Crank case pressure building from boost???
I have noticed that I'm getting a little leakage of oil around my katech valve cover only on the passenger side and around the oil pan gasket area. What do you high boosted (supercharged) cars do in an event this is happening? Doug from ECS just said to add a vent on the sump tank but what else can be done so that this oil stops this leaking issue...I was told by my installer to tap the passenger side valve cover but I hate to do it!!!
Any info would be great guys
thanks
thanks
I have noticed that I'm getting a little leakage oil oil around my katech valve cover only on the passenger side and around the oil pan gasket area. What do you high boosted (supercharged) cars do in an event this is happening? Doug from ECS just said to add a vent on the sump tank but what else can be done so that this oil stops this leaking issue...I was told by my installer to tap the passenger side valve cover but I hate to do it!!!
thanks
thanks
Mine are the cast alum. powder coated black. We tried some black epoxy but it looks like its still the same. I will take it off and try again...
My sump tank has 2 connections:
Connection 1: runs over and splits and runs to both katech valve cover connections.
Connection 2: runs up to the intake charge pipe filter area. can't really see where it goes but it looks like to create a vaccum of such.
The valley cover connection and the intake connection are connected together using a black tube.
This is the way it's done now and it's leaking on the passenger side valve cover gasket area and the oil pan gasket area.
Thanks John for the PM brotha!!!
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes
That's why we include a breather and catch can with the C5 and std C6 kits Jeff, it just takes a little more effort to plumb with the dry sump.
How do guy's install this setup and route the tubing in a dry sump ls7?
Well I guess I will be taking the car to Dallas Performance and let Taylor have a go at it. (SD TUNE) needed!!!
Also I'm have trouble with a leaky passenger side Katech cover and oil coming from around the oil filter area and oil pan gasket. I was told it was due to pressure from the car making boost (crank case pressure) but if I normally drive it (not hard) it still leaks. I guess you would think that a catch can with breather would have been added if this could have been a potential problem but it was not installed. I will do it to see it does the trick...
The check valve is in the right direction on the loop from the valley cover nipple to the intake also as I blew thru it and it works. I guess it's just too much pressure in the intake...
Also,my fans come on sometimes and other times they don't. I have replaced that damn module 3 different times and each time I unplug one and put the other one in it works but when I turn the car off and on again the fans will not turn on again when it reaches the pcm temp setting 196-198 degrees. When we unplug it again and plug it back it finally starts working again. This is a real pain in the ***. Any ideas???????????
I check the plug to the module, I have 3 different modules and I dont think its that now so what else could it be?????
My wife is upset because there is always something wrong and she has not even had a chance to ride in it. I told her that the next move is to sell it if I can get these issues resolved...
Any help will be apprceciated!!!
You are pushing oil out of EVERY gasket, you have too much crank case pressure. Once you push out a valve cover gasket it is going to continue to leak.
1. he told you that you needed a bigger BOV..... you left it and surged the compressor.
2. he told you that the short belt wouldn't do anything but carry boost a little longer...... it didn't do anything but carry boost a little bit longer.... he even spent two days on the dyno at no charge to you to show you.
3. he tried to tell you the process to figure out what's wrong with the fans, then showed you in the GM service manual..... if it's not the module then let him proceed to the next step.
4. he told you that you are building up crank case pressure and that you need large vents off each valve cover..... what has everyone on here been saying? that you need to vent the motor. NO putting a filter on the oil tank isn't going to do ****..... just like putting another BOV in with the other one using the same hole.
LISTEN and your issues will be over with......
I also talked to him and he said if you are going to let someone else do a SD tune Taylor is the only person he would trust with it. But you should talk to Chris and listen to what he has to say
Jeff, The Katech valve covers I have(Cast aluminum) already have a port that has a plug in it to install a fitting for PVC routing in other applications FYI etc... I don't know if your has it, but it was there. I would install a breather (PVC inlet basicly) that and larger vacum lines size wise to the intake of the blower and I would plug off your intake totally away from the crank case. I used to do it the way you have at least I think if I have my imaginnation going right LOL! This way worked better for me no oil leaks anywheres. I know your car is slightly different because of the dry sump, but the function of a PVC system is the same GL!
