Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-11-2009, 11:31 AM   #1
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Default Most popular FI Fuel Setup
I have been researching all the different fuel setups for making 800-1000 rwhp. Seems like it comes down to A and As external pump setup, ECS, a home made setup using (aeromotive fuel rails, aeromotive boost references regulator, bosch or Aeromotive 1000 pump and lines and fittings, Twin Walbros ( in tank??? not sure on this one) and APS in tank unit.
Can you guys elaborate on the twin walbros and how you mounted them what other components it consists of.
Pros /cons.
Fast06Z06 is offline   Reply With Quote
Old 11-11-2009, 12:41 PM   #2
aTX427
CF Senior Member
St. Jude Donor '09-'10
aTX427's Avatar
Dallas Performance Fuel System here.
aTX427 is offline   Reply With Quote
Old 11-11-2009, 02:43 PM   #3
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
More info please. I dont see anything on their website for fuel systems.
Old 11-11-2009, 03:06 PM   #4
MachineWorks
CF Senior Member
MachineWorks's Avatar
Twin in tanks. Hands down! Cleanest and no loud race pump sound.
MachineWorks is offline   Reply With Quote
Old 11-11-2009, 03:16 PM   #5
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
More detail please any photos?
Old 11-11-2009, 04:20 PM   #6
BADZ
CF Senior Member
Support Corvetteforum!
BADZ's Avatar
We will snap a photo once its done...
BADZ is offline   Reply With Quote
Old 11-11-2009, 05:27 PM   #7
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
Thanks.
Machine works where can you get these or is a DIY and you just need to buy the pumps and fit them in there on the factory fuel sender unit?
Old 11-11-2009, 06:12 PM   #8
aTX427
CF Senior Member
aTX427's Avatar
Quote:
I looked at them all and chose the DP Fuel System.
http://www.dallasperformance.com/DPC6fuel/index.htm
Old 11-11-2009, 06:43 PM   #9
carlrx7
CF Senior Member
St. Jude Donor '08-'09
carlrx7's Avatar
if your down with dropping the tank, then go for twin-in. if not, then the ecs fuel kit i what i like.
my .02
-carl
carlrx7 is offline   Reply With Quote
Old 11-11-2009, 07:19 PM   #10
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5&C6 609-752-0321
The problem with in tank twins from my experience, is that when you loose the canister, which the fuel is returned into, you create air rating problems. The canister keeps the fuel from sloshing around the pumps, and keeps a constant reservoir. When the pumps are dropped in without one, on a heavy launch, all the fuel slams the back of the tank, and your not getting constant fuel feed to the pumps.
The major problem with this is that you will still have fuel pressure on your gauge since air will compress, it just makes for inconsistent lean conditions when you need it most.
This is why we utilise our separate -8 feed, and -6 return block, which is mounted in the lower rear of the tank. The pump comes on under boost only, so there is no chance of you hearing anything other then what you did stock.
Our stage 1 can support 900+rwhp, and the potential to grow to 1200 hp+ is there with what you already purchased, just by increasing pump size and rails.
We have been utilising our system for many years now, and it has been more proven then any other system on this forum today. We have the personal experience to be able to tell you exactly when you will need to upgrade, and what is needed when you do.
I hope that helps save a few engines.
DOUG @ ECS is offline   Reply With Quote
Old 11-11-2009, 09:01 PM   #11
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Thanks Doug that is very valuable information and helps me make a better decision! Makes sense as all my old cars we always ran fuel cells with sumps so it never ran dry, a return line and jet extenders and notched bowls for when the fuel sloshed back in the carb it wouldnt bog. Once again for me just converting that to todays technology.
Old 11-11-2009, 10:43 PM   #12
Mr.Big
CF Senior Member
Mr.Big's Avatar
What I run... best offering out there imho...
__________________
Jeremy
Dallas/Valley Ranch Tx
1070+rwhp930+rwtq Boost ONLY
Dallas Performance custom F1R system, D.P. Forged 370, ALKY Control/D.P. Triple nozzle, D.P. E85 fuel system, Wilson Billet intake, D.P. Direct Drive + 10rib, WCCH 317's, D.P. Blower cam, HPTuner, D.P. '09 rearend, TR6060, Mcleod "sintered" twin, THANKS to www.dallasperformance.com
Mr.Big is offline   Reply With Quote
Old 11-12-2009, 08:24 AM   #13
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Thanks. Looks really nice.
Nice system but steep price. Is anyone out there running any home made setups. Any more pics of the A and A setup?
Old 11-12-2009, 09:47 AM   #14
RCC
CF Senior Member
RCC's Avatar
As with anything its better to do it right the first time, make even over doing it is better. If your attempting a 800hp+ the twin in tank pumps will work as long as you dont decide to go for more. I have twin walbros in a aps bucket in my tank, it ran out of fuel at 850hp. If thats your goal you will be fine, if not I would go to one of the many reputable dealers here and discuss your needs and they will take care of you. I like Dallas Performances setup, I dont use it but Taylor has always been very helpful. If you go with the twin in tank pumps and decide later you need more you can always do what the guys at LMR did for me- its crazy looking but it works. The in tank pumps feed the surge tank in the picture and the magnafuel 750 feeds the motor.
I will warn you though that route was expensive. So in my opinion I would spend the money now for a complete 1000hp fuel system.
RCC is offline   Reply With Quote
Old 11-12-2009, 10:22 AM   #15
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Nice setup Then it becomes for me that we keep adding more weight for this , more weight for that. I was ok with adding the SC and now using an LSX block but more weight for an additional tank....pretty soon its gonna outweight my diesel Thanks very much for the input. It all helps in my final decision
Old 11-12-2009, 04:53 PM   #16
ZO6er
CF Senior Member
ZO6er's Avatar
Tried and true, alot of 1K rwhp cars have been using this setup. I don't like the idea of going in the tank to change out any pump. Escpecially the way they are set up, it's a Biatch to get to. Just my .02 Good luck.
ZO6er is offline   Reply With Quote
Old 11-13-2009, 02:14 AM   #17
Black730
Forged
The Dallas Performance fuel system is a great system, and is rated to 1800hp. You could also save some money by going with their 1000hp system. That is what I'm going with.
__________________
936rwhp/932rwtq - Dallas Performance Forged 416, F1R, Callies Crank & Rods, Diamond Pistons, ETP Heads, FAST 102, NW Throttle Body, Full Grandsport Widebody, Z06 Brakes, RPS Triple Carbon Clutch, ZR1 Trans & Diff, DSS Axles, Pfadt Coilovers, DP Big Mouth Intake, DP Boost By Gear, AR Headers, DP Dual Meth Injection, DP 1000hp Fuel System, DP 8 Rib Direct Drive, DP Blower Cam, B&B Fusion Exhaust, Dewitt Rad/Fan, DP 3.5" Propshaft, 4 Point Cage
Black730 is offline   Reply With Quote
Old 11-13-2009, 11:19 AM   #18
Louis @ LG Motorsports
Louis @ LG Motorsports's Avatar
Imitation is the purest form of flattery
That setup, is the ONLY way to go. Period.
__________________
Louis Gigliotti Jr. The next generation
'09 CG Z06
Stock
http://www.LGMotorsports.com
http://www.LGMRacing.com
972-429-1963
Louis @ LG Motorsports is offline   Reply With Quote
Old 11-13-2009, 12:21 PM   #19
DOUG @ ECS
DOUG @ ECS's Avatar
Quote:
There's a couple of venders on this site that know EXACTLY what you mean...
Old 11-13-2009, 12:32 PM   #20
We took our World challenge fuel system ( 4 pumps) and adapted it to the street cars
http://www.lgmotorsports.com/catalog...oducts_id=1971
Reload this Page Most popular FI Fuel Setup
Tags
1000hp, bigger, c5, corvette, ecs, external, fuel, line, magnafuel, pump, roadrace, setup, surge, system, tank, works
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Looking for N20 overview blu00rdstr C5 Forced Induction/Nitrous 9 07-19-2004 11:34 AM
C5 Supercharger gcvette C5 Tech 13 07-18-2004 10:53 PM
Turbo vs Supercharger (why are the turbos not at higher HP #s given similar boost/motor) QuickSilver2002 C5 Forced Induction/Nitrous 47 12-27-2003 02:39 PM
Could use a recommendation on Fuel System parts. Jaxian C4 Forced Induction/Nitrous 18 12-13-2003 08:56 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
