Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-19-2009, 09:48 PM   #1
wanalooz
CF Senior Member
Default Nitrous Experts Help!
I have my 06 z06 at a shop, installing a wet direct port nitrous system on my built engine. Is there anything I should mention to them before the install is complete.( If it was your car, what would you make sure was not left out)
Timing? Colder plugs? Run rich? Cylinder #7 should have a larger fuel jet?Progressive?Fuel?Safety?
Help me out,
Thanks Ed
wanalooz is offline   Reply With Quote
Old 11-19-2009, 11:15 PM   #2
Drewstein
CF Senior Member
Drewstein's Avatar
Help me out,
Thanks Ed
Well you'll need the proper plugs, and a proper tune checked with a wide-band at least. I would personally make sure the car had a window switch on it as well as a fuel pressure safety switch.
My question to you would be; Why doesn't the shop installing the kit know this stuff already? That would be my concern.
Drewstein is offline   Reply With Quote
Old 11-20-2009, 08:02 AM   #3
wanalooz
CF Senior Member
I'm sure they do, I just want to make sure we don't miss anything. I am installing every gadget and safety item I can think of, any input is much appreciated.
Old 11-20-2009, 08:19 AM   #4
Mr.Big
CF Senior Member
Mr.Big's Avatar
one addition to the setup you've decided on, add a NANO assist, instead of a b.s. Heater...
__________________
Jeremy
Dallas/Valley Ranch Tx
1070+rwhp930+rwtq Boost ONLY
Dallas Performance custom F1R system, D.P. Forged 370, ALKY Control/D.P. Triple nozzle, D.P. E85 fuel system, Wilson Billet intake, D.P. Direct Drive + 10rib, WCCH 317's, D.P. Blower cam, HPTuner, D.P. '09 rearend, TR6060, Mcleod "sintered" twin, THANKS to www.dallasperformance.com
Mr.Big is offline   Reply With Quote
Old 11-20-2009, 09:23 AM   #5
wanalooz
CF Senior Member
Lsx intake, nano, progressive controller, direct port, dedicated fuel system, blow outs, gauges,blow down tube, purge, carbon fiber bottle, opener, filters, fuel rails, tires, 200-250 shot, hoping to break 9.99. If I left something out please add to the list.
Old 11-20-2009, 10:23 AM   #6
Drewstein
CF Senior Member
Drewstein's Avatar
What I said above -
Window switch
Fuel pressure safety switch
Plugs
Tune checked with a wide-band
GL on the quest for 9s
Old 11-21-2009, 02:13 AM   #7
Nitro Dave
CF Senior Member
Sounds like you have a pretty good idea. Needing a larger fuel jet in number 7 should be determained by reading the spark plugs. I would not suggest using a larger fuel pill and not actually varifying by the plug its right.
Main things to concider other than parts area.
Fuel delivery, Airfuel, spark plug choice, timing.
Dave
Nitro Dave is offline   Reply With Quote
Old 11-21-2009, 10:16 AM   #8
wanalooz
CF Senior Member
Thanks Dave thats good to know about fuel jet in number 7, thanks for the feed back.
Ed
Old 11-21-2009, 03:31 PM   #9
J HEBERT
CF Senior Member
Support Corvetteforum!
J HEBERT's Avatar
#7 will become less of a concern if u provide a coolant cross-over and tee in to the cross-over in the front. The #7 issue lies in coolant cavitaion/flow for the #7 cyl, NOT in airflow making that cyl. lean. Jetting #7 fatter helps, but is the band-aid IMHO
J HEBERT is offline   Reply With Quote
Old 11-21-2009, 03:37 PM   #10
J HEBERT
CF Senior Member
J HEBERT's Avatar
Quote:
Good suggestion, but that bottle too will need filling, I will sometimes use 2 bottles tee-ed together both heated, this way we still have over 900psi at the end of the pass in high gear. NANO is very sweet though..
Old 11-21-2009, 08:33 PM   #11
wanalooz
CF Senior Member
Thanks for all your info, who has the largest shot on a stock ls7 block, I heard that the 211 Texas mile guy has a 300 shot, is that the largest to date?
Old 11-22-2009, 09:16 PM   #12
gotjuice?
CF Senior Member
gotjuice?'s Avatar
The Texas Mile guy is Mike Z. He had two kits, a plate and a stand alone direct port. I think it was total 350 shot, but I am not for sure.
gotjuice? is offline   Reply With Quote
Reload this Page Nitrous Experts Help!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Quick look at the new F.A.S.T. throttlebody tbyrne C5 Tech 25 12-12-2003 01:31 PM
Cam experts, help me decide on a Cam for my '86. Mr. Magoo C4 Tech/Performance 39 06-12-2003 07:42 PM
HUGE Cubic Inch LS1 questions inside?? Experts please. 454 inch LS1!! Mike TexaSS C5 Tech 43 05-03-2002 11:24 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
