I just added about 3.5 lbs of boost = total of 9.8-10lbs of boost at WOT
the specs for my car are: LS3, 1 3/4 headers, catless, cam (223/240 .610 112 LSA) PISC with a 4 inch pulley, dallas big mouth intake
Running on 91 octane fuel with no meth
before I pullied down I had a peak RWHP 618 with no knock and really no issues with 6.5 lbs of boost.... So I decided to add some boost and now I could only get an extra 30 HP (645 total) from over 3 lbs of added boost - and in the process I am now seeing knock and my timing is getting pulled. I expected better numbers - but the engine is cooperating.
how can I spot false knock from extra noise due to the added boost vs the real thing?
3.5lbs is not little, and it seems the car wasnt tuned after the pulley swap - at least you made it sound that way. Check ur AFR for starters make sure its in the low 11's, and work out the timing until you stop seeing any knock. Knock pulls a good deal of timing and can lower you're max power. Lower timing and NO knock retard will likely result in higher HP.
But again, 91 octane and 10psi of boost? people usually run meth with that kind of boost/cr/fuel, the LEAST thing you can do is switch to 93, and tune it for 93.
-the meth kit might be an option, I just wanted to make it a daily driver and not worry about an additional system
-I was wondering about false knock because it wasnt seen before the addition of boost...but as stated the added boost added heat, so that might be the issue
-the shop has some limited experience with boosted LS engines...but not much...thats why I am asking questions to learn
---> final question - I had a procharger big red valve installed on my intake pipe right before the MAF...could that be causing any problems?
Reason: add
before the MAF is fine, anything between the MAF and throttle body will cause an issue.
Again, its not simply a heat issue, the more boost you run the less timing you can run. with a high comp ratio engine, and that much of boost on 91 octane, how much timing are you running? Ill bet its VERY low.
youd probably gain 50+ rwhp with the meth kit and ur current boost, set it to kick in at 6.5psi whihc should be at around `4500rpms?
thanks for the info!
I believe am at 11degrees of timing...does that sound right?
I might just move over to meth kit...thinking about it
If you use the washer tank (whihc is rather large on the C6) and leave the low fluid sensor plugged in you should not run into any problems running the meth, remember its only spraying a small amount when you are above the preset level therefore lasting quite awhile.
There is a bit more to it than that, but that's a good start!
Ya I know, I think most people think they are going to go through it like they go through gas and have to fill it up all the time which kind of scares them away from it, which isnt the case.
Been through 7 gallons in 2 mos!! My daily went down so I've been beating the hell out of the Vette!! Actually made 4 180+ pulls today!! Had to show a HPF Stage 3 M3 whats up!
