Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2009, 06:58 AM   #1
0EPP
CF Senior Member
Default EPP LS2 402ci Aluminum Short block - Camshaft included!
http://www.exoticperformanceplus.com...html?item=1715
Check it out at the above link, with many options to choose from. Bob
* Callies Compstar 4.00 Stroke crankshaft
* Callies Compstar 6.125 H Beam connecting rods with ARP 2000 rod bolts
* Diamond forged pistons
* Comp/EPP blower camshaft 232/240 .595/.608 on 115 LSA or customer spec Comp camshaft
* Camshaft degreed in
* Total Seal file to fit piston rings
* Clevite main and rod bearings
* Cylinders are CNC Bored and Honed To Size with a Torque Plate
* Main Journals are Align Honed
* Crankcase is Stroker Clearanced
* Balanced rotating assembly
* Choice of compression ratio
* Sold outright, no cores required
* Built entirely from brand new parts
* Includes front cover
* Includes valley cover
* Includes Comp double row LS2 timing chain set
* Includes Comp Pro-Magnum hydraulic roller lifters
* Includes lifter guides
* 28 or 54 tooth reluctor wheel
* Oil pump not included
* Oil Pan not included
EPP is offline   Reply With Quote
Old 11-12-2009, 07:52 AM   #2
0EPP
CF Senior Member
Bump for one heck of a good deal! Bob
Reload this Page EPP LS2 402ci Aluminum Short block - Camshaft included!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
