C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
How much RWHP can the Stock LS7 block handle?
Old 08-15-2008, 03:23 PM
stanklr
stanklr's Avatar
Default How much RWHP can the Stock LS7 block handle?
just wanted to know How much RWHP can the Stock LS7 block handle? 600rwhp? 700rwhp or more?
If i wanted to build a +++800rwhp car with an ls7 engine ( LS7 block ) what do I need to change to make it handle that kind of HP?
Sorry for the noob question
Thanks in advance
Old 08-17-2008, 03:17 AM
tlaselva
tlaselva's Avatar
Lingenfelter has run 1500+ hp & torque with the LS7 blocks in several of their customer's Z06's, w/o any block related failures, so 800rwhp&tq shouldn't be a problem.
Old 08-17-2008, 03:34 AM
o0 zeno 0o
o0 zeno 0o's Avatar
There's no way a stock LS7 block can handle 1500+hp and torque.
For 800+hp you will need darton sleeves, lsx block, or warhawk block.
Or better advice, ask your tuner. If you trust them to make 800+whp, you should trust them to tell you what you need to do it. But they're going to say the same thing. Stock block won't do it.
Old 08-17-2008, 03:54 AM
SpeedyD
SpeedyD's Avatar
900 plus can easily be done on a stock LS7, I don't know about 1500, but those blocks are good up to a 1000 or more. Nick Yoskin is running 1005 on an auto through a stock LS7.800 plus should't be an issue
Dan
Old 08-17-2008, 04:20 AM
Mr.Big
Mr.Big's Avatar
as zeno said... LS7 block can do it (1000+), WITH Darton sleeves...
Old 08-17-2008, 07:30 AM
aTX427
Guest
Posts: n/a
The block yes, the sleeves no. Have R.E.D or Katech resleeve the block. I am not sure what Katech uses, but the LS2/LS7 Darton sleeves are a little longer, which will allow you to use much stronger pistons than the stock length sleeves.
Old 08-17-2008, 11:38 AM
Vindication
Vindication's Avatar
Dont forget ERL who did a awesome job on my LS7 block.
Old 08-17-2008, 01:16 PM
0Taylor@DallasPerformance
Former Vendor
Taylor@DallasPerformance's Avatar
ERL would get my vote as well...
Old 08-17-2008, 02:15 PM
EdwardETraylorIII
EdwardETraylorIII's Avatar
I've consistently made 1,150-1,200 at the wheels on two of my STOCK BLOCKED (with all forged internals and of course studs EVERYWHERE) TT Z06's.
However, when the builds started out this much power was not my goal (we wanted 900-1,000 RWHP). It was just fairly easy to hit these numbers with Twins and Nitrous...
I'd say my luck has been better than average due to ZERO detonation (due to damn near perfect tunes on each car!). I'd say you can get away with 21.5, MAYBE 22.5 PSI before the 4 bolt heads start lifting and the block integrity becomes an issue.
Hope that helps!
Old 08-17-2008, 02:37 PM
Vindication
Hope that helps!
I've asked once and I'll ask again where are the sheets!?!?
Old 08-17-2008, 04:13 PM
stanklr
stanklr's Avatar
So what if I used forged internals with the Stock LS7 block? will it handle 800rwhp or a little more ?
Old 08-17-2008, 04:21 PM
o0 zeno 0o
o0 zeno 0o's Avatar
There's no way anyone with any sense would recommend that much boost with an aluminum block with walls that thin. That's just asking for problems.
Old 08-17-2008, 05:23 PM
Jorday
Jorday's Avatar
Keep in mind guys that surviving through some dyno runs is different from lasting through several years of being beaten on and raced.
If it was me, I wouldn't go over about 800 on the stock block with only studs and forged internals as the upgrades.
Old 08-17-2008, 09:09 PM
Mr.Big
Mr.Big's Avatar
Best rep on the block... No pun...
Old 08-18-2008, 01:59 AM
EdwardETraylorIII
Vindication, I'll put a couple up for you sometime this week when I return from TDY. I don't recall you ever asking me for a dyno sheet? However, senility has set in, and I could be wrong.
Old 08-18-2008, 10:40 AM
RoadRebel
RoadRebel's Avatar
I have so many 800-900rwhp pump gassers running around on stock LS7blocks I dont even think about it anymore.
Phil
Old 08-18-2008, 10:42 AM
tlaselva
tlaselva's Avatar
I'll take Lingenfelter's years of experience with the LS7 over yours.
To How much RWHP can the Stock LS7 block handle?
Old 08-18-2008, 02:09 PM
o0 zeno 0o
o0 zeno 0o's Avatar
Exactly where are these 1500+hp cars from Lingenfelter that you speak of, and what makes you think they are using stock unmodified blocks...
The highest package they sell is 1000bhp, which would only translate 800-820whp.
Old 08-18-2008, 03:45 PM
EdwardETraylorIII
0o (and other disbelievers)- just a little more fuel for this fire...
I layed down over 1,000 ft lbs of torque on PUMP gas with a STOCK LS7 NON-SLEEVED block last night shortly after I made the post before this one.
Worth noting, that motor has well over 8,000 miles on it at this power level and it brutalized every day of the week. Still running STRONG! The piece de resistance - it's a Nitrous motor!
Old 08-18-2008, 04:41 PM
06.Z51.MontRed.Vert
06.Z51.MontRed.Vert's Avatar
Location: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
Quick Reply: How much RWHP can the Stock LS7 block handle?
