Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2009, 08:58 AM   #1
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Default Z06 Rear diff and Tremec T56 Tranny
At what rwhp and or torque do you need to start upgrading these two things and what exactly needs to be upgraded? Input shafts, output shafts etc?? whats the threshold. thanks guys
Fast06Z06 is offline   Reply With Quote
Old 11-20-2009, 12:31 PM   #2
carlrx7
CF Senior Member
St. Jude Donor '08-'09
2006 Chevrolet Corvette
carlrx7's Avatar
the amount that your shooting for is probley enough to justify some beefin up.. level IV-V tranny and III-IV for the diff.
carlrx7 is offline   Reply With Quote
Old 11-20-2009, 04:27 PM   #3
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
Yea but what if I keep it around 800 850 rwhp for now and no power shifting and no hard launches
Just rolling starts what would they hold before failure from brute torque?
Old 11-20-2009, 04:38 PM   #4
PELONSZ06
CF Senior Member
PELONSZ06's Avatar
Hey bro ive had my C6Z06 runnin 840rwhp for about 5k miles with sum hard launches and roll racin and rearend still holding up together, their pretty stout..for now
PELONSZ06 is offline   Reply With Quote
Old 11-20-2009, 04:44 PM   #5
Robls6
CF Senior Member
Robls6's Avatar
I snapped the output shaft clean off on my 07 MN6 last summer. This was on the street with the run crap tires and only 570RWHP. Anything can happen.
Robls6 is offline   Reply With Quote
Old 11-20-2009, 04:47 PM   #6
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
Must have had some wheel hope or gotten shocked.
Not a Z TRanny though then
Old 11-20-2009, 04:50 PM   #7
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
Tranny still stock too? How much torque are you running?
Thats 840 though runnin the shot so its not all the time.
Old 11-20-2009, 04:52 PM   #8
Mr.Big
CF Senior Member
Mr.Big's Avatar
broke my sh*tty 2005 rearend at a little over 400rwhp, and then after we beefed it up all was fine until 700rwhp, and that was the magic number for stock tranny, and more rearend issues... so I'd say you are on borrowed time, drive'r hard till she breaks...
__________________
Jeremy
Dallas/Valley Ranch Tx
805rwhp 700rwtq Boost Only
D.P. F1C @ 15psi, N2O, ALKY Control Dual, Dallas Performance fuel system, A&A bracket, Dynatech Headers, Borla Stingers, WCCH 317's, ECS Blower cam, ECS 8rib, FAST Intake, HPTuner, D.P. C5 rearend w/3.15's, Mcleod "sintered" twin...
Mr.Big is offline   Reply With Quote
Old 11-20-2009, 04:55 PM   #9
BADZ
CF Senior Member
Support Corvetteforum!
2007 Chevrolet Corvette
BADZ's Avatar
You should be fine bro. If your thinking about replacing something, replace the diff. output shafts and half shafts.
BADZ is offline   Reply With Quote
Old 11-20-2009, 04:58 PM   #10
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
Is that what you did?
Old 11-20-2009, 07:44 PM   #11
MachineWorks
CF Senior Member
MachineWorks's Avatar
Quote:
Thats what I did. Can't make them amy stronger, just shift smoother. You can also put the stiff diff mounts on.
MachineWorks is offline   Reply With Quote
Old 11-20-2009, 07:54 PM   #12
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
Wouldnt the cushion better or does it cause it to distort? Who makes the stiff or solid mounts?
Old 11-21-2009, 03:16 AM   #13
Black730
Forged
Quote:
What part of your stock tranny broke? Was it a T56 or TR6060? And what have you done to it to support your new 800rwhp.
I've got a stock z51 TR6060 using a hardened mainshaft running to a zr1 differential. I'm wondering how well the tranny is going to hold up, especially with the z51 gears.
__________________
Dallas Performance build in progress:
HKE 416, DP F1C Procharger, Callies Crank & Rods, Hard Anodized Diamond Pistons, Full Grandsport Widebody, Z06 Brakes, RPS Triple Carbon Clutch, ZR1 Transmission & Differential, DSS Axles, Pfadt Coilovers & Trans Mount, DP Big Mouth Intake, American Racing Headers, DP Dual Meth Injection, DP 1000hp Fuel System, DP 8 Rib Flip Drive, DP Custom Blower Cam, B&B Fusion Exhaust, Custom 3.5" Propshaft, Tint, CCW C10s w/ MTs, Vossen VF-061s w/ Invos
Black730 is offline   Reply With Quote
Old 11-21-2009, 01:08 PM   #14
Spying Beast
CF Senior Member
Spying Beast's Avatar
I just upgraded from the stock 05 trans & diff to a Z06 set-up @ 650 WHP. I'll let you know if something goes bad.
I've upgraded the trans mounts to harder stuff, and replaced the suspension to Pfadt Coilovers in hopes of eliminating the chance of wheel hop.
I hope this holds up for a while. At the very least, it's far better than the stock 05 stuff...
Spying Beast is offline   Reply With Quote
Old 11-22-2009, 08:30 PM   #15
Robls6
CF Senior Member
Robls6's Avatar
No wheel hop. It broke in 1st gear from a roll at a stop light. It's wasn't a Z06 trans. It's a T56. I went with an RPM Stage 5 and haven't had any problems since.
Old 11-22-2009, 08:53 PM   #16
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
A Tremec T56 is what IS in a 06 Z. Just has some beefed up internals over a stock T56......
Nice to hear your problems are done. What kind of power are you making now?
Old 11-22-2009, 09:38 PM   #17
Robls6
CF Senior Member
Robls6's Avatar
Oops. You're right. I'm only making 570RWHP. I had the trans installed at RPM last spring and had them do the hardened single piece axles on both sides while everything was apart. Rodney personally disassembled and re assembled my diff. I still have the stock LS7 clutch so I was really surprised I broke anything in the first place. That clutch grabs pretty well actually.
Old 11-22-2009, 11:26 PM   #18
aTX427
CF Senior Member
St. Jude Donor '09-'10
aTX427's Avatar
I am probably going to do a RPS triple carbon carbon, ZR1 trans and diff with hardened axles. It's big bucks though - figure $15k
aTX427 is offline   Reply With Quote
Old 11-23-2009, 05:53 AM   #19
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
.....seems there are better alternatives to get to the same goal for much less no..
Old 11-23-2009, 08:51 AM   #20
Black730
Forged
I just about went the same way with the zr1 differential, DSS axles, and RPS triple carbon clutch.
The only difference is I'm just using my stock TR6060 z51 transmission with a hardened mainshaft. We'll see how that holds. Not sure if I'd go to the zr1 diff if it fails, but I'm not sure what my other options are next to an automatic conversion.
If you are going to go all out like that, you might as well strengthen your driveshaft too.
__________________
Reload this Page Z06 Rear diff and Tremec T56 Tranny
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
