Ragin Racin Blower Cams!!!!
Supporting Vendor
I am sure you guys see some of sick builkd we put out there. Just wanted to give you guys a chance to see our Line of Blower Cams that are available.
219/231 114 .600 - LS1, LS2
224/232 113 .625 - LS1, LS2, LS3
224/248 117 .625 - LS7
232/256 114 .660 - LS7
If you have any questions please feel free to give us a call
__________________
RAGIN’ RACIN’
Randy Leger
337-278-8397
sales@raginracin.com
http://www.raginracin.com
RAGIN’ RACIN’
Randy Leger
337-278-8397
Quality takes time, Pamp. It's only Shawn and Randy taking care of the many Corvettes that go in and out of there....and the occasional Porsche, right Randy?
I didn't really understand that at first, and probably gave them a little more s**t than they deserved. (Public apologies for that, fellas)
If it's been a week, just give 'em a call back. They get really busy. OR shoot 'em an email.
I have cam #2 on that list and it is pretty awesome. Just enough lope to sound bad-*** but not fall on it's face or shake your teeth out at a red light. A nice increase in power before the boost kicks in, and once it does it's a screaming effin' banshee. Really. It's scarier than other Vettes I've been in with more power.
I know guys that are local to me with *other forum vendor* cams. Some make more power, but drive or run like hot garbage. (also tune dependent)
It's also VEEEERY close to a certain "custom grind" that gets a lot of attention here, but uses less lift on a smaller lsa w/ the same int/exh durations. (and for the record, the RR cam came first. They won't say it, but I will.)
Supporting Vendor
I usually return all phone calls when a message is left. PM Me your number and I will give you a call later today
Supporting Vendor
Well you know me...... I have the 232/256 114 in my car now. I will be publishing numbers on my LSx 427, ECS 2200 Build very soon. It is Street Tuned, just haven't had a chance to dyno it.
Thanx!
Ruben
I see on you first 2 cams that you have the exhaust duration at 231 & 232 for ls2 and 3 motors. If I am running 8 psi with and eforce and headers do you feel that is sufficient duration? Obviously the ZR1 also has a similar ex. dur. so my thoughts were maybe to go a little longer with it. From my research it seems that 236-238 duration seem to do better up top. Any thoughts?
As for specs, I can list them if you REALLY want. But it'd be easier to list the things NOT on the car yet.
The basics though; roughly 600 rwhp @ 8psi w/ RR's 224/232 grind, stock shortblock, no meth (yet)
I opted to upgrade the cooling system and brakes first before trying to put more power down. And still debating whether I want to do the fuel system next or not.
The current project is a built A6 install though....trying to get the drivetrain situated looking ahead to sticky tires.
Supporting Vendor
Its not a bad idea to run a little more split with a blower on the car. We can always custom design a cam for your application. The 219/231 cam we have is a very nice cam and we are making 800rwhp in a c5 with that cam so bigger is not always better. We just use the cams to make the motor more efficient. There is always a point of deminishing returns.
Shawn
Supporting Vendor
In that application I would use our Stinger Cam. 224/232 113. This would give you everything you are looking for. Give me a call and I can get out to you.
Any blower cams similar to Stalker cam? I have the Lethal and it drive great but looking to get rid of the shake at idle with the AC on. thanks again for a great product
How would this cam work if I wanted to keep the stock exhaust manifolds on an LS7. Also anyway to work with heads being milled without going into the shortblock if I was wanting to add an A & A blower setup?
