Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-08-2010, 07:57 AM   #1
Gannet
CF Senior Member
St. Jude Donor '06
Support Corvetteforum!
Gannet's Avatar
Default Limits of stock fuel system + BAP + Racetronix, limits of D1?
What's the upper limit of RWHP the stock fuel system (not injectors, obviously), supplemented by a Kenne-Bell 40A Boost-A-Pump and a Racetronix pump harness, can support?
The same question for the D-1SC head unit?
"Support" means for at least the standing mile.
Gannet is offline   Reply With Quote
Old 01-08-2010, 09:28 AM   #2
excessive81
CF Senior Member
excessive81's Avatar
Send a message via Yahoo to excessive81
there really is no good answer. each setup is so diffrent. for my stock ls2 i was able to make 8psi boost before it was an issue. then it is a snow ball effect if you want more boost/power. if you can run 60# injectors most the time you will be okay with bap. after that....not so much lol
excessive81 is offline   Reply With Quote
Old 01-08-2010, 10:32 AM   #3
ZO6er
CF Senior Member
ZO6er's Avatar
With my setup I had 750whp and the pump was hating life, I think to get to 800-850whp might work but not sure if the pump would last. I would not want to chance it though. Install the APS twin pumps and crank up the boost a little more, I was around ~10#.
ZO6er is online now   Reply With Quote
Old 01-08-2010, 11:30 AM   #4
BADZ
CF Senior Member
BADZ's Avatar
I made 760 rw with a bap and 60 lb inj. that came in the ecs kit as this was with 10#. This was using my stock fuel system and the items listed above.
I would run a twin pump setup.
BADZ is offline   Reply With Quote
Old 01-08-2010, 11:38 AM   #5
aTX427
CF Senior Member
St. Jude Donor '09-'10
aTX427's Avatar
I was making 750rwhp on an LS2 pump with a KB BAP, 60# injectors and a heavy dose of methanol. Maybe Taylor or Jeremy will jump in because they have more experience running the mile. My concern with the stock fuel pump is having it over heat on such a long WOT pull like the mile. Standing mile builds are a bit different than building for 9-10 sec 1/4 mile runs.
aTX427 is offline   Reply With Quote
Old 01-08-2010, 12:17 PM   #6
Louis @ LG Motorsports
Premium Supporting Vendor
Louis @ LG Motorsports's Avatar
Depends on how much you pad it with Meth
I hate BAPs, but they are popular...
Louis @ LG Motorsports is offline   Reply With Quote
Old 01-08-2010, 12:24 PM   #7
wooden
CF Senior Member
wooden's Avatar
I was running out of fuel with 675 rwhp with meth injection, i was able to turn up the meth and compensate. I am going duel pumps.
wooden is offline   Reply With Quote
Old 01-08-2010, 01:37 PM   #8
QwikC
CF Senior Member
QwikC's Avatar
The following, compliments of tjwong...
POST 2 tjwong: ...If so the BAP should be plenty adequate for what you have. Make sure that its wired right and its getting adequate power and that the wiring is sized properly. I have installed several of Andy’s kits and never had a problem with fueling, especially with the BAP added.
If you are slightly modded, then just go with a Z06 replacement fuel pump module. It is a drop in and I can personally tell you that the Z06 pump will support over 750hp without the aid of a BAP, I don't recommend it but I know it will as I personally tested it and it will fuel for 750+ rwhp.
Fueling with the stock style pump will be much easier, less complex and much more reliable.
Reference: http://forums.corvetteforum.com/c6-f...harged-c6.html
Naturally as everything in life , individual results may vary.
QwikC is offline   Reply With Quote
Old 01-08-2010, 06:43 PM   #9
Slvr08Z51
CF Senior Member
Slvr08Z51's Avatar
I run 710rwhp with a KB BAP, been running that hp for 8k miles.. No problems..
Slvr08Z51 is offline   Reply With Quote
Old 01-08-2010, 07:30 PM   #10
Taylor@DallasPerformance
Supporting Vendor
Taylor@DallasPerformance's Avatar
Quote:
I respect Tom as a diligent tuner and intelligent guy in general. With that being said, this statement has just not been my experience.
I have data/logs that proves that the stock Z06 pump can not maintain correct fuel pressure past 700rwhp WITH a BAP. I'm not talking about just one car. I've tested dozens of cars on the dyno and logging fuel pressure. You can keep making power past that but you will in the 40PSI or LESS range. If you were tuning for 13:1 AFR it wouldn't be so bad but it will never live with FI.
700-725 rwhp is the borderline safe limit with a BAP and the RX harness.
We have made some big power on the stock fuel pump (both Z06 and non-Z) and I cringed with every dyno pull...
__________________
Taylor Sims
www.DallasPerformance.com
214-349-1300
Taylor@DallasPerformance is offline   Reply With Quote
Old 01-08-2010, 07:36 PM   #11
PELONSZ06
CF Senior Member
PELONSZ06's Avatar
Quote:
same hur with a D1SC @ 6psi
PELONSZ06 is offline   Reply With Quote
Reload this Page Limits of stock fuel system + BAP + Racetronix, limits of D1?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
