11-20-2009, 01:22 AM
CF Senior Member
Someone else can chime in but I do believe that their LS1/LS6 system will work on any LS style motor including the LS3. Their nozzles go into the intake where your fuel injectors go and then your fuel injectors go into the nozzles. I dont think there is a difference in injector size as far as the part that goes into the intake is concerned for any LS motor. They might provide the way, but you will need to be able to raise and mount your fuel rails and injectors up higher with spacers or something.
