Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-09-2010, 12:18 PM   #1
Gannet
CF Senior Member
St. Jude Donor '06
Support Corvetteforum!
Gannet's Avatar
Default Living with a "high end" fuel system
Several of the better-known FI shops/suppliers offer "high end" fuel systems, ranging in price from about $1100 to $5300.
I assume that most or all of these will do the job, at least to "moderate" (up to 1000 rwhp) power levels. My question is, what are they like to live with? Are they reliable? Do they leak? Are they noisy? Do they run all the time, or just under boost? Are there any problems with driveability? Any adverse effect on fuel economy? Any reason not to put one of these on a daily driver?
I think most or all of these require dropping the LH fuel tank if the install is to be performed properly. I would really prefer not poking holes in the tank. Any idea what the labor charges for a typical installation are, including dropping the tank? Just roughly.
Thanks!
Gannet is offline   Reply With Quote
Old 01-09-2010, 01:00 PM   #2
HorsePowerAddicts
Supporting Vendor
HorsePowerAddicts's Avatar
Do you have a specific fuel setup in mind? How much power are you looking to make? Your fuel system can be set up a few different ways to handle more power. Aftermarket fuel setups are just as reliable as stock if setup properly.
HorsePowerAddicts is offline   Reply With Quote
Old 01-09-2010, 01:52 PM   #3
Bobby @ LG Motorsports
Premium Supporting Vendor
Bobby @ LG Motorsports's Avatar
The fuel pumps in our kit run the 24 hours of Le Mans with no issue. Thats why we chose the pump system we did.
As for them running all the time, they do not. One runs all the time like factory, the other runs off of a pressure switch under boost.
I have quite a few systems out there, zero failures to date.
Bobby @ LG Motorsports is offline   Reply With Quote
Old 01-10-2010, 06:51 PM   #4
zeshawn
CF Senior Member
- they will draw current
- they will make an annoying whine
- return style systems with big external pumps will heat the fuel to the point where you could literaly burn ur hand if you touch the fuel line
- they fail, especially those boost switch operated ones
I think the best option is the twin intake pumps, which will make 1000rwhp with BAP, and no annoying pump noise either.
zeshawn is offline   Reply With Quote
Old 01-10-2010, 07:23 PM   #5
Gannet
CF Senior Member
St. Jude Donor '06
Gannet's Avatar
Good feedback, thank you. This is the sort of thing I was looking for (or worrying about).
Old 01-10-2010, 08:30 PM   #6
zeshawn
CF Senior Member
Quote:
problem is, everyone will tell you how quite their fuel systems are - while tolerable noise levels are subjective (just like how every vendor says their cam drives like stock) - and that they had no failures, where in real those boost switches can fail very easily, and usually do so from heat (speaking from personal experience).
You could wire up an RPM window switch and let the secondary fuel pump kick in at say 3500rpms, that would be reliable.
again, the twin intank systems seem to be the best solution.
Old 01-10-2010, 08:32 PM   #7
BADZ
CF Senior Member
BADZ's Avatar
I run a twin intake pump setup (2)walbros. These are mounted inside the plastic can (low point) with no sloshing the fuel to worry about. I always run a 1/2 tank or more fuel on my weekend driver. On the startup is when you hear the pumps come on and thats it, no noise at all. This setup powers my 900hp street driver with no problems..
The best setup IMHO.
BADZ is offline   Reply With Quote
Old 01-10-2010, 08:43 PM   #8
zeshawn
CF Senior Member
agreed, this is the best set-up, and you can always add a BAP to even further the output of the pumps.
Old 01-10-2010, 08:48 PM   #9
Gannet
CF Senior Member
St. Jude Donor '06
Gannet's Avatar
Is this a return-style system?
Does anyone sell this as a drop-in, or do you have to buy bits and pieces?
Old 01-10-2010, 08:48 PM   #10
shizon'00
CF Senior Member
shizon'00's Avatar
I have a problem with absolutes. I have a return style system with a magnafuel 4303 that doesn't do what you said it does as do many others. Just as a switch from RPM or Boost isn't any more reliable than the other. I think they're both pretty reliable.
Anyway, I would suggest talking to the guys that run these systems in a lot of cars. You'll find you have a lot options to meet your goals.
shizon'00 is offline   Reply With Quote
Old 01-10-2010, 09:04 PM   #11
BADZ
CF Senior Member
BADZ's Avatar
Not a return style setup.
You have to piece it together depending on how you want to run it but it is as close to stock as your gonna get. It just supports much more hp.
I'm not running a BAP but could if there was a need for more hp's..
Old 01-10-2010, 10:13 PM   #12
Taylor@DallasPerformance
Supporting Vendor
Taylor@DallasPerformance's Avatar
We use a digital controller (solid state) for guys that want to run the pump off a switched source. Tested at 1,000,000 cycles by the manufacture.
__________________
Taylor Sims
www.DallasPerformance.com
214-349-1300
Taylor@DallasPerformance is offline   Reply With Quote
Old 01-11-2010, 01:58 AM   #13
MachineWorks
CF Senior Member
MachineWorks's Avatar
A BAP will not power two pumps. I have tested this. Too many amps.
MachineWorks is offline   Reply With Quote
Old 01-11-2010, 02:30 AM   #14
tjwong
CF Senior Member
tjwong's Avatar
Send a message via AIM to tjwong
Quote:
They do make a dual output BAP. http://kennebell.net/accessories/boo...boostapump.htm
tjwong is online now   Reply With Quote
Old 01-11-2010, 02:49 AM   #15
MachineWorks
CF Senior Member
Quote:
Originally Posted by tjwong View Post
I still wouldn't use it. Just do a triple 255 intank set up. Nice Try and i are doing a triple 255 intake setup soon on a C5.
Old 01-11-2010, 04:09 AM   #16
Supporting Vendor
For the C5 stuff, RSI (sponsor) has a nice assembly. Great vendor as well...
Old 01-11-2010, 08:07 PM   #17
NiceTry
CF Member
Send a message via AIM to NiceTry
Quote:
It is a nice setup, I checked it out. But I am going to sit down with my CNC shop and attempt create something similar but try to stuff a third pump in without going to the other tank.
NiceTry is offline   Reply With Quote
Old 01-11-2010, 08:41 PM   #18
Gannet
CF Senior Member
St. Jude Donor '06
Gannet's Avatar
After looking some more at (what little) is published about these systems, and talking quite a bit with my mechanic, I am leaning towards having him build a surge tank system. Anybody else have one?
Old 01-12-2010, 02:08 PM   #19
Louis @ LG Motorsports
Louis @ LG Motorsports's Avatar
Louis @ LG Motorsports is offline   Reply With Quote
Old 01-12-2010, 03:19 PM   #20
0Steve@AandACorvette
Former Vendor
Location: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
AACorvette AandACorvette
Send a message via AIM to Steve@AandACorvette
Our system is boost controlled with a Hobbs switch. When you hit 5 psi, the pump comes on. When your at 5 psi you are going to hear the motor and the exhaust over the pump. When you are at idle and cruising around town, the external pump will not be on.
Steve@AandACorvette is offline   Reply With Quote
Reload this Page Living with a "high end" fuel system
Tags
boost, controled, corvette, hobbs, living, switch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
