Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-03-2009, 02:51 PM   #1
btstone84
CF Member
Default timing
is a 125shot with 28 degrees of timing WAY too much. would this create a bomb. i am running a 75 shot wet kit now with no issues,
thanks in advance guys
btstone84 is offline   Reply With Quote
Old 11-03-2009, 02:56 PM   #2
Chris@East Coast Supercharging
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Chris@East Coast Supercharging's Avatar
Send a message via AIM to Chris@East Coast Supercharging
stock bottom end? cam specs?
Chris@East Coast Supercharging is offline   Reply With Quote
Old 11-03-2009, 03:01 PM   #3
btstone84
CF Member
yeah stock, trick flow cam. 595 lift dont remeber the duration
Old 11-03-2009, 09:12 PM   #4
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
YEA can you say BOOM. I could barely hold 18 degrees total timing at WOT on a stock bottom end and heads with cam and supercharger. If its an LS7 your nuts. I cant see it holding that much timing at all.
Fast06Z06 is offline   Reply With Quote
Old 11-03-2009, 11:41 PM   #5
carlrx7
CF Senior Member
St. Jude Donor '08-'09
carlrx7's Avatar
whats the rule of nitrous? 3 degrees for every 50 hp? so take out 7.5 degrees.
carlrx7 is offline   Reply With Quote
Old 11-04-2009, 01:25 PM   #6
BADZ
CF Senior Member
Support Corvetteforum!
BADZ's Avatar
Very well put!!!
Quote:
BADZ is offline   Reply With Quote
Old 11-04-2009, 01:52 PM   #7
btstone84
CF Member
i have cam, 225 heads, and bolt ons
Old 11-04-2009, 06:39 PM   #8
ArcticT
CF Senior Member
I'll have to double check, but I think I am on 18 or 19 degrees with cam, bolt ons and a 125 shot on my LS3.
ArcticT is offline   Reply With Quote
Old 11-04-2009, 10:56 PM   #9
rattt g
CF Senior Member
rattt g's Avatar
just run 100 octane and you will be fine
rattt g is offline   Reply With Quote
Old 11-05-2009, 08:45 AM   #10
Fast06Z06
CF Senior Member
Fast06Z06's Avatar
Quote:
With 28 degrees timing and a nitrous shot at WOT on a stock LS7 block even with 100 octane he will be detonating like crazy and probably crack a piston. I wouldnt suggest that. Where did you come up with the 28 degrees timing from?
Are you sure its 28 degrees timing at WOT or is it midway through the chart like part throttle. Thats a different story. Are you looking at the main timing table in HP?
Reload this Page timing
Tags
28, degree, timing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
TDC cam timing and distributer vettepilot68 C3 Tech/Performance 47 08-30-2005 08:38 AM
Where do you guys set your base ignition timing (L98)? TheCorvetteKid C4 Tech/Performance 61 08-21-2005 02:17 PM
The Dark Side of Performance Timing Tele_Man C3 Tech/Performance 106 08-05-2005 03:29 PM
Dyno time aproaching - Timing mn_vette C4 Forced Induction/Nitrous 41 07-05-2005 04:47 PM
As far as timing and AF for FI? XCELER8 C5 Forced Induction/Nitrous 31 06-27-2005 03:24 PM
ignition timing results....need some advice bobs77vet C3 Tech/Performance 85 04-28-2005 07:55 PM
SWC Duke Help! With my 327 johnfharding C1 & C2 Corvettes 74 12-08-2004 09:54 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
