Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-26-2008, 01:53 PM   #1
jleonhar
Junior Member
jleonhar's Avatar
Default Calling all Maggie Owners
Tried to cut down the engine covers and am having issues , please post pictures of your successes with tips and tricks or post an alternative solution please.
Thanks for the support in advance.
jleonhar is offline   Reply With Quote
Old 01-26-2008, 06:23 PM   #2
vettl83
CF Senior Member
vettl83's Avatar
Lingenfelter has em and so does Callaway. The Lingenfelter ones can be had color matching and the Callaway ones you have to paint. They are both expensive 500.00 + smackers by the time the smoke clears. Far as I know they are the only ones that have em made to fit the Maggie. I bit the bullet and ordered the Lingenfelter ones in A/O.
vettl83 is offline   Reply With Quote
Old 01-26-2008, 08:33 PM   #3
1bdasvt
CF Senior Member
St. Jude Donor '06-'09
Support Corvetteforum!
1bdasvt's Avatar
Quote:
,I did the same!!
1bdasvt is offline   Reply With Quote
Old 01-27-2008, 12:29 PM   #4
Bushong572
CF Senior Member
Bushong572's Avatar
I have the LPE covers also.........You might try a search, I saw a post last year where someone cut the top 1/3 off with a bandsaw (he said it was easy....looked good). I know the LPE and Callaways are high, but they sure look nice. Good luck.
Bushong572 is offline   Reply With Quote
Old 01-27-2008, 12:34 PM   #5
Bushong572
CF Senior Member
Bushong572's Avatar
This should help.........
http://forums.corvetteforum.com/show...el+rail+covers
Old 01-27-2008, 02:25 PM   #6
mcv
Platinum Supporting Vendor
mcv's Avatar
Here are pictures of the Callaway covers for 2005-2007 Corvettes with Magnachargers. They're molded from fiberglass, not cut-down stock covers.
They have steel mounting brackets bonded to the back side and come with OEM grommets and extra coil bracket standoffs for OEM-like installation.
Part No. 210.60.3048
Sugg. Retail Price: $480.
They're available at Callaway Authorized Dealers, or on Callaway's Online Store.
The Callaway decals come only on Callaway Corvettes and C16's.
mcv is offline   Reply With Quote
Old 01-27-2008, 03:52 PM   #7
jleonhar
Junior Member
jleonhar's Avatar
Thanks for the link. I just completed cutting them like Marct6444 did and they pretty good for a cut down piece. Now I can wait a bit before buying the Callaway covers (expensive). I am so inspired now I may just clean these up a bit more, give them a shot of Millennium Yellow and see how they look. Sounds like a next weekend project. [/font]
Tips for others who may be in the same boat[/font]
1) be aggressive and do not be afraid to cut allot off. I ran the cut line at the bottom of the corvette embossed section taking off at least 1/3. They now just say LS2. Band saw would work best; I used a coping saw and did it by hand. Cleaned up with a Dremel tool. [/font]
2) The hole for the stainless line needs to be expanded as the line shifts back to the rear. Just follow the current line down to make a larger square opening. [/font]
3) You need to cut some off the front to fit it past the power steering tank. About 1 1/2 inches does the trick[/font]
4) On the front of the driver’s side you must trim a little to clear the cables. Just cut the corner down about an inch. [/font]
5) it is held on only but the two mounts now but it seems very solid. [/font]
I still need to clean mine up but I am going to wait until they come off again for paint. Thanks for all of the help on the forum. If I could figure out how to post a picture I would.
Old 01-27-2008, 08:49 PM   #8
Gene Gorman
CF Senior Member
Gene Gorman's Avatar
Here is a picture of mine. Cut down silver carbon fiber from TKO.
[IMG][/IMG]
[IMG][/IMG]
Gene Gorman is offline   Reply With Quote
Old 01-29-2008, 04:38 PM   #9
vvette_c6
CF Senior Member
vvette_c6's Avatar
Send a message via MSN to vvette_c6
www.magnacharger.com
vvette_c6 is offline   Reply With Quote
Old 01-30-2008, 02:02 PM   #10
MADMAX1
CF Senior Member
MADMAX1's Avatar
Quote:
Originally Posted by 1bdasvt View Post
,I did the same!!
MADMAX1 is offline   Reply With Quote
Reload this Page Calling all Maggie Owners
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
