Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2009, 01:40 AM   #1
Black730
Forged
Support Corvetteforum!
Default Those w/ high HP cars: How are your axles holding up?
Those with high HP cars (800-1000rwhp+), how are your axles holding up?
I have a build in progress and we are going to aim for around 900rwhp. I'm debating on whether to upgrade to the DSS 300m axles.
What do you think? How many of you have broken yours, and those of you with the DSS axles, how are they working for you?
__________________
936rwhp/932rwtq - Dallas Performance Forged 416, F1R, Callies Crank & Rods, Diamond Pistons, ETP Heads, FAST 102, NW Throttle Body, Full Grandsport Widebody, Z06 Brakes, RPS Triple Carbon Clutch, ZR1 Trans & Diff, DSS Axles, Pfadt Coilovers, DP Big Mouth Intake, DP Boost By Gear, AR Headers, DP Dual Meth Injection, DP 1000hp Fuel System, DP 8 Rib Direct Drive, DP Blower Cam, B&B Fusion Exhaust, Dewitt Rad/Fan, DP 3.5" Propshaft, 4 Point Cage
Black730 is offline   Reply With Quote
Old 11-08-2009, 02:06 AM   #2
TRINIC5
CF Senior Member
TRINIC5's Avatar
Now this is depending on your application, I has an automatic C5 making big power, I also has the stock rear with the Harden output shalfs, I hav never broke an axle on my C5, although it was said that the C5 axles are the best, I also installed a set of C5 axles on my C6 with 700RWHP and broke it, My friend with his 08 broke about 2 axles, he is now running the C5 axles but is not getting on it as he use to.
The DDS axles are strong, I installed those on my C6 M6 and it is holding very good, I had make a few passes and it seem as if it will take the abuse, there is a problem I had with it, and thats the axle bolts to the CV joint next to the rear, after having it installed for a couple months I noticed I was smelling oil, I check everything until I found out it was the axle splashing grease onto the exhaust, had to take the axles out and have it repac and reseal. Just check to make sure the axles are seal properly around the joining by the rear end.
TRINIC5 is offline   Reply With Quote
Old 11-08-2009, 02:12 AM   #3
Black730
Forged
Quote:
The DDS axles are strong, I installed those on my C6 M6 and it is holding very good, I had make a few passes and it seem as if it will take the abuse, there is a problem I had with it, and thats the axle bolts to the CV joint next to the rear, after having it installed for a couple months I noticed I was smelling oil, I check everything until I found out it was the axle splashing grease onto the exhaust, had to take the axles out and have it repac and reseal so I would not be that
Thanks. I have a C6 M6. Sounds hit or miss on the stock axles. Not sure I want to take the chance of being stranded. Did DSS fix the problem for you under their 1 year warranty?
__________________
Old 11-08-2009, 07:43 AM   #4
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
I was making 680-700 rwhp and made two passes at the strip power shifting and a fair amount of street driving as well with that setup. I also dont beat the car hard launching and shifting unless im at the strip either so. But havent had a failure on them yet after my first one broke when I was stock from wheel hop and power shifting
Fast06Z06 is offline   Reply With Quote
Old 11-08-2009, 10:09 AM   #5
Jutskin
CF Senior Member
Automatics are easier on parts....with a standard an upgrade would be appropriate...especially with 800Hp plus.
From what I have seen anyway.
Jutskin is offline   Reply With Quote
Old 11-08-2009, 04:08 PM   #6
TRINIC5
CF Senior Member
TRINIC5's Avatar
The one year warranty is nice but in a situation like mine, I would have to take the axles out and ship it to them, then wait on their time to have it repaired and ship back to me which can be up to two weeks, so I R&R the axles myself and resealed it in les than 2hrs.
Old 11-08-2009, 04:13 PM   #7
TRINIC5
CF Senior Member
TRINIC5's Avatar
Quote:
I don't think abuse breaks them, its if your car hooks good, the power do the breaking, I've seen a few breaked at the track, I did it once and I also broke the output shalf once and even the main shalf from the Z51 transmission to the rear, it snaped like paper on the street. A good clutch and a good set of tires makes the weak point collapse.
Old 05-21-2010, 12:27 AM   #8
69 Vette
CF Senior Member
69 Vette's Avatar
I broke my C5 axles in my C6 ZO6 last night at the track.
900 RWHP
http://www.youtube.com/watch?v=K6wbBQKtNW0
Going with the DSS 300m axles now
69 Vette is offline   Reply With Quote
Old 05-22-2010, 06:52 PM   #9
barneygookle382
CF Senior Member
Default axles
Mike at Eastcoast Perf.was selling hardened C5 Z06 axles for $395 a pair than fit right in the c6 .. Cheap insurance and Mike very good to deal with..
barneygookle382 is offline   Reply With Quote
Old 05-22-2010, 07:11 PM   #10
Black730
Forged
DSS axles are expensive, but I like the 1 year warranty so that I can give them a beating and see if they keep on ticking...
__________________
Old 05-22-2010, 09:30 PM   #11
fperra
CF Senior Member
fperra's Avatar
Have you beefed up the differential? I would worry about that before the axles. I'm a little over 800 and I recently changed out the diffy to an RPM Stage 3 and C5 axles just for peace of mind.
fperra is offline   Reply With Quote
Old 05-22-2010, 09:35 PM   #12
Le Mans C6
CF Senior Member
Le Mans C6's Avatar
Sorry to piggyback on the thread, I know this is asking for more RWHP for axles, but at 600RWHP has anyone seen issues that low down? Should I be worried with 600?
Le Mans C6 is offline   Reply With Quote
Old 05-22-2010, 09:48 PM   #13
saplumr
CF Senior Member
saplumr's Avatar
Quote:
Not sure if "worried" would be the correct word but anything can happen when the tires don't spin.
saplumr is offline   Reply With Quote
Reload this Page Those w/ high HP cars: How are your axles holding up?
Tags
600, axles, c6, hp, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
