Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2009, 05:55 PM   #1
setxws6
CF Senior Member
setxws6's Avatar
Default Impeller speeds
What are some of your opinions about overspinning a centri head unit a few thousand rpms on the impeller speed? Pros, cons, or personal experiences? Thanks!
setxws6 is offline   Reply With Quote
Old 11-06-2009, 06:55 PM   #2
aTX427
CF Senior Member
St. Jude Donor '09-'10
aTX427's Avatar
I am geared for 110% - made the torque curve look like a TT.
aTX427 is offline   Reply With Quote
Old 11-06-2009, 07:13 PM   #3
carlrx7
CF Senior Member
St. Jude Donor '08-'09
carlrx7's Avatar
Quote:
is that 10% over Max RPM?
also are you runing a restrictor plate?
with a Vortech Si, a 3.6 @ 7000 rpms will be pretty much maxing it out RPM wise.
maybe a 3.4 if you kept it under 6500rpms
-carl
carlrx7 is offline   Reply With Quote
Old 11-06-2009, 08:18 PM   #4
0Steve@AandACorvette
Former Vendor
Location: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
AACorvette AandACorvette
Send a message via AIM to Steve@AandACorvette
-carl
3.6, 7K rpm and 7.33 crank = 51310 rpms...
3.4, 7K rpm and 7.33 crank = 54328 rpms...
I say 3.4. People have been overspinning these bad boys since day one. And the numbers they publish are always conservative. and you'll only be at 7000 rpm for a quick second...
But then again I may be under some sort of obligation to only quote manufacturers specs.
Steve@AandACorvette is offline   Reply With Quote
Old 11-06-2009, 08:39 PM   #5
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
The 7.33 is stock crank pulley size Steve? I thought it was 7.5 inches?
Fast06Z06 is offline   Reply With Quote
Old 11-06-2009, 09:42 PM   #6
setxws6
CF Senior Member
setxws6's Avatar
Quote:
That's a good question. I understand the LS1 stock dampner is 7.25, and I've read that the LS2 stock is 7.5.....
Old 11-06-2009, 09:49 PM   #7
carlrx7
CF Senior Member
carlrx7's Avatar
max rpm is 52000 right? for the Si?
Old 11-06-2009, 11:56 PM   #8
aTX427
CF Senior Member
aTX427's Avatar
-carl
Yes, 10% over the max on my F1R - no restrictor plate.
Old 11-07-2009, 08:19 AM   #9
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
V2 si yes
Old 11-07-2009, 08:21 AM   #10
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Im gonna drop down from a 3.8 to 3.6 inch. What rwhp gain do you think I can see and torque?>
Old 11-07-2009, 09:09 AM   #11
Mr.Big
CF Senior Member
Mr.Big's Avatar
I've been over spinning for years... No cons thus far... only pros!!!
__________________
Jeremy
Dallas/Valley Ranch Tx
1070+rwhp930+rwtq Boost ONLY
Dallas Performance custom F1R system, D.P. Forged 370, ALKY Control/D.P. Triple nozzle, D.P. E85 fuel system, Wilson Billet intake, D.P. Direct Drive + 10rib, WCCH 317's, D.P. Blower cam, HPTuner, D.P. '09 rearend, TR6060, Mcleod "sintered" twin, THANKS to www.dallasperformance.com
Mr.Big is offline   Reply With Quote
Old 11-07-2009, 10:44 AM   #12
setxws6
CF Senior Member
setxws6's Avatar
Quote:
Do you think this could have been a cause in (possible premature) seal failure earlier this year?
Old 11-07-2009, 12:35 PM   #13
BigMay60
CF Senior Member
BigMay60's Avatar
52000 RPM appears to be the published OEM maximum operating speed for the V3Si SC. This is very different from the critical maximum speed.
In most industrial applications (gas turbines, steam turbines, internally geared air compressors, etc...) a critical overspeed limit is set 10% above the maximum operating speed. This well within the safety factor of the machine. 110% max speed for the V3Si is 57200 RPM.
In a internally geared machine, the main issue running at overspeed is the dynamic oil wedge thickness between leading gear edges upon contact. As the speed of the gears increase, the force contact between the gears increases and this oil wedge becomes thinner. The smaller oil wedge increases the probability for metal to metal contact (damage) or any particles in the oil to cause FOD (foreign object damage) on the gear faces. This type of damage will initially show up as a high gear mesh frequencies and eventually escalate in to an audible gear whine.
The oil seals in these compressors are similar to PD oil deflectors. The only thing that will cause an issues (leaking) with them is run out of the shaft that will causes their fits to increase. Slight bumps over the maximum operating speed should not have had any effect on these.
In summary, I would only worry about it if you were going to run your SC at overspeed (<=57200) for an extended amount of time. In an automotive application I would not be concerned.
BigMay60 is offline   Reply With Quote
Old 11-07-2009, 01:03 PM   #14
setxws6
CF Senior Member
setxws6's Avatar
Thanks Scott, that's a good write up!
Old 11-07-2009, 01:20 PM   #15
TRINIC5
CF Senior Member
TRINIC5's Avatar
One of the most important factor about overspinning a unit is the heat generating from overspin, it may seem as overspinning the unit makes more power but after checking the ATI it tence to make less power with the heat factor, its better to use a bigger unit and spin it less than to try and spin a small unit max, the unit generate less heat and makes it more efficient with more power. I also try spinning a D1SC head unit over the max and it did damaged the popellers inside the unit by hitting the housing. So the theory for HP are to spin a big unit about 80% to max than to try and spin a small unit 110%. Now in TX427 case, he wanted max HP and he had no choice to spin a F1R to 110% but the intercooler has to be big and he will still loose some power because of heat. Remedy for his application will be to increase the unit but he will have to do the whole system over because his intercooler could be at the max flow with a F1R.
TRINIC5 is offline   Reply With Quote
Old 11-07-2009, 03:18 PM   #16
BigMay60
CF Senior Member
BigMay60's Avatar
Quote:
Making power with a larger unit is more efficient than running a smaller unit at higher speeds. It will definatley lower your IATs.
Old 11-07-2009, 03:44 PM   #17
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
So anyone know the answer to this?
Old 11-07-2009, 04:31 PM   #18
BigMay60
CF Senior Member
BigMay60's Avatar
So what happended, Brian? Did one of your oil seals start to leak this year? Did you ever run with the unit overfilled?
Old 11-07-2009, 04:50 PM   #19
setxws6
CF Senior Member
setxws6's Avatar
Pulley down one size like that will net you around 1.5 - 2lb increase in boost. So probably 30-50rwhp, but that's depends on your other mods, and the flow efficiency of the motor.
Quote:
No, nothings wrong with the V3, none at all. This was a conversation piece that's come up before, and I did a search and didn't find much on it. So I figured I'd see what other opinions were on it. I may look at spinning it up a couple thousand over the max rated speed one day. Just looking at opinions.
I've never really "overfilled" the unit. But the 4oz bottles they give you is just a little more than what you need in the unit. I've only change the oil once in it. Drained it all out, and then put the whole 4oz in. It would burp a little (on the vent plug, not everywhere) the first few weeks/month, then would stop after a certain point. But it did this from the beginning, so apparently even Vortech "overfilled" it a little too.
Old 11-07-2009, 06:30 PM   #20
TRINIC5
CF Senior Member
TRINIC5's Avatar
The answer to your question depends on the application beeing used, are you going to use the same size motor you had before, are you using the same size heads you had before, same size valves, same size cam? now those are the answers you will have to consider first, then if not, there will be alot of other things to think about, if the heads are flowing better and the cubic inch are the same, the boost gage might read the same as before but the motor will be gaining more power, the boost is a restriction to the motor, the more the motor is restricted, the more boost you see, therefore it is not the restricted boost that makes the power but the CFM that applied to the motor. Now if your heads are flowing better and you down size the pulleys, you might have the same reading on your boost gauge and could be making over 80 to 90 more RWHP.
Reload this Page Impeller speeds
Tags
2005, corvette, d1sc, overspinning, supercharger, v3si, vortech
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
how does the Maggie (or KB Twin Screw) produce instant boost... Jesse_Boyer C5 Forced Induction/Nitrous 13 06-30-2005 04:54 PM
Sluggish performance... here's why qwiketz C4 Forced Induction/Nitrous 27 02-02-2005 01:42 PM
What is the difference in the internal setups of ATI SC? XCELER8 C5 Forced Induction/Nitrous 12 09-15-2004 09:04 PM
They say it can't be done but going to do it. Electric Forced-Induction. BIG JIM 54 C4 Tech/Performance 231 12-30-2003 08:07 PM
Merlin’s Maiden Voyage Merlin522 C3 Tech/Performance 70 11-25-2002 08:14 PM
overheating - one last time mgriffis C1 & C2 Corvettes 41 09-19-2002 12:30 PM
Meziere LT1 water pump on sale RichS C4 Tech/Performance 57 11-04-2001 11:35 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
