Tried to start up my new 427 motor today
Tried to start up my new WarHawk 427 motor today and nothing happen. I checked all the fuses, disconnected and reconnected the battery over and over again. Went back and checked all my wiring and still can’t find out why it will not start.
I pulled the factory motor out with around 4,500 miles on it and built a WarHawk 427 motor and installed the APS Z06 kit at the same time as I put the motor in. I can hear the fuel pump prime but the motor will not crank over.
The starter is brand new, and with the APS kit on it will be hell getting it out to take in to test.
Any ideas guys?
I will have to say this build has been nothing but problems from the start. But it has also been a great learning and fun experance.
Any ideas guys?
Former Vendor
Bring it by, I'll get it going for you
Just kidding! Could be a lot of things but I would check with clutch pedal switch first, then verify starter relay is connected correctly, keep going down the list...
Any ideas guys?
Any ideas guys?
Existing or new ECU?......any error codes stored? Possibly "Clutch Pedal Position Learn" needs to be accomplished? That code will keep the motor from turning over.
Existing ECU and that was one idea I also had. I have a friend coming over with a Tec II so we can find out what codes it has and clear them all out.
Thank you for the ideas
Well I got it running today for about 60 sec before the ECU cuts out the injectors. I jumped power right to the starter and it worked just fine. I think what’s going on is my body control module is bad so the car thinks I'm stealing the car so that is why my injectors cut out. So this means I have to tow in the car to buddy’s that has a TEC II scanner and he can set the body control modular up.
yup just what i was gonna suggest, anti-theft is kicking in, but there was a way to pull of two fuses and put them back it that would reset anti-theft but i cant remember them >.< a tech 2 would be handy.
also with the 60second shut-off you might want to check with the crankshaft position sensor, which might need a relearn as well
Well today we got our hands on a Tec 2 and found out what the problem was. It was the BMC needed to be reprogrammed; the theft system rest, and then we could see that the clutch sensor was not sending any signal to the ECU. I have a new sensor coming on Monday. I was about ready today to take the one out of my other car to just get this one running.
Former Vendor
Gotta love those Tech2's, they great for solving these kinds of problems and save a lot of frustration.
Post up some pictures of the build.
