Manifold has hvi [high velocity] ports that are restricted in a vee shape. Not all are like this but the Camaro kits are. Simple to grind out as it is only at the port match area.
Manifold pressure was monitered in kpa instead of psi. 100 kpa=1bar or about 14.5 psi. Altitude fuddles are the numbers but the dyno run 56 would have been 8.8 psi boost vs. 9.4 for run 50. I can speed the blower up about 5% more safely which I plan to do but will not get close to the boost levels of guys at sea level.
Waiting for news on your animal.
