.::House of Boost/Aeromotive Eliminator and Pro Series Fuel Pump Assemblies::.
#41
I took a couple of pictures of the Eliminator version of the new Aeromotive setup.
It installed very easy and all parts were of very high quality and fit.
We will use a Aeromotive pump speed controller to keep noise and heat down during normal use. The stock wires/connector is used to the pump but it's cut down to about 5" length. The speed controller is feed directly from B+ and is connected to the stock female fuelpump connector.
Thanks to Jeremy at HOB for great service
#46
