LS2 or LS3 for boost?
I'm looking to buy a corvette which I would supercharge, and I am trying to decide if I want an LS2 or LS3. Amazingly, I couldn't find any threads about this.
I know the LS3 is a little bigger and badder, but it runs a bit higher compression ratio (10.9 vs. EDITED, I was wrong: 10.7). Do you need to run slightly less boost with an LS3 to keep it from detonating?
If anyone knows of any safe horsepower limits with or without water injection of the LS2 or LS3, that would be helpful. I think 550 to 600 whp would be a good number.
I know the LS3 is a little rarer, so if you think they are much more expensive to replace, that information would be helpful as well.
Thanks in advance!
EDIT: Is it just me, or do the LS3's sound a little meaner? To me, a LS2 sounds kind of like an LS1, and a LS3 sounds a little meaner and lopey, like a LS6/7.
Thanks in advance!
I know the LS3 is a little bigger and badder, but it runs a bit higher compression ratio (10.9 vs. 11.3 IIRC). Do you need to run slightly less boost with an LS3 to keep it from detonating?
Thanks in advance!
Thanks in advance!
The LS3 has a stronger block, stronger rod bolts, much better flowing heads.
In my opinion, the LS3 is the better choice for supercharging.
Thanks! I googled LS3 compression ratio, and the first link implied it was 11.3, but once you clicked the link the data was in a chart and showed 10.7:1, as you've stated.
That right there pretty much answers my question.
Anyone know what the safe limits (or records) are with and without water injection?
All else being equal, you can get to your power goals with less boost if you start with an LS3. Less boost = less heat which can equal a longer engine life. A few extra cubes don't hurt the quest either.
Don't know what the "safe" limits are, but a friend has a LS3 with a maggie, cam and long tubes, He's running 6-6.5 pounds of boost(no injection) and with a safe tune for 91 octane is getting around 554 RWHP. Tuned for 93 octane, he was seeing 604 RWHP. He feels comfortable with that, but he is not interested in pushing it further.
Supporting Tuner
LS2 with A&A Vortech + Headers (automatic)
LS2 with A&A Vortech + Headers (manual)
LS2 with A&A Vortech + Meth/Heads/Cam/Headers (manual)
LS3 with EnglandGreen Havoc cam + A&A Vortech/Headers - stock heads, no methanol injection (manual)
LS2 with EnglandGreen Whiplash cam + A&A Vortech/Meth/Heads/Headers (manual)
The LS3 makes power with less parts and at a lower cost.
Stephen
Stephen
Stephen
Stephen
Location: Greater Detroit Metro MI, when I'm not travelling.
Thanks in advance!
Thanks in advance!
Also not sure where you got your comp. ratio info from. The LS3 is lower compression, as others have pointed out.
Both engines work great. If you ruin an LS3, the engine block costs 500 bucks more; it is not any more rare; both are readily available for anyone with a little $$$ to spend. The LS3 IS the better engine, with better flowing heads and a little more CuIn, but they both work great, and the money you save by going with an LS2 could go towards headers, a cam, methanol injection, etc...
My LS2 made 597RWHP / 517RWTQ with nothing but a base A&A supercharger kit, headers and a tankfull of 93 octane. I was extremely happy with it.
Thanks for the input. It sounds like you guys are making gobs of power on either block.
I think that bore has something to do with the exhaust sound. The head design definitely does have something to do with the sound (think LS1 vs a modular motor). Having said that, I don't really care enough to argue about it.
6162/5967 = 1.033, but I think bore has some effect on engine sound, but maybe it's corresponding change in camshaft profile? Bore may be unnoticeable on a LS2 vs. LS3, but I felt like they sounded slightly different when comparing them on youtube. It probably has a lot to do with the headers/exhaust, as you mentioned.
[QUOTE=Cyphear;1574728445]6162/5967 = 1.033, but I think bore has some effect on engine sound, but maybe it's corresponding change in camshaft profile? Bore may be unnoticeable on a LS2 vs. LS3, but I felt like they sounded slightly different when comparing them on youtube. It probably has a lot to do with the headers/exhaust, as you mentioned.[/QUO
Are you basing your purchase on the sound of the engine , because the sound will vary , depending on exhaust system & camshaft selected, I would buy the ls2
