Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-29-2009, 08:20 PM   #21
gdiddy
Junior Member
What would you guys consider an ideal a/f for this setup? So you guys dont have to scroll up its 7psi totaly stock ls7 engine. I'm putting meth on as a safety measure for those hot summer days where i live but don't plan to tune for it . Will this cause the car to run rich at all?
gdiddy is offline   Reply With Quote
Old 04-30-2009, 01:00 PM   #22
EdwardETraylorIII
CF Senior Member
EdwardETraylorIII's Avatar
Location: MIA/FTL/ATL/HSV/SFO/SJC Work keeps me on the move!
Send a message via AIM to EdwardETraylorIII Send a message via Yahoo to EdwardETraylorIII
gdiddy,
Without meth I shoot for 11.8-12.2:1 A:F. Once Meth is installed, depending on HOW MUCH meth you are spraying, then I shoot for a target A:F anywhere from 10.5:1-11.5:1.
Remember, most folks tune meth for right around 4.5:1 so that offsets our petrol based stoich balance considerably.
Methanol can run almost 3 times as rich (volume) as petrol based fuel and still make great power - so don't worry about running rich when injecting meth. It will still make great power and cool things way off.
EdwardETraylorIII is offline   Reply With Quote
Old 04-30-2009, 11:21 PM   #23
HANNY
CF Senior Member
HANNY's Avatar
Quote:
Originally Posted by EdwardETraylorIII View Post
This is a 10 second fix within HP Tuners...
HANNY is offline   Reply With Quote
Old 06-23-2009, 10:27 PM   #24
lfsglass
CF Senior Member
lfsglass's Avatar
Quote:
Originally Posted by gdiddy View Post
This seems to be the common reaction lol. They don't seem to lag. Its different going from s/c'd to turbo and i was expecting some delay so maybe they do maybe they don't. I mean sure if i punch it in third not going fast there's a bit of a delay. I love the feel when you have the rpms up high and run thru the gears. Once i have the tuning done on a dyno in the next week ill post up the results. What do most guys go with for there tt setup?
What happened to posting results? Did you start another thread?
lfsglass is offline   Reply With Quote
Old 06-24-2009, 03:45 AM   #25
gdiddy
Junior Member
Quote:
Sorry guys been busy with life. With the tuning from sts the car put down 586 rwhp and i believe 550 torque. Im sending the car to a shop that specializes in vette tuning to have it finished. I'm not expecting much more in hp but theres some 'issues' with the current tuning . For the record i ate some rice recently , the old vette liked chewing on a new gtr
Old 06-24-2009, 05:56 AM   #26
Flash99
CF Senior Member
Support Corvetteforum!
Flash99's Avatar
Numbers seem low, I put the same numbers down through my KB LS2 and thats through an A6. Might want to check with your tuner and see if there is anything he can do about it.
Heres a vid of my goat with a single tiny turbo:
http://videos.streetfire.net/video/F...68L_121444.htm
Flash99 is offline   Reply With Quote
Old 06-24-2009, 09:52 PM   #27
blackbird00
CF Senior Member
I think a set of headers would probably help you out alot!
The more air comming in the better, any reason why you chose to have no supporting mods?
blackbird00 is offline   Reply With Quote
Old 06-26-2009, 02:06 AM   #28
gdiddy
Junior Member
No reason other then seemed the opnion was it would run well the way its setup. Ill let everyone know what happens with the tuning that i have done. I told the shop that its going to they could do whatever they like for exhaust etc. What would you recommend?
Old 06-26-2009, 12:05 PM   #29
blackbird00
CF Senior Member
Most turbo kits come with their own manifolds but since you went the STS route you can choose what ever headers you like, I know the more air the more HP so a set of 1 7/8 headers would be my choice, possibly thoes new LG superflows,
Old 06-27-2009, 08:04 AM   #30
Gannet
CF Senior Member
St. Jude Donor '06
Gannet's Avatar
Turbos are powered by heat, not by "air". Ahead of the turbos you want the exhaust that loses the least heat. Usually that means factory manifolds, and if you're real serious you use exhaust wrap on the system up to the turbos. Most STS cars that install headers lose horsepower and gain lag.
Gannet is offline   Reply With Quote
Old 01-24-2010, 11:59 PM   #31
McMung
CF Senior Member
Send a message via Yahoo to McMung
Quote:
Originally Posted by crabman View Post
There is no state where it is legal to remove the cats. All states must comply with federal or CARB rules and neither allows for the removal or relocation of the cats.
Thanks buzzkill.
McMung is offline   Reply With Quote
Old 01-25-2010, 02:30 AM   #32
TTBEAST
Junior Member
TTBEAST's Avatar
These numbers seem low to me, I would expect that it would fart out 600-650rwhp with those turbos and 7psi. I would get a good tuner in your area to get it straightened out. Hopefully someone with an STS kit can chime in with their results. I would definatley go with meth, for the saftey and cooling .
TTBEAST is offline   Reply With Quote
Old 01-25-2010, 01:51 PM   #33
East Tx Muscle Cars
Supporting Vendor
East Tx Muscle Cars's Avatar
Send a message via Yahoo to East Tx Muscle Cars
i would not go with a set of headers if i was you. STS turbos DONT like them. the only time you do that is if you have a 800+ monster that you have to have the flow out of the motor. Turbos work off heat and headers let heat out, ifg you do headers your spool time will go up and you may actually loose HP. if you want better spool time put a turbo blanket on it, and you can also wrap SOME of your exhaust system. Also you should be in the 625 range on your wheel hp with 7 psi.
__________________
STEPHEN COVINGTON OWNER OF E.T.M.C.
Turbos,nitrous,superchargers,Hand Porting and Polishing of heads, fab work, and much more!!!!!
WWW.EASTTEXASMUSCLECARS.COM
East Tx Muscle Cars is online now   Reply With Quote
Old 01-25-2010, 10:40 PM   #34
TTBEAST
Junior Member
TTBEAST's Avatar
Old 01-26-2010, 11:01 AM   #35
baddgoat
Junior Member
I hear you about the tune. The one thats in there now is useable but not what id consider proper. Nothing beats a dyno for tuning. I wonder how loud the car would be with no cats and turbos as mufflers lol. Thanks for your reply.
take those cats out before they destroy themselfs,get a one peice stainless x pipe you will love the power and sound will be nice,I have built many gto rear twin turbo setups with headers, A X pipe and 3 inch stainless pipes back to the turbos, then out to the factroy tips, car sounded nice,not loud at all,guess it all depends on person,now I use mufflers after the turbos,love it.
I have also ran 13 psi to 15 on a stock ls2 for three years on 93 octain,TUNE is where its at,IMO spend thousands on parts and if its not tuned right,car might not ever run to its potential.
baddgoat is offline   Reply With Quote
Reload this Page STS Twin Turbo
Tags
c6, sts, turbo, twin, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
**** CARTEK/STS C5 Single Turbo is finished !! **** Dave_Busch C5 Forced Induction/Nitrous 124 12-19-2005 02:45 PM
STS Twin Turbo Introductory Pricing! tbyrne C5 Forced Induction/Nitrous 70 09-30-2005 11:24 AM
STS Twin Turbo Introductory Pricing! tbyrne C5 Parts for Sale/Wanted 67 09-13-2005 06:31 AM
STS TTi update: great news! Scubanme C5 Forced Induction/Nitrous 28 08-14-2005 04:09 PM
"Spy pics" of the upcoming C5 STS Twin Turbo! tbyrne C5 Forced Induction/Nitrous 33 07-01-2005 12:59 PM
"Spy pics" of the upcoming STS Twin Turbo! tbyrne Northeast 9 06-30-2005 11:37 AM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
