Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-12-2009, 07:28 PM   #1
adam205348
CF Senior Member
Send a message via AIM to adam205348 Send a message via MSN to adam205348 Send a message via Yahoo to adam205348
Default Water Cooled Turbo Setups
For you guys running GT35Rs or any other turbos that are setup for water cooling and actually have it hooked up. Where are you getting the water from and having the water return back to. I know APS has their setup that they say you pull a Freeze plug and put in one of their adapters to get the water and then return it back to the head which is what I was planning on doing. But I cannot find the fitting that they use. So I am wondering where else you can get the water from and return it back to?
The fitting they provide with their setup is as follows.
28mm x 1.25 x 9/16 JIC the JIC part is a -6 AN fitting
This is the fitting if anyone happens to have one.
adam205348 is offline   Reply With Quote
Old 11-12-2009, 08:08 PM   #2
07MontRedcp
CF Senior Member
Support Corvetteforum!
07MontRedcp's Avatar
Did you try Summit Racing?
BJK
07MontRedcp is offline   Reply With Quote
Old 11-12-2009, 08:22 PM   #3
adam205348
CF Senior Member
yeah nothing has come up, i havent called them yet so i might do that tomorrow. I have called all the local hose, pipe, and fitting companies around figuring if anyone had it they would and no luck. Looks like APS had these custom made for them. TTI says you can order their kits with water cooled turbos, does anyone know how they get water to them and what fittings?
Old 11-12-2009, 09:53 PM   #4
Taylor@DallasPerformance
Supporting Vendor
Taylor@DallasPerformance's Avatar
It's as simple as removing the plug and welding on a -6 steel AN bung. Done.
__________________
Taylor Sims
www.DallasPerformance.com
214-349-1300
Taylor@DallasPerformance is offline   Reply With Quote
Reload this Page Water Cooled Turbo Setups
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Anyone Looking To Build a Twin Ballistic BallBearing GT Turbo Kit LB C5 Forced Induction/Nitrous 69 04-14-2002 06:19 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
