Alright Guys..... I am back again with some great results!
I received my motor on 11/06/09 at 5 p.m pulled an all nighter and had her running at 11/07/09 6:15 a.m. After so much hard work and time spent on my car "Satans Zo6" is back to life! I got to drive her home at 5 P.M after finishing all my customers cars... as promised
Details :
I tried my best to work out that RHS Block but it just did not fit my time period! After 3 weeks of hearing we will receive the block this week I decided to go with the Warhawk...... I Like High revs and as I said this has to be a "budget Build", so we went with the short deck "454" end results were Incredible...although I did run out of Fuel Injectors "max Duty" and MAF Sensor...BUZZ KILL! Car maxed out at 593 RWHP and 535 TQ...... I was also running cats! She asks for more fuel starting at 5700 rpm so we know these numbers will be much higher once everything is complete
I will replace the MAF sensor and the fuel Injectors as well as knock out the stuffed cats! I will need a 102 ported fast as well since I am not getting enough air in :/ . The car is also on the smaller ... "More streetable cam" which cost me a 40 Hp drop to the flywheel..... She is incredibly FAST!!
Special thanks :
I would Like to thank Chad @ "Golen Engine" Man behind his word! Also the man that covered 2 cam swaps and ate the cost of them because he wanted to go the extra mile as I like to do my self and only work with those who do!
I would Also like to thank Mike and Tad @ "Haddad Motor Sports" For taking their time and putting in that fine tune! Thanks for the colder plugs MIKE! "GIFT"
Specs:
1.Warhawk block
2.Magnum crank
3.Diamond "coated" Pistons & upgraded Pins and oilers 12:1
4.Callies I beam rods
5.Custom Billet Camshaft
6.Ported LS7 Heads,Intake Manifold, and TB
7.Aviad windage tray & tank insert
8.RPS STREET TWIN LIGHT
9.Aluminum Torque Tube Bushings
10.Talent Motor Sports Built Transmission
11.Strengthened out put shafts for the differential
12.Heat wrapped Kooks 1 7/8 Headers, catted X pipes and stock Zo6 exhaust with "Muffler Mod"
SLIDE SHOW :
I will be back on this post Hopefully soon.....I unfortunately am Only 19 with Bills over your head
and am not made out of money or have parents supporting my build so i will try my best to get back with the Maf since Joel has supported me with Injectors.... I would also like to thank this man
....... Until then hang in tight for higher Numbers expected
Once N/A Set up is complete...........We will then introduce a nice Nano Nitrous System to "Satans Zo6" and watch her
our competitors and run
around them and then
at them and tell them they have
chance and make me look
and now im about to
"ROLL OUT" ENJOY
