Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-18-2009, 09:40 PM   #1
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Default V2si- Smallest pulley size ran and outcome
What is the smallest pulley size people have ran safely and the outcomes as far as power. Seems no one has really pushed the limits of the V2si and just opted to upsize to T trim, Ysi etc.
Fast06Z06 is offline   Reply With Quote
Old 11-20-2009, 05:42 PM   #2
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
Bump anyone?
Old 11-21-2009, 01:15 AM   #3
carlrx7
CF Senior Member
St. Jude Donor '08-'09
carlrx7's Avatar
why go T when you can go YSi? lol
i, myself am gonna try and for a 3.4 pulley after a blower cam to keep the psi up
carlrx7 is offline   Reply With Quote
Old 11-21-2009, 08:05 AM   #4
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
No I have the V2si and was gonna stay with it for now, but ended up buying the Ysi last nite anyways
I am still curious though whats the smallest people have run without loosing power on top.
Old 11-21-2009, 09:15 AM   #5
carlrx7
CF Senior Member
carlrx7's Avatar
ill let ya know some time next year. but i think with gears and drags im gonna reach my goal
Old 11-21-2009, 11:22 AM   #6
aTX427
CF Senior Member
St. Jude Donor '09-'10
aTX427's Avatar
I don't think you will find a definitive answer since safe is a relative term and I cannot remember if your engine is forged. If it is, you can pulley it down until you max the blower, if not 8lbs would probably be the max I would go with any kind of longevity. The increased heat on a NA spring pack is the killer. They are gapped smaller than blower cars and have the tendacy to close the gap under extreme heat. When that happens, the piston sticks and breaks - game over. That is what happened to me at 10lbs / 600hp, so I can tell you that it was not safe, although I was looking for an excuse to build a forged engine.
aTX427 is offline   Reply With Quote
Old 11-21-2009, 11:28 AM   #7
setxws6
CF Senior Member
setxws6's Avatar
If you go to Vortech website, they have an impeller speed calculator. LS2 stock crank pulley is 7.5in diameter, with a blower 3.4 pulley at 6500rpm is just under the recommend max rated impeller speed for the V2 or V3 si models. But you can alway overspin it. So if you really wanted to push it hard, over spin it with a 3.2 or 3.0 pulley or go with an 8 inch crank pulley.
setxws6 is offline   Reply With Quote
Old 11-21-2009, 12:10 PM   #8
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
Yea already went through all that I would be 10k overlimit recommended at a 7k redline with a 3.25 8 rib pulley. Looking for real world experience though..
Doesnt matter now though because I ordered a Ysi from Andy last nite. But I am still curious to see what others with similar combos are running. Thanks
Old 11-21-2009, 12:35 PM   #9
setxws6
CF Senior Member
setxws6's Avatar
MRBIG made 781rwhp with his P1sc which flows the same CFM as Vortechs T-trim V2 models, but this was overspinng some. I think a V2si would probably make around 700rwhp before having to overspin it. And a V2 t-trim could probably make roughly 750rwhp before overspinning it.
Old 11-21-2009, 10:21 PM   #10
Rock'n Blue 08
CF Senior Member
Support Corvetteforum!
Rock'n Blue 08's Avatar
Good job! I have the 3.8 pulley and 9psi plus boost with a V-3 with more than 578rwhp and 530rwtq. So the 3.4 is two steps smaller. I would change pulleys but since the addition of A&A's new intake. I feel I'm over 600 rwhp and still safe. I'm going to stick with the 3.8 I'm more than satisfied! I think the V-3 is plenty big since I can go
two sizes smaller pulley yet. While still being in the sweet spot as far as efficiency (78 percent)
Rock'n Blue 08 is offline   Reply With Quote
Old 11-22-2009, 01:24 AM   #11
setxws6
CF Senior Member
setxws6's Avatar
I'd keep it there Rockn. If you go any further, you'll start pushin' it. If you keep it there you'll be safer for longer.
Reload this Page V2si- Smallest pulley size ran and outcome
Tags
30, 32, 34, impeller, max, maximum, p1sc, pulley, smallest, speed, spin, spinning, v2si, v3, v3si, vortech
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
