01-02-2010, 09:05 PM
CF Senior Member
pulley changes on Maggie
I have the stock pulleys on my maggie set up. I making 5lbs of boost. I want more! Has anyone changed to a smaller size? What effect did it have on boost. Where did you get them? Any relationship between boost and HP. In other words 1lb of boost adds ___ HP.
Rod
01-02-2010, 09:36 PM
CF Senior Member
St. Jude Donor '06-'09
1 lb. of boost will make approx. 10 or so rwhp.
I have a 2.8" pulley on mine,if Yours is stock,it should be a 3.4",,get a 3.0" if You can find one!
01-05-2010, 08:59 PM
CF Senior Member
Quote:
Originally Posted by
1bdasvt
How much boost are you making?
01-05-2010, 09:07 PM
CF Senior Member
sea six
9.90 with a 2.8" pulley and meth.
01-05-2010, 10:49 PM
CF Senior Member
I would suggest a 3.0". This will make~7 lbs of boost with headers (that's what I'm at). I would not spin a M112 any faster. Reichard Racing makes excellent pulleys, if you can find one. You can also purchase from Magnacharger.com
01-05-2010, 10:56 PM
CF Senior Member
You will also need a 103.7" belt and a retune with that 3.0 pulley.
BTW: Hi George...........
01-06-2010, 06:42 PM
CF Senior Member
Thanks guys. What HP are you making at 7lbs of boost?
Rod
01-06-2010, 06:54 PM
CF Senior Member
550 rwhp/520 rwtq on a A6 transmission......no methanol
01-07-2010, 12:02 PM
CF Senior Member
STEVE!!!!!!
How it going,,,,,hope all is well!!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
