Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-09-2009, 12:33 AM   #1
excessive81
CF Senior Member
excessive81's Avatar
Send a message via Yahoo to excessive81
Default iat break out
my car is sd and i want to get rid of my old maf as it is a restriction and i would like to clean up the install with less couplers and clamps ect. has anyone used this harness to separate iat wires from maf so can remove maf then just run new 2 wire iat sensor. iat is only reason it is on car at this point. if someone has already done this which sensor are you using. all i have found are press/rubber gromet fit sensors. i figure it gonna need a screw in sensor because of the boost pressure i run
excessive81 is offline   Reply With Quote
Old 11-09-2009, 01:01 AM   #2
wooden
CF Senior Member
wooden's Avatar
I am running a press in sensor fitting with 14lbs boost no problems.
wooden is offline   Reply With Quote
Old 11-09-2009, 01:09 AM   #3
excessive81
CF Senior Member
what sensor do you have?
Old 11-09-2009, 01:11 AM   #4
07MontRedcp
CF Senior Member
Support Corvetteforum!
07MontRedcp's Avatar
I got the AEM 30-2010 Air Inlet Temperature Sensor Kit off of Amazon for $52. It will be awhile before I put it in. Do a Google on it and see if it's what you're looking for.
BJK
__________________
APS TT 630 rwhp/654 rwtq @ 9 psi
'07 Z51, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, GT2 Coilovers, Autometer Cobalt Fuel & Boost Guages, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system.
07MontRedcp is offline   Reply With Quote
Old 11-09-2009, 01:37 AM   #5
Andy@AandACorvette
Platinum Supporting Vendor
Andy@AandACorvette's Avatar
Just get a sensor and grommet from a 97. Drill the hole just under the size of the grommet. It will never come out.
I also just use an OE IAT harness from the same year. Cut the wires and solder in the new ones.
This is probably the cheapest way to do it and it's nice and clean if done properly.
__________________
A&A CORVETTE PERFORMANCE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107 Toll Free- 1 888 VETTEPRO
Andy@AandACorvette is offline   Reply With Quote
Old 11-09-2009, 09:20 AM   #6
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
This is the way I did mine.
Fast06Z06 is offline   Reply With Quote
Old 11-09-2009, 09:51 AM   #7
excessive81
CF Senior Member
i dont want to cut the harness just incase some day there is a maf for big power guys or i want to pull my motor and drop a crate motor back in it to trade or sell so i am ok with the $30 harness. gonna pull all the maf wires out of clip so it just be iat wires coming out of it anyway. thanks for the sensor info. but i cant find any act pics of the aem sensor. do you have any. i want to make sure it will connect to the harness i getting ......Andy i just ordered a 8 rib bracket from you today got some belt slip issues i trying to fix.
Old 11-09-2009, 01:00 PM   #8
aTX427
CF Senior Member
St. Jude Donor '09-'10
aTX427's Avatar
I run a Dallas Performance card maf charge tube. It is as clean as any SD setup I have seen and I don't have to worry about temp / humididty issues.
aTX427 is offline   Reply With Quote
Old 11-09-2009, 03:02 PM   #9
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
You dont have to butcher the harness. You just cut the two wires you need for the IAT solder the two ends coming from the harness to the IAT and leave the other ones taped up and out of the way. If you ever need to put it back you just unsolder those wires and resolder them to the original two wires in the harness.
Old 11-09-2009, 06:00 PM   #10
Taylor@DallasPerformance
Supporting Vendor
Taylor@DallasPerformance's Avatar
You can also pull the pins from the MAF connector if you want. Then pop those pins into the new IAT pigtail...
__________________
Taylor Sims
www.DallasPerformance.com
214-349-1300
Taylor@DallasPerformance is offline   Reply With Quote
Old 11-09-2009, 07:09 PM   #11
Mr.Big
CF Senior Member
Mr.Big's Avatar
Quote:
what Taylor said...
Dallas Performance MAF system here as well
__________________
Jeremy
Dallas/Valley Ranch Tx
1070+rwhp930+rwtq Boost ONLY
Dallas Performance custom F1R system, D.P. Forged 370, ALKY Control/D.P. Triple nozzle, D.P. E85 fuel system, Wilson Billet intake, D.P. Direct Drive + 10rib, WCCH 317's, D.P. Blower cam, HPTuner, D.P. '09 rearend, TR6060, Mcleod "sintered" twin, THANKS to www.dallasperformance.com
Mr.Big is offline   Reply With Quote
Reload this Page iat break out
Tags
302010, aem, bonneville, breakout, ect, iat, maf, pontiac
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
Stinger "help" 98corvette82 C5 General 17 01-22-2005 03:42 PM
Dynatech SuperMAXX Dyno Results bgood C5 Tech 32 05-24-2004 09:57 AM
Does anyone have Andy's Head/Cam special? MagRed01Atty C5 Tech 17 05-19-2004 09:01 PM
Finally started my ATI install!!!!! vvv90 C4 Forced Induction/Nitrous 71 12-01-2003 05:59 PM
How I found 30 free horsepower! MTVette C4 Tech/Performance 18 07-02-2003 03:55 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
