Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-10-2009, 07:59 PM   #1
mhoglund
CF Senior Member
mhoglund's Avatar
Default Maggie 122HH & RK Sport Hood Interference
Has anyone had a problem with the vaccuum actuator interfering under the hood? The vacuum actuator is the black canister that has linkage going to it. In lamens terms its the bypass when your driving normal. Mine is hitting so bad it cracked the paint on the outside. There goes my 3 color custom paint job...
mhoglund is offline   Reply With Quote
Old 11-10-2009, 08:20 PM   #2
1bdasvt
CF Senior Member
St. Jude Donor '06-'09
Support Corvetteforum!
1bdasvt's Avatar
Mine has no problem
1bdasvt is offline   Reply With Quote
Old 11-11-2009, 06:45 PM   #3
mhoglund
CF Senior Member
mhoglund's Avatar
Well I'm waiting for feedback from Sicmotorsports and RK sport to see how they are going to address my problem. Still waiting....
Old 11-11-2009, 08:02 PM   #4
mhoglund
CF Senior Member
mhoglund's Avatar
I took it upon myself to call RK Sport directly. The person I spoke to basicly told me because they have tested thousands of hoods, the problem must be with my blower. That the biggest load of crap I have ever heard. My blower is the 122HH bought from Magnuson! As its not bad enough that I will have to cover the painting of a new hood which is going to cost somewhere near $1000.00 because the color scheme is custom. It sounds to me like they don't want to help at all. It amazes me that once companys get your money they're done with you. I left a message with Mike Lozano. At this point I'm extremly
Old 11-11-2009, 08:43 PM   #5
old motorhead
CF Senior Member
You're not the only one that's had clearance problems with these hoods. I know at least one guy that painted his only to find that the hood wouldn't close over his TVS1900. I can understand you're being pissed. Luckily, I knew to steer clear of that hood. They ought to do something about it.......They will probably tell you to lower your motor.
old motorhead is offline   Reply With Quote
Old 11-12-2009, 08:21 AM   #6
mhoglund
CF Senior Member
mhoglund's Avatar
Quote:
The only acceptacle soloution is a new hood. I shouldn't have to change the height of the engine to make it fit when it says on their website that the Magnuson 112 and 122 fit with no problems. I wonder if the idiot I spoke to last night even stopped to think.....that out of the thousands of 112/122 hoods they have made that it is possible to have some non-conforming product. No company is perfect, however I do expect them to accept responsibility for the defective hood they sent me. Hopefully Mike will return my call today with good news.
Old 11-14-2009, 10:27 AM   #7
mhoglund
CF Senior Member
mhoglund's Avatar
I'm still waiting to hear from Sicmotorsports and RK Sport. I also called Magnuson Products and spoke to Davis Gonzalez to verify that the vaccum actuator on the 122HH is correct, and it is.
Old 11-14-2009, 11:19 AM   #8
Gene Gorman
CF Senior Member
Gene Gorman's Avatar
Here is a picture of my 122 it fits with no problem with the exception that we had to notch the rear cross member of the hood.
Gene Gorman is offline   Reply With Quote
Old 11-14-2009, 12:54 PM   #9
0SicMSP - Daniel
Former Vendor
SicMSP - Daniel's Avatar
Quote:
No actuator piece on the pic below - I left David another message by the way. I think him not calling me back means he's trying to figure out why your's has it and the other ones dont...
Quote:
SicMSP - Daniel is offline   Reply With Quote
Old 11-14-2009, 02:53 PM   #10
mhoglund
CF Senior Member
mhoglund's Avatar
I went back to the shop where my Corvette is today and took more pictures. The actuator that Magnuson installed onto my unit sticks up 5/8 of an inch above the tallest part of the Magnacharger. Unless I sand through the hood theres no way that actuator can be correct regaurdless What David at Magnuson says.
Old 11-14-2009, 02:54 PM   #11
mhoglund
CF Senior Member
mhoglund's Avatar
I think someone in upper management from Magnuson needs to chime in.
Old 11-14-2009, 07:09 PM   #12
mhoglund
CF Senior Member
mhoglund's Avatar
Does anyone else have pictures of a 122HH installed where you can see the vaccum actuator?
Old 11-14-2009, 08:22 PM   #13
old motorhead
CF Senior Member
I have a 122 on my truck, but it's a front drive. The vacuum actuator is way below the top of the blower. It's on the back end. I guess the blower is turned 180 degrees vs yours. Something has to be mounted wrong on yours. I can't believe, with all of the hood clearance issues that the Mangnacharger folks have to work through, that they would have that actuator mounted that high. Call or EMail Brian at Magnacharger monday a.m. I think he goes by "Magnacharger" on this site. Don't think he checks in here too often though.
Old 11-14-2009, 11:37 PM   #14
mhoglund
CF Senior Member
mhoglund's Avatar
I just sent Brian an email. Hopfully hes going to solve my problem
Old 11-15-2009, 12:24 AM   #15
1bdasvt
CF Senior Member
1bdasvt's Avatar
Old 11-15-2009, 10:51 AM   #16
Magna Charger
Premium Supporting Vendor
Matt, call me on Monday.
Magna Charger is offline   Reply With Quote
Old 11-18-2009, 11:19 PM   #17
mhoglund
CF Senior Member
mhoglund's Avatar
It turns out that the vaccum actuator was mounted incorrectly when the Magnacharger was manufactured which caused the hood interference. Brian at Magnuson sent me a new actuator next day red. Now we need to address the spider cracks in the hood which were caused by the interference. Sending pics tomorrow morning.
Reload this Page Maggie 122HH & RK Sport Hood Interference
Tags
04, 122, 122hh, corvette, custom, hh, jobs, lozano, magnacharger, magnuson, mike, paint, rk, sport
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
