C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Aeromotive Stealth Fuel Pumps - www.PartsTaxi.com
Old 11-03-2010, 11:25 AM
0PartsTaxi.com
Former Vendor
PartsTaxi.com's Avatar
Default Aeromotive Stealth Fuel Pumps - www.PartsTaxi.com
Finally, a solution to your Corvette’s fuel system needs. No more drilling your fuel tanks, no more risking pump failure in a 1, 2, or 3 pump set ups, no more surge tanks, no more mess. Aeromotive has engineered a patent-pending, complete drop-in fuel system available for C6 and late C5 Corvettes. The system provides a single Eliminator Fuel Pump capable of supporting big HP. The best part, it’s a complete drop-in assembly into your factory tank that still incorporates the factory jet siphon system. Now you can plumb a true return-style system into your Corvette without the worry of the siphon system and while using the factory fuel tank.
Supports 1000HP Forced Induction or 1300 HP NA
Aeromotive A1000 Corvette Stealth Fuel Pump Kit - $625.95
Support 1400HP Forced Induction or 1900 HP NA
Aeromotive Eliminator Corvette Stealth Fuel Pump Kit - $789.97
Old 11-03-2010, 02:02 PM
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
Is this really a drop in system like was discussed here? http://forums.corvetteforum.com/1574997990-post9.html
I can't picture exactly how it would drop in and connect to the OEM lines.
Old 11-03-2010, 02:40 PM
TimbrSS
TimbrSS's Avatar
install instructions from aeromotive:
http://aeromotiveinc.com/wp-content/...0/08/18670.pdf
looks like you need to run braided lines, fuel rails, regulator. (purchased separately)
Old 11-03-2010, 03:44 PM
d.medic
Support Corvetteforum!
d.medic's Avatar
St. Jude Donor '10
Like the HOB kit??
Old 11-03-2010, 04:38 PM
Vetteinplano
Vetteinplano's Avatar
According to the instruction manual:
Utilizes the factory tank, o-ring, lock ring and mounting location
• Includes all necessary fittings and hardware to plumb the pump into your tank.
Old 11-03-2010, 05:23 PM
old motorhead
old motorhead's Avatar
Received 1,336 Likes on 945 Posts
Isn't the fly in this ointment the return line?
Old 11-03-2010, 05:39 PM
carlrx7
carlrx7's Avatar
St. Jude Donor '08-'09
i want some -db readings. if its loud, no way, no matter how cheap it is.
Old 11-04-2010, 09:56 AM
5 Liter Eater
St. Jude Donor '11
Sure, it drops right into your tank. It even plumbs into the crossover. The rub is hooking up the feed line.
Old 11-04-2010, 03:04 PM
wilson34
wilson34's Avatar
Does anyone know how much power this would support at boost referenced corvette fuel pressures?
Old 11-04-2010, 03:09 PM
5 Liter Eater
St. Jude Donor '11
Old 11-04-2010, 07:06 PM
wilson34
wilson34's Avatar
Yea.....I feel those numbers are determined at a lower pressure. Not near 60-70-80psi. Aeromotive pumps drop off pretty much as the fuel pressure goes up.
Old 11-04-2010, 08:39 PM
0Jeremy@HOB
Former Vendor
Jeremy@HOB's Avatar
These numbers were flow tested from base 58psi. Obviously high pressure will lower you're flow so I highly recommend running a larger injector to keep fuel pressure down in order to keep flow up. These pumps will still support the advertised power levels with corvette fuel pressure.
Old 11-04-2010, 09:09 PM
vertC6
vertC6's Avatar
So what is the final answer, does this work with the factory lines?
Old 11-04-2010, 09:23 PM
gotjuice?
gotjuice?'s Avatar
St. Jude Donor '13
I believe you still need to run a return line and regulator.
Old 11-04-2010, 09:24 PM
0Jeremy@HOB
Former Vendor
Jeremy@HOB's Avatar
With an array of fittings you could adapt it but I don't suggest it. You'll quickly reach the limit of the stock lines once you step up to this fuel pump.
Old 11-05-2010, 12:11 AM
Spying Beast
Spying Beast's Avatar
I have heard mixed reviews if this fuel system, what kinds of warranty is involved?
Old 11-05-2010, 12:32 AM
BoosterClub
BoosterClub's Avatar
Originally Posted by jeremy@hob
these numbers were flow tested from base 58psi. Obviously high pressure will lower you're flow so i highly recommend running a larger injector to keep fuel pressure down in order to keep flow up. these pumps will still support the advertised power levels with corvette fuel pressure.
Old 11-05-2010, 04:34 PM
0PartsTaxi.com
Former Vendor
WOW, lots of interest in these. Thanks Jeremy for jumping in and answering some questions.
From a forum member in a related post that is running this pump, his list of additional items needed;
Aeromotive Related LS Components:
Fuel Filters: Check Valves:
12301 (pump/race gas) 15106 (6AN)
12335 (race gas/E85) 15107 (10AN)
12305 (filter bracket)
Fuel Pressure Gauge:
Fuel Pressure Regulators: 15633 (dry 0-100psi)
13101 (10AN ports)
13109 (6AN ports) Fuel Rails:
14106 (LS1/LS6)
Electrical Components: 14114 (LS2)
16301 (pump wiring kit) 14115 (LS3/L76)
16306 (pump speed controller) 14142 (LS7)
14147 (LS1, Edelbrock 29085)
14156 (Platinum LS1/LS6)
As far as the warranty question, direct from AeromotiveInc.com;
Aeromotive Product Warranty, Policy and Procedure: Retail
All Aeromotive products sold are warranted free from defects in materials and workmanship for a period of one year from the original date of purchase. No warranty claim will be valid without authentic, dated proof of purchase. This warranty is to the original retail purchaser and none other and is available directly from Aeromotive and not through any point of distribution or purchase. If a defect is suspected, the retail purchaser must contact Aeromotive directly to discuss the problem, possible solutions and obtain a Return Goods Authorization (RGA), if deemed necessary by the company. All returns must be shipped freight pre-paid to the company and with valid RGA before they will be processed. Aeromotive will examine any product returned with proper authorization to determine if the failure resulted from a defect or from abuse, improper installation, misapplication or alteration. Aeromotive will then, at its sole discretion return, repair or replace the product.
Old 11-05-2010, 11:28 PM
vertC6
vertC6's Avatar
I understand what you are saying but for those of us in the 600-700rwhp range that are all using stock lines with no problems. Wouldn't it be feasible to have a lesser pump that could handle this range? 90% of us don't strive to get to the 900 to 1000 hp range and don't need that much fuel, however we do need something better than stock. I would prefer not to run a BAP or dual pumps if I don't have to. I believe you could sell hundreds of these if not thousand if they were a "true" drop in and go. Just my .02
To Aeromotive Stealth Fuel Pumps - www.PartsTaxi.com
Quick Reply: Aeromotive Stealth Fuel Pumps - www.PartsTaxi.com
