Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-18-2010, 08:54 AM   #1
schilitj
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Support Corvetteforum!
schilitj's Avatar
Default Myth (or truth) about Meth
I read many differing threads about the value of meth for supercharged vettes. I've got a 2005 C6 with 402 stroker and a procharger D1 set-up. Have heads, cam, headers, etc along with a DeWitts rad.
I no longer run the car down the 1/4 mile, it is and has always been my DD. I live in Boca Raton, FL, so the summers are hot.
I was recently at a car show and it was strongly suggested that meth should be added as a standard practice on all supercharged vettes
So, here's my question, should I or shouldn't I add meth? What are the up-sides and what are the down-sides?
schilitj is offline   Reply With Quote
Old 01-18-2010, 09:45 AM   #2
Gannet
CF Senior Member
St. Jude Donor '06
Gannet's Avatar
Funny, I hadn't heard that the ZR1 had a meth system.
Gannet is offline   Reply With Quote
Old 01-18-2010, 10:24 AM   #3
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5&C6 609-752-0321
Quote:
The ZR1 is also 8.5 :1 Compression ratio (+-) Once you go and up the power on it you need to either have meth, or run race fuel in it like we do in our project ZR1, and I recall seeing where LPE did the same in their project ZR1. You really cannot properly compare the two in this situation IMHO.
Upsides to meth are simple; lower IAT's, octane on demand, clean intake/pistons, basically the ability to not only make a lot more power on pump gas, but the ability to continue to make the power you did on the dyno in real world situations.
Downsides; filling the tank, although it's simple, you still have to do it. The possibility of a failure, but there should be proper safeties in place from your tuner in the event of that ever happening the car would just fall on it's face in power, and you get it corrected. Either way, your never stuck anywhere, you would just have to keep it out of high boost until it's corrected.
I hope that helps.
DOUG @ ECS is online now   Reply With Quote
Old 01-18-2010, 10:32 AM   #4
Gannet
CF Senior Member
St. Jude Donor '06
Gannet's Avatar
Quote:
Well, my point was just that any such sweeping statement as "standard practice on all supercharged Vettes" is Typical car show blather.
In some circumstances meth is not required, in some it's optional, and in some it's mandatory. It's up to the development engineer (that would be the owner or tuner of a modded FI Vette) to determine which applies in his case.
I think you did a great job of pointing out the advantages and disadvantages.
Old 01-18-2010, 10:54 AM   #5
DOUG @ ECS
DOUG @ ECS's Avatar
Agreed, meth is not mandatory as long as you are within the limits of the fuel you are using.
Old 01-18-2010, 11:37 AM   #6
peter pan
Life Time NCM #2196
peter pan's Avatar
I also look at meth as safety from when I put in 93 and it is really 87. The octane boost is still there under heavy boost. I have been using meth over 4+ years on my forged C5 and like that my IATs in the heat in Texas is a non issue. Sure I do not need meth with a forged setup, but then running 20lbs of boost with meth is a good thing
peter pan is offline   Reply With Quote
Old 01-18-2010, 11:39 AM   #7
Jutskin
CF Senior Member
How do you really know the limits of the fuel you are using?
Pump may say 91 octane.....but is it every time you fill up? Could it be bad gas?
If your car has been tuned with 91 octane in the tank and you fill with some bad 91 octane gas there could be catastrophic results....especially if some tuner car challenges ya on remote highway somewhere.
Meth makes me sleep better.
Jutskin is offline   Reply With Quote
Old 01-18-2010, 01:01 PM   #8
greekc6
CF Senior Member
greekc6's Avatar
just think of it as cheap insurance. just use meth for safety and a little more power. dont rely on meth just for high octane fuel
greekc6 is offline   Reply With Quote
Old 01-18-2010, 03:33 PM   #9
bosco 08
CF Senior Member
bosco 08's Avatar
when it comes to boost, meth is your friend
bosco 08 is offline   Reply With Quote
Old 01-18-2010, 03:41 PM   #10
06.Z51.MontRed.Vert
CF Senior Member
St. Jude Donor '08-'09
06.Z51.MontRed.Vert's Avatar
Location: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
All us "boost" guys are "meth" heads. The system just plain works and the safety factor is awesome.
06.Z51.MontRed.Vert is offline   Reply With Quote
Old 01-18-2010, 04:19 PM   #11
dmaxcamss
CF Senior Member
dmaxcamss's Avatar
06.Z51.MontRed.Vert, are you making the numbers in your avatar with a stock cam or aftermarket? Pump gas or race fuel?
__________________
'05 Corvette
HKE 416 ci 9.7:1, DP Blower Cam, DP Direct Drive System, DP Big Mouth, Procharger D1SC, IW 8-Rib OD Balancer, MSD BAP, Kooks, Corsa, RPS Twin Disk, G-Force Tune, GM ZO6 Rear Widebody, CCW T10, Nitto Invo, Home Built & Assembled
FOR SALE:
*HUGE Sale! Peformance, Appearance, Audio, Misc. Multiple Applications*
JL Audio 10W3V3, JL Audio 10" Sub Grilles, Focal 165V2S, PAC SWI-ALP, Custom Sub Box
dmaxcamss is offline   Reply With Quote
Old 01-18-2010, 10:53 PM   #12
greekc6
CF Senior Member
greekc6's Avatar
Quote:
i believe he still has my old setup. stock cam novi 1500 pump gas with meth.
Old 01-19-2010, 12:13 AM   #13
dmaxcamss
CF Senior Member
dmaxcamss's Avatar
Damn, 676 rwhp stock shortblock, stock heads, stock cam, pump gas, and meth? That's sick. I thought for sure with those numbers it had either race gas or a cam. Is that with a filter?
__________________
'05 Corvette
FOR SALE:
Old 01-19-2010, 01:02 AM   #14
TRIZ
CF Senior Member
TRIZ's Avatar
How do you really know the limits of the Meth you are using?
I know you can get bad gas at the pump 91 octane but what if U got some bad Meth?
TRIZ is offline   Reply With Quote
Old 01-19-2010, 09:50 AM   #15
Jutskin
CF Senior Member
Yikes.......
I do make an effort to not buy the no name variety.
To me a meth and a flip drive are important additions to a supercharged vette....especially if you have a heavy right foot
....like me.
Old 01-19-2010, 09:52 AM   #16
06.Z51.MontRed.Vert
CF Senior Member
Total stock engine, stock cam, pump gas, AND thats with 410's. ECS could have bumped it further but we kept it on the "safe" side
Old 01-19-2010, 09:54 AM   #17
06.Z51.MontRed.Vert
CF Senior Member
Quote:
Correct, I'm still on the same system that greekc6 used to have.
Old 01-19-2010, 04:25 PM   #18
dmaxcamss
CF Senior Member
dmaxcamss's Avatar
06.Z51.MontRed.Vert, how much boost? I assume you're using a restrictor plate?
__________________
'05 Corvette
FOR SALE:
Old 01-19-2010, 07:45 PM   #19
Drewstein
CF Senior Member
Drewstein's Avatar
Quote:
I'm one of the few that is against it. If I want more power I'll fill up with 109 and turn up the boost.
I do agree with the above posters, tune for 91 and run it for safety.
Drewstein is offline   Reply With Quote
Old 01-20-2010, 01:01 AM   #20
greekc6
CF Senior Member
greekc6's Avatar
i made 725 with all the stuff you said above. im assuming you mean air filter and yes. 14-15lbs will do it for ya haha
Reload this Page Myth (or truth) about Meth
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
