Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-02-2010, 06:12 PM   #1
ScottJ03
CF Senior Member
ScottJ03's Avatar
Default Cars w/ twin turbos...
Do you ever run trackdays? Any over heating issues. What brand and how many pounds of boost with a stock bottom end.
Scott
ScottJ03 is offline   Reply With Quote
Old 01-02-2010, 06:36 PM   #2
ZZMike
CF Senior Member
  • No
  • No
  • One Day
ZZMike is offline   Reply With Quote
Old 01-02-2010, 08:14 PM   #3
kmthor00
CF Senior Member
kmthor00's Avatar
No
No
APS 8lbs
kmthor00 is offline   Reply With Quote
Old 01-02-2010, 11:24 PM   #4
z06801
CF Senior Member
z06801's Avatar
to all above, drag race or road course
z06801 is offline   Reply With Quote
Old 01-03-2010, 11:28 AM   #5
TurboLX
CF Senior Member
Yes
No, but I added Swain Tech Coating to all hot parts
APS, 5.5psi makes 600rw on a stock LS3
__________________
Greg Banish
Calibrated Success, Inc.
TurboLX is online now   Reply With Quote
Old 01-03-2010, 12:55 PM   #6
wewing
CF Senior Member
wewing's Avatar
Yes, I run at VIR (road course for those who haven't been), and I have an APS turbo kit, and run 8psi and no alcohol.
Yes, I have a heating problem on the track, but only in the summer. I get to 300 degree oil temp after 20 mins on track, but boy its a fun 20 mins, then I take it a little easy and the temp drops, so no harm no foul.
Yes, I have a stock bottom end and a stock radiator with no oil cooler, and I plan on putting a Dewitts radiator with oil cooler in the car to fight the heat. It should work, we'll see.
One interesting note is that the plastic ribbons on the oil supply lines to the turbos have melted, but only in the last inch or so from the turbo, so that is a good indication of how hot and how far the heat seems to be propagating from the turbo.
wewing is offline   Reply With Quote
Old 01-03-2010, 01:06 PM   #7
atomicfusion
CF Senior Member
Support Corvetteforum!
atomicfusion's Avatar
Do you ever run trackdays? Drag only
Any over heating issues. Not how we run... Can run True street fine
IPSmotorsports.net
Never ran it on a stock bottom end... but run 17-21lbs depending on how fast we want to go.
atomicfusion is offline   Reply With Quote
Old 01-03-2010, 04:49 PM   #8
ScottJ03
CF Senior Member
ScottJ03's Avatar
Default Thanks for feed back
I have plenty of bottom end with 3.15 gears.
Wanted to stay NA but CARB sucks A$$.
So I thought turbo with the power kicking in later and growing would be the ticket.
But I want to be able to run for 30 min sessions on Track days Road Coarse...
This is why I was thinking turbo instead of SC....
Do SC get hotter than TTs?
Thanks again,
Scott
Old 01-03-2010, 08:40 PM   #9
Z06wanted
CF Senior Member
Z06wanted's Avatar
TTIX here
Drag race only
Oil cooler
9psi 708rwh LS3 418
Z06wanted is offline   Reply With Quote
Old 01-03-2010, 09:57 PM   #10
wewing
CF Senior Member
wewing's Avatar
As far as turbo power kicking in later, thats not the case. Ball bearing turbos spool up fast, and on the track, they're always spooled anyway. The biggest thing about turbos on the road track is that the blow off valves tend to open close abruptly, so you have to modulate that with your foot a little more carefully. The car's power is almost on and off like a light switch.
As far as turbos or SC being hotter, I don't know. I do know that my friends with SC cars seem to have belt problems on the track. At least with turbos that is a problem I don't have.
Old 01-04-2010, 09:00 PM   #11
aTX427
CF Senior Member
St. Jude Donor '09-'10
aTX427's Avatar
If you are going to do a lot of track days, NA + displacement works best.
aTX427 is offline   Reply With Quote
Old 01-05-2010, 08:41 AM   #12
chuntington101
CF Senior Member
Has anyone seen or used Inconel blankets/shields to help keep heat down under the hood???
these guys do it. http://www.atpwrap.com/html/alloyracing.html
and there a a guy with a Trubo 240Z that says they are very good. http://forums.evolutionm.net/evo-eng...-blankets.html
He is also using like an Ally bag on the coldside to help keep that cool. Might be usefull to!
Chris.
chuntington101 is offline   Reply With Quote
Old 01-09-2010, 06:16 PM   #13
zo6landrocket
CF Senior Member
zo6landrocket's Avatar
This stuff looks like it would work. Anybody here use this brand?
zo6landrocket is offline   Reply With Quote
Old 01-16-2010, 07:32 PM   #14
C6 Twin Turbo
CF Senior Member
C6 Twin Turbo's Avatar
APS twin turbos
I do some hpde events at a couple different tracks. I had some heat issues with the car in an auto. I had RPM chnge my c6 to a m6 transmision and added a louvered hood. oil and water Temps have been better since.
I do agree with keeping the car N/A if you want to do alot of road tracks.
C6 Twin Turbo is offline   Reply With Quote
Reload this Page Cars w/ twin turbos...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tomorrow, i hope to set some new records! LIMEY C4 ZR-1 Discussion 247 08-10-2005 01:17 AM
*editorial* My Turbo observation ICULUKN-C5 C5 Forced Induction/Nitrous 94 12-14-2004 03:57 AM
is the stock c5 catback restrictive after a certain HP level? or purely for audio pleasure? TT_Vert C5 Tech 18 02-22-2004 10:47 PM
OT: I just got PUNKED by a '96 Porsche 993 Twin Turbo.... Corey_68 C3 Tech/Performance 38 02-21-2004 05:19 PM
UPDATE ON 95 LPE ZR1 TWIN TURBO NO. 3 OF 4 NORM KOERNER C4 ZR-1 Discussion 144 01-09-2002 05:12 PM
{CALLAWAY}Dyno #'s on a bone stock B2K w/in> *89x2* C4 ZR-1 Discussion 60 11-02-2001 01:48 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
