Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-11-2010, 08:51 PM   #1
Adam Sean
CF Senior Member
Adam Sean's Avatar
Default What is the fuel system in the ZR-1
What is the fuel system in the ZR-1? How much power can it support? What would it cost? How hard would it be to make it work in a 2005 Z51? I am looking for user friendly options to upgrade the factory setup for my supercharged vette
Adam Sean is offline   Reply With Quote
Old 01-12-2010, 02:07 AM   #2
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Quote:
Its actually quite complex, it consists of a brushless pump running on three phase power. The control reference (desired fuel pressure based on engine load) comes from the PCM which sends a control signal to the via the high speed GM LAN to the fuel pump control module. The FPCM in turn drives the control relay to control the three phase brushless fuel pump. The control signal from the FPCM is a 400hz PWM (pulse width modulated) signal. The frequency of this PWM signal is varied to control the pump speed as pressure is either reduced or increased as demanded by the PCM. For feedback there is a pressure sensor in line to provide a pressure feedback signal to the PCM, thus providing a basic closed loop control loop for pressure control.
If you wanted to incorporate this system into your car, it would not be impossible but it would be very expensive. It would require the ZR1 PCM, and all the wiring and other smart devices such as teh FPCM, FPCM relay, the special pump and all the associated wiring. Seeing on the ZR1 uses a different PCM it will require a new engine harness, not cheap at all, but not impossible.
tjwong is offline   Reply With Quote
Old 01-12-2010, 07:37 AM   #3
Adam Sean
CF Senior Member
Adam Sean's Avatar
I doesn't sound like the cheap alternative that I was looking for...
Old 01-12-2010, 09:09 AM   #4
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5&C6 609-752-0321
Tom hit it right on the head, great system though. We have not been able to run a ZR1 out of fuel yet with the stock system. Too bad it's such a complex install to convert to a standard C6.
DOUG @ ECS is offline   Reply With Quote
Old 01-13-2010, 02:30 AM   #5
396375
CF Senior Member
St. Jude Donor '08-'09
396375's Avatar
Has anyone priced the ZR1 pump?
396375 is offline   Reply With Quote
Old 01-15-2010, 02:03 PM   #6
0IPS Motorsports
Former Vendor
Send a message via AIM to IPS Motorsports
Quote:
$1100 dollars
Were tinkering with a ZR1 fuel system now to see what we might be able to work with.
IPS Motorsports is online now   Reply With Quote
Old 01-15-2010, 05:42 PM   #7
EuroRod
CF Senior Member
EuroRod's Avatar
I'm experiencing what seems to be a fuel starvation problem with my 2005 ProCharged car, too. The SC has been on the car for 3 years with zero issues, but, 6 weeks ago, it began acting as if it was running out of gas after running it thru the gears. Right after shifting into 3rd, the engine would just go dead. After coasting for 10 to 15 seconds, it would sputter back to life, then run as if nothing was wrong. It never did this before, so I assumed the fuel pump might be dying, so I replaced it. I got the car back early this week, but, because of work and weather, did not drive it until today. I still have the same symptoms. Tomorrow I am going to try again. This time I will run it thru the gears again and if it kill again, I'm going to shut off the ignition, and fuel pump, coast to the shoulder, and pop off a fuel fitting to see if the fuel rails are dry.
If anyone else has experienced this problem, and discovered a fix, please let me know. I hope I don't need to upgrade the fuel delivery system. The car ran great with the stock pump for almost 25k miles.
EuroRod is offline   Reply With Quote
Old 01-15-2010, 11:32 PM   #8
PowerLabs
CF Senior Member
PowerLabs's Avatar
Send a message via ICQ to PowerLabs Send a message via AIM to PowerLabs Send a message via MSN to PowerLabs Send a message via Yahoo to PowerLabs
I had a similar problem when the following conditions were met:
1- Driving the car for several hours non stop (I.E. This only happened on long non stop drives).
2- Around 1/4 tank or less.
It would then fall completely flat on its face when given full throttle, but stop after refuelled.
I BELIEVE this is due to the fuel pump getting too hot. I spoke with a few other supercharged C6 owners who reported the same problem with other kits as well. Sadly I do not have a good solution for this, but I am planning on going dual Walbros in my car...
PowerLabs is offline   Reply With Quote
Old 01-16-2010, 09:00 AM   #9
EuroRod
CF Senior Member
EuroRod's Avatar
When my car ran out of fuel two days ago, it had a brand new pump assembly, full tank, the car had been driven just enough to get up to operating temp, and it was 40 gegrees outside. I don't think my pump was getting too hot. I just can't come up with an answer. Like I said, the car ran fine for 3 years and 25k miles with the original pump.
Old 01-16-2010, 12:40 PM   #10
excessive81
CF Senior Member
excessive81's Avatar
Send a message via Yahoo to excessive81
zr1 is sweet fuel system but $$$$
get second aux pump for when you go into boost. that will solve every fuel related issue. And can ditch bap
excessive81 is offline   Reply With Quote
Old 01-16-2010, 01:35 PM   #11
PowerLabs
CF Senior Member
PowerLabs's Avatar
That makes no sense. Are you runing a BAP? If so that could be the answer...
Old 01-16-2010, 09:54 PM   #12
EuroRod
CF Senior Member
EuroRod's Avatar
Quote:
No BAP. Car never needed one. I do run the RaceTronics wiring harness that puts alternator current directly to the pump. Other that that, and 60# injectors, the fuel system is 100% stock. Raining here today, so could not check to see if fuel rails were are running dry.
I'm stumped.
Reload this Page What is the fuel system in the ZR-1
Tags
fuel, system, zr
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ran the ZR-1 at the track Friday FastMatt2 C4 ZR-1 Discussion 16 07-04-2003 02:25 PM
ZR-1 vs 1000 HP Supra = Blown Motor LIMEY C4 ZR-1 Discussion 57 04-13-2003 06:54 PM
415" 90 ZR-1 Pictures LIMEY C4 ZR-1 Discussion 46 07-16-2002 01:29 PM
What's the best Gasoline for your ZR-1? Hib Halverson C4 ZR-1 Discussion 13 06-09-2002 06:18 PM
What are the Disadvantages of Getting a 91-2 Z over 94-5? LowFlight C4 ZR-1 Discussion 13 02-19-2002 10:23 AM
Just got my ZR1 back. Have a Problem w/ motor. Please Help!! Clemson ZR-1 C4 ZR-1 Discussion 9 01-23-2002 06:15 AM
what pulled more top-end callaway or ZR-1? FastMatt2 C4 ZR-1 Discussion 23 01-04-2002 07:00 PM
ZR-1 vs. Callaway Twin Turbo 3Deuces C4 ZR-1 Discussion 89 09-02-2001 11:35 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
