Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-15-2010, 01:28 PM   #1
SinisterC6
CF Senior Member
SinisterC6's Avatar
Send a message via AIM to SinisterC6
Default Gauge pod install
I decided I would be different and make my own gauge pod, I got the idea from a wrx that had something similar installed. As you can see I used PVC pipe which fits the gauges perfectly, balsa wood as a base and styrofoam to make the desired shape. I wrapped it in a vinyl similar to the dashboard so it matches then painted the front flat black.
to secure the pod i used zip ties looped through the wood base and mounted it on the defroster grill, this way the pod is removable for service and does not require any drilling into the dashboard. I did have to relocate the sunload sensor with this setup but it was as easy as clipping a piece of the grill and zip tieing the sensor into place.
the wires run through a hole in the base through the defroster vent and into the cavity behind the gauge cluster. from th harness the wires travel over the steering cradel and down to the driver foot well where they exit through a hole below the grommit with the hood release cable
As you can see i wired all the gauge connectors together and made a harness, wires are labeled and wrapped in black duct tape to match oem wiring. the gauges require three connections:
switched + : this is coming from the passenger foot well from an add-a-fuse plugged into the windshield wiper fuse, the wire comes behind the carpet and into the cavity behind the center console
ground : i removed a bolt holding the steering cradle in place and used a grounding clip attached to a wire
lights: the gauges are tinted, when you turn the ignition on they light up revealing they're reading, then you turn on the lights they will dim like the factory gauges 30%. previously i added leds to light up my ashtray switch panel, so i merely used this wire found in the cavity behind the center console.
the wideband 02 sensor need a constant + wire so i tapped the wire supplying the 12v outlet, ive tapped here before its a very heft circuit with a 30A fuse so it can power lots of goodies. the WB O2 box is in the glove box as it needs to be calibrated every 6 months by pressing and holding a button, when i button everything up i will tape it down with automotive 2face tape
more pics
had to relocate my gtech, the plug is still hard wired into the 12v outlet circuit but now the wiring travels behind the gauges and out between the dash and apillar
feel free to ask questions id be glad to help anyone looking to install theyre own gauges.
SinisterC6 is offline   Reply With Quote
Old 01-15-2010, 01:33 PM   #2
SinisterC6
CF Senior Member
SinisterC6's Avatar
im running glowshift gauges in my car, they match the stock gauges and are less expensive than the autometer brand while still having great reviews. I did a lot of research before buying on different car forums and got nothing but praises with people using them for 3 years.
boost gauge
fuel
i would recommend theyre wideband sensor as well to ensure you don't go lean on a run.
they gave me a coupon code to use: enter 08shipping and get 10%off your order, also they're running free shipping on orders above $50
Old 01-15-2010, 03:21 PM   #3
Greg A
CF Member
Greg A's Avatar
Good find on the Glow Shift gauges SinsterC6. Decided to order a set and the price is great!
Greg A is offline   Reply With Quote
Old 01-16-2010, 01:12 PM   #4
excessive81
CF Senior Member
excessive81's Avatar
Send a message via Yahoo to excessive81
i put glow shift gauges in my bonneville when we did the blower and they are nice looking... color match is sweet too! thought bout swaping my auto meters from vette with these too
excessive81 is offline   Reply With Quote
Old 01-20-2010, 12:51 AM   #5
outbackfarmer
CF Senior Member
Support Corvetteforum!
outbackfarmer's Avatar
Wow, I love the gauges where the air vent was on the boniville. Does anyone know if there is a set up like this for the vette?
outbackfarmer is offline   Reply With Quote
Reload this Page Gauge pod install
Tags
2005, ac, ashtray, boost, c5, c6, corvete, corvette, dim, gauge, guage, install, installation, nitrous, pod
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
a pillar pod install question and fuel pressure gauge sender question TT_Vert C5 Tech 21 09-04-2004 12:54 PM
I'm on a roll today, Info needed, Gauge pod J Z06 C4 General Discussion 17 09-10-2003 09:41 AM
pillar gauge pod ludachriss2 C4 Tech/Performance 22 03-31-2003 11:28 PM
FOR SALE: Autometer 2 Gauge Pod for the C5 **NEW** theperfectcorvette C5 Parts for Sale/Wanted 15 09-25-2002 03:28 PM
who has a pic of a dual gauge pod on the a-pillar of their c4? Wheelman C4 Tech/Performance 18 07-10-2002 03:27 AM
Dual Gauge Pod and Shift Light Pictures BBC5 C5 Forced Induction/Nitrous 19 07-06-2002 03:36 PM
A piillar gauges. only found a 2-gauge pod for C5. also question about which gauges rwj383 C5 Tech 34 01-16-2002 11:17 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
