LMR Warhawk 440 TT W/4L80 Build
#142
Ok guys, we made the first pull this morning. Looks like the torque converter is way to loose. Wastegate only(5.8lbs) she made 600rwhp. The car went to 7200rpms and only 104mph in third gear. Looks like we will be waiting on a new converter.
http://www.youtube.com/watch?v=X1bacnPHC4g
#144
Power is close to where it should be though.
Keep chuggin! Good luck.
-Brandon
#145
After getting the car running its dead in the water again. The transmission had internal failure on the dyno, talk about things that will make the most patient person want to kick something. We have it out and it will be torn down tommorrow to find problem. But I did get a bit of good news today, my long anticipated fast lsxr showed up. So now we can change it out while waiting on the trans.
Im hoping to get this thing finished soon.
#149
Im not going to slam the people I bought the conversion from, but I am very unhappy to say the least. I was going to use a sheetmetal intake but was worried about heat soak since the car will be street driven alot, so I figured the fast was my next best option.
#151
Went ahead and started making some baby pulls, car put down 750rwhp on pump gas on only 8.4lbs of boost! Will turn her up a little bit and get some dyno vids beginning of next week!
#155
I wish I had more numbers to report, but I dont. The APS fuel system wasnt up to the task. So I figured why it was up on the rack waiting for the new fuel sytem I would shoot some pics of the bottom of the car.
#159
Im using B&B fusions, I ve heard the aps exhaust had alot of drone. Im only running the exhaust on the street on a low boost setting. The exhuast was built to be easily removed for the track.
