Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-07-2009, 11:51 AM   #1
R50THC5
CF Senior Member
R50THC5's Avatar
Default oil leak?? not sure
My 2006 a6 cpe procharged, I saw a drip trail up the driveway which caught my eye. Today I backed out of the garage pausing while waiting for the door to close, as I moved back that's when I saw a puddle that appears it came from the right front of the motor area. I quickly pulled back in and shut down. Got to go to work. A quick look the best I could, I saw some drips on the concrete under the area right front. Will have to put on the ramps for a closer look. I am asking for any thoughts as to what you may think I should look for. At first thought it was the oil filter but I think that's located left rear side of the motor. I don't run the car hard. Have 34,500 miles. Any ideas greatly appreciated. Thanking you in advance.
R50THC5 is offline   Reply With Quote
Old 11-07-2009, 12:11 PM   #2
BigMay60
CF Senior Member
BigMay60's Avatar
Did you do a cam with the procharger? When I changed my cam, I had a oil leak afterwards due to a bad crank seal that was pinched during the install. But, you would have to remove the timing cover to have any effect on this seal...pinning the crank should not have hurt it.
Are you running a self lubricated unit, or did you have to install some oil lines? Could have issues there.
Good luck finding the leak!
BigMay60 is offline   Reply With Quote
Old 11-07-2009, 12:24 PM   #3
setxws6
CF Senior Member
setxws6's Avatar
All the street Procharger units are self contained now, no oil lines, though look at all the plugs around the head unit to see if they're dripping.
Are you sure it's oil? It could be power steering fluid or engine coolant from that area under the hood. Best bet is too jack it up in the air and get under there with a flash light and find out.
setxws6 is offline   Reply With Quote
Old 11-07-2009, 02:28 PM   #4
R50THC5
CF Senior Member
R50THC5's Avatar
No cam change, I did look at the oil dip stick and all looked well. I will check the power steering unit. Did not think to check another obvious source. The appearance of the puddle seemed oily and transparent. Thanks to all for the response. Crossing my fingers.
Old 11-07-2009, 02:45 PM   #5
TrenAman
CF Senior Member
I have a procharger on mine and I have a little amount of red looking clear oil coming from the right front, kind of under the procharger area.. I cannot find anything myself. It is red.. I use redline oil.. no clues here, let me know if you find what it is!
TrenAman is offline   Reply With Quote
Old 11-07-2009, 03:24 PM   #6
setxws6
CF Senior Member
setxws6's Avatar
Quote:
You may want to look or feel around the head unit itself, and check plugs that may be leaking. I'm not sure if Procharger has this, but my V3 Vortech unit is self contained, and there's a plug that has a vent on it to keep from any pressure building up in the unit. Mine, when slightly over filled with fluid, would burp out just a little out of this vented plug. Not sure if Procharger has this, so I would check it out.
Old 11-07-2009, 03:33 PM   #7
TrenAman
CF Senior Member
I think procharger oil is green.. I will check..
Old 11-07-2009, 11:47 PM   #8
BigMay60
CF Senior Member
BigMay60's Avatar
Do you have an automatic? The lines Auto Fluid line connections are on the passenger side of the radiator. Its a red fluid.
Old 11-08-2009, 07:07 PM   #9
R50THC5
CF Senior Member
R50THC5's Avatar
Yes I have an A6 and the fluid is red. BigMay60, you may have hit it. Lots of plumbing around there and was hard to tell what is what. Going to flatbed it to the speed shop and have them take care of a couple other issues while there. I sent them pix,so they may already suspect my problem. Thanks to ALL who have made an input. Love this forum and the folks involved
Reload this Page oil leak?? not sure
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil Leak slarson C4 ZR-1 Discussion 24 05-24-2005 01:38 PM
Internal oil leak Dyna C1 & C2 Corvettes 48 01-21-2004 08:58 PM
oil leak ?? rear main seal?? azarby C5 Tech 11 01-06-2003 09:03 PM
I effed up while looking for my Oil Leak November Soul C4 General Discussion 17 01-01-2003 02:44 AM
Help dealer estimate on repairing oil leak!!! cadawg C4 Tech/Performance 21 05-11-2002 01:15 AM
Oil leak at the heads? Pictures..... Mervz C5 Tech 12 03-13-2002 09:02 PM
'Vert goes in for an oil change, comes out with an oil leak! The One C5 Tech 30 01-18-2002 11:35 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
