Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-03-2009, 05:47 PM   #1
Cajundude@EnglandGreen
Supporting Tuner
Houston Events Coordinator
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11
Support Corvetteforum!
Cajundude@EnglandGreen's Avatar
Location: ========= Houston, Texas www.englandgreen.com ============== Necessary Evil™ __ 281.464.2800
Default *** EnglandGreen's CRAZY November Drivetrain SPECIALS!!! ***
Differentials! Transmissions! Clutches! Stall Converters! It is time to have our November specials and they will last until November 30, 2009 so book your appointment today! We chose the drivetrain this month because we are hearing more and more people are breaking stuff lately! This is a good month to jump in to prepare for the go fast mods in the next couple of months!
These specials apply to the C5 and the C6! If you are not local or do not want to drive for the install, we will offer free shipping on the differentials and transmissions to the lower 48.
*** Differentials, differentials, differentials! ***
The differential pricing below includes all fluids and installation as well as shipping back and forth for RPM Transmissions differentials! Sales tax will be added to parts. Please add $100.00 (Normally $200) for C5s with long tube headers. If you have a 2005 and want to upgrade to a 2006, please add $1050.00. GM in all its wisdom decided to use a sand cast case for its differential in 2005 so these are prone to break. GM quickly went back to the die cast in 2006. A4 and A6 transmission computer tunes will be $150.00 for this special.
Quick and easy option for the C5 - Brand new C5 Z06 3.42 differential installed for $1895.00. We keep your core differential.
RPM Transmissions Stage 2 Differential - $1995.00 installed!
  • Media blast case
  • New seals
  • C6 Z06 left shaft
  • C6 Z06 2-piece right shaft
  • OEM clutch packs
  • HD preload springs
  • Performance Metal Micropolished gear of any ratio:
  • 2.73, 2.93, 3.15, 3.42, 3.73, 3.90, 4.10
RPM Transmissions Stage 3 Differential - $2795.00 installed!
  • Media blast case
  • New seals
  • 300M left shaft
  • 300M 2-piece right shaft
  • Upgraded carbon clutch packs
  • C6 Z06 pinion support
RPM Transmissions A6 Differential - $2195.00 installed!
  • Media blast case
  • New seals
  • C6 Z06 left shaft
  • OEM clutch packs
  • 2.56, 2.73, 2.93, 3.15, 3.42
RPM Transmissions C6 Z06 Differential - $3195.00 installed!
  • Media blast case
  • New seals
  • 300M left shaft
  • 3.73, 3.90, 4.10
*** Transmissions, transmissions, transmissions! ***
The transmission pricing below includes all fluids and installation as well as shipping back and forth to RPM! Sales tax will be added to parts. Please add $100.00 (normally $200) if you have long tube headers installed. HD upgrades available if needed! Pricing applies to the C5 and C6.
RPM Transmissions T-56 Level IV Transmission - $2195.00 installed!
  • Media blast transmission case
  • Solid synchronizer keys
  • Steel 3-4 shifter fork
  • Hand fit sliders and hubs
  • New Compressed Carbon blocking rings
  • Assembly to RPM's specifications
RPM Transmissions T-56 Level V Transmission - $2695.00 installed!
  • Bronze fork pads
  • RPM modified 1-2 shifter fork
  • Performance metal micropolish
RPM Transmissions 4L60E Level IV Transmission - $2295.00 installed!
  • RPM sleeved input drum
  • RPM 3-4 clutch pack
  • RPM reinforced sunshell with collar and bearing
  • Heavy Duty double caged 29 element sprag
  • 4L65E low roller clutch
  • Billet 4th gear servo
  • Transgo HD-2 shift kit
  • Corvette servo
  • Wide 2-4 band
  • Updated aluminum accumulator piston
  • Bushing kit
  • New shift solenoids
  • New wiring harness
  • New GM valve body spacer plate
  • Seal & gasket kit
  • Filter
  • Set clutch and band clearances to RPM's specifications
  • Each transmission is dyno tested before shipping
RPM Transmissions 4L60E Level V Transmission - $2695.00 installed!
  • Corvette servo
  • Wide 2-4 band
  • Bushing kit
  • GM 5 pinion planetary gearsets - front and rear
  • Seal & gasket kit
  • Filter
RPM Transmissions 4L60E Level VI Transmission - $3195.00 installed!
  • Corvette servo
  • Wide 2-4 band
  • Bushing kit
  • 300M hardened output shaft
  • Seal & gasket kit
  • Filter
Need a RPM Transmissions modified ZR1 transmission installed in your C6Z? Give us a shout. We have done a few of these and they are smooth as butter.
Stall Converters! - $825.00 while doing the tranny at the same time. If you just need a converter installed without the tranny, the price is $1275.00 installed. Add $100.00 if long tube headers are installed.
*** Clutches, clutches, clutches! ***
At EnglandGreen we always provide our customers with complete packages so there are no surprises on your bill. We also do not like to come back to you after your car is here and say, "oh by the way, you need this..." So, our clutch packages are complete!
Textralia Z-Grip Package - $1895.00 installed! Please add $100.00 for cars with long tubes installed. Our clutch packages consist of the following:
  • Textralia OZ700 Clutch
  • New pilot bearing
  • New flywheel bolts
  • New hydraulic slave cylinder
  • New hydraulic master cylinder
  • Remote bleeder
Spec SuperTwin packages are available as well if you need a clutch good to 1395rwtq.
As previously mentioned, these specials will end on November 30, 2009 by the close of the business day. Also, we will be having a customer appreciation party on December 5, 2009 should you care to stop by! We will make an announcement in another thread.
Please don't hesitate to call us with any questions you may have. Thanks!!!
Jason
__________________
3135 Fall Street
Houston, Texas 77054 USA
281 464 2800
sales@englandgreen.com
AIM/iChat: sales@englandgreen.com
Facebook: EnglandGreen.Corp
EnglandGreen Corp. is a high performance facility that specializes in C6 & C5 Corvettes.
© 1994-2011 EnglandGreen Corp. Necessary Evil™
Cajundude@EnglandGreen is offline   Reply With Quote
Old 11-03-2009, 10:18 PM   #2
CONMAX
CF Senior Member
CONMAX's Avatar
why do you have to add $100 for LT headers? since the exhaust system unbolts from the collector, i would not think there would be any unbolting from the heads. i have LG LT's.
CONMAX is offline   Reply With Quote
Old 11-03-2009, 10:36 PM   #3
Supporting Tuner
Quote:
The headers will have to be removed to do a clutch, particularly the LGs. If you do not remove the headers, you can not get the bellhousing off.
Old 11-09-2009, 08:46 PM   #4
Supporting Tuner
TTT
Old 11-14-2009, 09:52 AM   #5
Supporting Tuner
Bump since the forum works again...
Old 11-16-2009, 08:27 PM   #6
Supporting Tuner
Back to the top.
Old 11-21-2009, 08:10 AM   #7
Supporting Tuner
Up, up, up... Have a great weekend everyone!
Old 11-26-2009, 10:29 AM   #8
Supporting Tuner
Gobble gobble! Turkey Day bump! Happy Thanksgiving?
Jason
Old 11-28-2009, 12:23 PM   #9
Supporting Tuner
This special ends Monday. Thanks for all the orders!
Jason
Old 11-30-2009, 06:02 PM   #10
Supporting Tuner
Today is the last day! Thanks for all the orders!
Jason
Reload this Page *** EnglandGreen's CRAZY November Drivetrain SPECIALS!!! ***
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
