Showing off nitrous which kit?
Can anybody recommend a good nitrous kit for me? I have a 05 c6, a4.I am basically going to use the kit for showing off. Meaning purging the nitrous in the air, just for show! I would like to shoot 100 shot. Should I go wet or dry? I'm not going to get a tune because it's mainly for show. I would like it to function right if I decide to go to the track one day with it. Any advice, let me know!! Thanks
If you don't plan to shoot often, I'd go dry shot (easier to install). NX makes a good kit. Whether or not you plan to shoot often, I'd get tuned anyways. The few hundred you spend tuning may save you a blown motor, and it only takes one squeeze of the juice (setup incorrectly) to blow it all up. Buy the purge kit as well....
If its just for show, then just buy a purge sellinoid, and hook it up. If you really want to spray your car and make power, I'd go with a TNT 90mm power ring wet kit (I have one for sale right now in great condition) with that you can spray 75-200hp shot, it has proven to make more power than the other brands.
Get one of the dual bottle kits from nitrous outlet. And PLEASE do not have the mind set that you can just spray a 100 shot with no tune, and with out repercussions.
Good luck other wise.
-Brandon
-Brandon
