1000 RWHP 427 Warhawk Z06 Build Begins
Well here goes , you know I had to do it, and although the thread is gonna be quite for a few weeks, except that ill make sure to update this on a regular basis with the build details, parts, my crazy ideas all with pictures and videos in that case whether engine mods or cosmetic everything will be documented over here.
Estimated parts delivery time: 10st of September
Estimated Completion time: [Edit: delayed] End of September.
HP Target: 1000rwhp on race gas (bragging rights)
Otherwise: 900+ RWHP on 93 octane fuel, no meth or additives.
Build overview:
- 427 CI LS7X Warhawk aluminum block @ 9.0:1 compression ratio + 6bolt heads.
- Power Adder: TTi C6 Z06 Twin Turbo kit @ 15lbs of boost.
- A&A Fuel system
- 95lbs low-impedance injectors + Versafueler converter
- Custom fabricated exhaust utilizing stock butterfly valves.
- Custom designed exhaust valve control by throttle position.
Cooling:
- Ron Davis/Dewitts aluminum radiator + built in engine oil cooler
- 80% distilled water + 20% anti corrosion coolant mix.
- 160 degree thermostat.
- Plus one of my custom cooling creations
Power Delivery:
- Spec twin-disk clutch
- 345 Nitto Invos
Tuning:
- EFILive/ HPT havent decided yet
Goals:
- Streetable daily drivable monster vette, infact WILL be daily driven.
- A car that will actually go straight instead of sideways with that power. In order to acheive those results, boost will be mapped 3D using an HKS controller for boost vs throttle position vs vehicle speed delivering the maximum power that the rear tires can handle at every speed/gear.
Cosmetic mods:
- 360 Forged Spec Multi wheels
- World challenge triple louvered hood
- MTI racing front chin spoiler
- Boost + wideband gauges and gauge pod
- Alcantra roof covering the pillars + gauge pod.
A big thanks goes to Ed Potter from Late Model Speed who is supplying the parts from long-block to boost gauge.
Pics will follow + hopefully a video of the engine in an engine dyno (minus turbos).
Estimated build cost: $50+K
Build overview:
- A&A Fuel system
Cooling:
Power Delivery:
- 345 Nitto Invos
Tuning:
Goals:
Cosmetic mods:
I'm worried that the 63's won't be enough, Mine were maxed out at 800rwhp... I would consider, an AEM (or brand X) converter and some bigger low z injectors in addition to the A&A fuel system...
You will be fine with 63 Lbs/hr with 1,000 RWHP. You will have to run them at 90& Dudy Cycle but fort 10 seconds at a time this is ok.
Mr. Big is correct, you are going to need a bigger injector then that...why take a chance on pushing a part that hard when you can have some piece of mind for the cost of the impedance converter?
The RC Injectors you have chosen are 63.5 Lbs/Hr (rated @ 43.5 psi) are now rated at 80.55 Lbs/Hour at a new fuel pressure of 70 PSI, giving you a potential of 1031.04 horsepower at a duty cycle of 80% and a bsfc of .5.
No idea, still researching.
As an experiment, call AEM and ask to speak with the guy who designed their box. Ask to see the thermal loading calculations that drove their heat sink design. Ask if their design includes a timer circuit that will switch from peak current to hold current in the event the injector current does not reach the target peak value. If it does, ask about the time constant calculations.
I can discuss those and all the other design aspects with anyone who's interested in hearing about them.
Or you can just blindly buy from the big name on the assumption that the bigger company has the better product.
Jeff
If you want your 63.5 lb/hr injectors to behave like 80.55 lb/hr injectors as in the quote above, you'll have to set your fuel pressure at 70 psi plus whatever your boost is. For example, if you're at 25 psi of boost, your fuel rail pressure will have to be 95 psi.
Now consider that there is always a pressure drop in fluid systems that increases as the flow rate goes up. This means that your fuel pump will have to create more than 95 psi in order to end up with 95 psi in the rails. There aren't many reasonably priced pumps out there that have a high flow rate at 100 psi. The flow rate for all pumps goes down as the pressure goes up!
My 'Brand X" advice is to look for an injector in the 85 to 95 lb/hr range. Roughly 80% of the injectors I sell are 95 lb/hr. That's what I ran in the Camaro in my avatar, which I drove to work and which ran a best of 9.47@148 at Sacramento using the factory LT1 PCM.
Jeff
Former Vendor
True, that does mean his system could see 85psi at the rail with the 15psi boost he plans to run.
Fwiw, not sure what pumps he plans to use but we have used twin Walbros at 5bar (73.5) base pressure +20psi boost at the 950rwhp level and they had no problems supporting that flow requirement with 93.5psi at the rail.
just as a reference, I run a Fuel Lab brushless 1800hp pump, and my Mototron 60's were maxed at 800rwhp with boost + N2O... My current fuel system has just about every bell and whistle you would ever want/need on a street car with less than 1500rwhp...
I wish I knew about 9secz and his product sooner, this week was the first time I was aware of the situation AEM put him in. Being a business owner, I try to do business with the "small guy" when I can. I'll consider his product in the future when I learn more about it...
Former Vendor
We've had the RXT in a twin turbo 95 Cobra for 2 years now. The car makes 1075rwhp and ran 9.2 @156 at the track with a 3700lb raceweight. Not a single problem with the clutch so I expect to have similar results in a Z.
Not the best vid in the world but you can hear it launch off the 2-step and pull the left front on the 1-2 shift
http://www.youtube.com/watch?v=3ErD-HUL9Hk
I had a Twin Mcleod on my Cobra that made 600 rwhp. Awesome clutch no doubt. Just like i said before not easy to put on a C6.
