Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-13-2010, 11:05 PM   #1
Gannet
CF Senior Member
St. Jude Donor '06
Support Corvetteforum!
Gannet's Avatar
Default Is it better to run a ProCharger towards the bottom or top of its range?
Let's assume you want about 1400 cfm out of a Procharger. A D-1SC-1 will do that right about at redline. Or an F-1A will do it loafing with the largest blower pullies.
Which will result in the least charge heating?
Which will have the lesser drive loss?
Gannet is offline   Reply With Quote
Old 01-13-2010, 11:39 PM   #2
PowerLabs
CF Senior Member
PowerLabs's Avatar
Send a message via ICQ to PowerLabs Send a message via AIM to PowerLabs Send a message via MSN to PowerLabs Send a message via Yahoo to PowerLabs
Neither. You have to run any centrifugal compressor in the middle of its efficiency "island" if you want minimal charge heating and parasitic drag per power generated. Here is an example from a Vortech:
You will see that at the peak of its RPM range the efficiency plummets, but it is also very low if you try to run a lot of boost early on, or very late in the RPM range, or a lot of boost in general...
PowerLabs is offline   Reply With Quote
Reload this Page Is it better to run a ProCharger towards the bottom or top of its range?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
