C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Just a little nudge to the ET bar, ECS Paxton = 8.70 @ 157
Old 09-04-2009, 09:15 AM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,079 Likes on 653 Posts
Default Just a little nudge to the ET bar, ECS Paxton = 8.70 @ 157
Come guys, I'm not even making throttle adjustments anymore until someone comes knockin' so come on Fran, get a cage in that monster and get it out there! Atomic, we are close in power, lay it down!!
I also reached a personal goal of mine, which was to cut a 1.2 60' time!! (1.28) which is the first C5/C6 IRS to hit the 1.2's!!
We are putting together a package price for the recipe for the suspension necessary to do that. We will be offering install packages as well, which includes corner weighing the car and the complete set up, along with explaining how to make the adjustments necessary. Feel free to call the shop if you are interested.
DOUG @ ECS is offline
Old 09-04-2009, 09:17 AM
Stage7
Stage7's Avatar
Insane! Congrats!
Stage7 is offline
Old 09-04-2009, 11:04 AM
Mr.Big
Mr.Big's Avatar
WOW 1.2's!!!
Mr.Big is offline
Old 09-04-2009, 11:18 AM
greekc6
greekc6's Avatar
great work doug. cant believe how that vert moves
greekc6 is offline
Old 09-04-2009, 11:25 AM
Streetfast
Streetfast's Avatar
Streetfast is offline
Old 09-04-2009, 12:00 PM
drivinfast
drivinfast's Avatar
Doug, have you put any info for the rear end in a summary form somewhere. Like what half shafts, drive shaft, suspension, type of upgraded diff, etc.
If not, without giving anything away, could you do that here?
drivinfast is offline
Old 09-04-2009, 12:58 PM
DOUG @ ECS
DOUG @ ECS's Avatar
No prob! I'm not one to with hold info. (lets face it, I want to sell them to everyone)
It is a std C5Z case, built here, 3.42 gears with our spool kit installed and both hardened shafts, and the gears are cryo treated same as all our rear builds.
Both flywheels have been upgraded, along with the splined hub that the torque tube slides into. The driveshaft is presently our HD driveshaft with universal joints, but I have a Pfadt Carbon fiber driveshaft going in when I have time to see how that holds up. Ours is simply beefy, but with beefy comes weight, Pfadt says we are good to hold the power with their lightweight set up so I'm going to give it a try.
The trans is our power glide conversion which is a straight bolt in swap that can be done in a day. That includes the rear brace etc.
We have HD axles and hubs mated to our 15" spindle kit, with our axle loops as per NHRA rule.
The rest of the suspension is Pfadt drag products, coil overs-sway bar-engine and trans mounts and spherical bearings. Corner weighted, aligned, and set up here.
Any other questions let me know.
Old 09-04-2009, 02:02 PM
06.Z51.MontRed.Vert
06.Z51.MontRed.Vert's Avatar
Location: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
Damn thats amazing!! Great Job Doug!!
06.Z51.MontRed.Vert is offline
Old 09-04-2009, 02:21 PM
jordan@pfadtracing
jordan@pfadtracing's Avatar
Autocross & Roadrace Forum Sponsor
Nice work!!!!
The Pfadt Carbon Shaft is rated to 2350 ft/lbs! We cycled it to 1350 ft/lbs over 500,000 times!!
Get that thing in the car!! It will help the 60 ft for sure!!! 1.19??
This car is running the Pfadt Drag 2 package that includes our Drag Spec Coil Overs, Drag Rear Sway Bar and Spherical C-Arm Bearings. It also has our Engine Mounts and Tran/Diff Mount.
What throttle % are you at now?
Congrats again to the entire ECS crew for an amazing build!
Kind regards,
jordan@pfadtracing is offline
Old 09-04-2009, 02:43 PM
0Mike69@ECS
Former Vendor
Mike69@ECS's Avatar
Cruise-In III Veteran
Cruise-In V Veteran
The Vid!
Mike69@ECS is offline
Old 09-04-2009, 04:33 PM
jordan@pfadtracing
That is seriously awesome!
Old 09-04-2009, 05:10 PM
24hr Z06
24hr Z06's Avatar
and you have how much throttle left?
nice job guys..
24hr Z06 is offline
Old 09-04-2009, 06:36 PM
atomicfusion
atomicfusion's Avatar
Great job! We hope to be there soon.
atomicfusion is offline
Old 09-04-2009, 08:03 PM
tlaselva
tlaselva's Avatar
Making the power is the easy part. Laying it down is not.
Great work Guy's, Novi's rule!
tlaselva is offline
Old 09-04-2009, 09:02 PM
STEALTH 99 C5
STEALTH 99 C5's Avatar
Originally Posted by jordan@pfadtracing
Nice work!!!!
Kind regards,
That beast is really hooking up the power . How much for a package price on the drag suspension parts you listed ?
STEALTH 99 C5 is offline
Old 09-04-2009, 09:35 PM
wishmaster
wishmaster's Avatar
Will this tranny fit to C6Z06 and what will be the cost ?!
great job guys
wishmaster is offline
Old 09-05-2009, 12:25 PM
DOUG @ ECS
DOUG @ ECS's Avatar
We will have a full kit price up shortly Mike, next week sometime I'll post it up in the drag racing.
great job guys
Yup, we have the trans set up and brackets completed already for the C6 ZO6, which requires a different custom shaft. We started with the C5 rear so we had gearing options, but I run a 3.42 now and will probably switch to the C6Z rear and cradle when the time comes for a Warhawk block and a larger head unit.
I'm glad we started that way so if someone wants the glide set up from us, we know exactly what gear is needed for their power set up and expected ET, so there is no wasted time or money for the customer.
7's with an IRS sounds like a nice future goal.
To Just a little nudge to the ET bar, ECS Paxton = 8.70 @ 157
Old 09-05-2009, 02:52 PM
06.Z51.MontRed.Vert
: cool: That would be unreal!! Better get the avatar designed ahead of time!!
Old 09-05-2009, 10:56 PM
Tony B4
Tony B4's Avatar
St. Jude Donor '08
Default 1.2 60ft!
Originally Posted by Mike69
The Vid!
Insane! Congrats Doug, great pass!
Tony B4 is offline
Old 09-05-2009, 11:03 PM
drivinfast
drivinfast's Avatar
One notch of tuning at a time and get r done
It will take something for an IRS 7's but it will be done soon IMO
Quick Reply: Just a little nudge to the ET bar, ECS Paxton = 8.70 @ 157
