Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-24-2008, 12:15 PM   #1
csun213
CF Senior Member
csun213's Avatar
Default Msd Vs Kb Bap
Hi guys, I am going to purchase a BAP as insurance for my C6. Just wondering which one people prefer and which one is better between the MSD and KB boost a Pump? Thanks
I am also going to post this in the tech section.
csun213 is online now   Reply With Quote
Old 01-24-2008, 01:27 PM   #2
Tuner@Straightline
Premium Supporting Vendor
Tuner@Straightline's Avatar
We only use the Kenne Bell unit, and have been with great success for years. No experience with the MSD unit unfortunately.
__________________
Mike Hornback @ Straightline Performance
815-485-7741
New Lenox, Il
Email: Sales@1320hp.com
Tuner@Straightline is offline   Reply With Quote
Old 01-25-2008, 12:35 AM   #3
HyeSpeeder
CF Senior Member
I have installed many MagnaVolt BAP and never had a problem they are a very slick design and look great under the hood.
Gev
HyeSpeeder is offline   Reply With Quote
Old 01-25-2008, 01:44 AM   #4
csun213
CF Senior Member
csun213's Avatar
Quote:
Gev
I have not heard much about MagnaVolt BAP. Do you like it over the MSD and Kenne Bell?
Old 01-25-2008, 03:39 AM   #5
Brabus2
CF Senior Member
Brabus2's Avatar
Quote:
I've used the MagnaVolt for little over a year now and no issues, previously used the KB BAP also with no issues. My suggestion on the KB BAP, mount the controller were you can keep an eye on it or at least a decent view of it, mine was under the dash and since there is no locking mech. on the knob I found the knob on some occassions not in the proper setting. There were times before I go WOT, I would reach under just to make certain.
__________________
2001 Brabus EV8 Kompressor
2002 S500 Sport
2007 Chyrsler T&C Limited
2006 Brabus ML500 B11
2005 C6 LAPD/APS Twin Turbo 402 cid -sold
Meth-dual nozzle, Blitz i-Color, WCCH LQ9, 230/230 115LSA, FAST 90, Wilwood BBK, LPE hood, Hotchkis bars, PFADT Coilover, LS7 Clutch, Cobalt gauges & shift light, Callaway shifter, Bullets, Z06 Time Attacks & rear fenders, 2bar SD tune.
2009 SL65 AMG (Brabus Tuned)
Brabus2 is offline   Reply With Quote
Old 01-25-2008, 01:03 PM   #6
HyeSpeeder
CF Senior Member
Yes i like it over the msd and kb.
The magnavolt is not only boost reference but it picks up rpm too.
I have installed at least over 15 magnavolts and never had a problem.
I mount it next to the fuse box under the hood.
Old 01-25-2008, 03:15 PM   #7
csun213
CF Senior Member
csun213's Avatar
Where do you purchase the Magnavolt BAP?
Old 01-25-2008, 03:36 PM   #8
Brabus2
CF Senior Member
Brabus2's Avatar
Los Angeles Performance Division (LAPD) - 818.998.3966, speak with Keith.
There in-house tuner Doug worked for Magnuson for many years and was involved with the engineering process of the MagnaVolt.
Replied to your PM.
__________________
2002 S500 Sport
Old 02-07-2008, 01:14 AM   #9
jhaines
Supporting Vendor
Default Fuel pump voltage booster
We have tested the Kenne Bell, the MSD and the Magnuson.
We have used the Magnuson and the Kenne Bell. We use the Magnasun Magnavolt on some of the Magnuson supercharger kits but we have been using the KB Boost-A-Pump for longer since it was out before the Magnavolt so that is the one we use more often (mostly just because we have more time and experience with it). For some of fuel pumps that pull a lot of current when run at high voltages (20+ amps), the Magnavolt wouldn't be compatible either since I don't think it is designed for those types of current loads.
For high boost, smaller engines the MSD one would probably work well. For the relatively low boost levels (5 to 15 psi) that we run on most street supercharged and turbocharged LS series engine packages, we couldn't get the voltage boosting we wanted because the MSD uses an internal boost pressure sensor and even at the maximum voltage per psi of boost gain, it didn't get us to the voltage we needed at the pump. We did this testing several years ago so MSD may have changed the design to increase the adjustment range or may now offer one with a different adjustment range (compared to the one we did our testing with).
__________________
Jason Haines, Project Director
Lingenfelter Performance Engineering
www.lingenfelter.com
jhaines is offline   Reply With Quote
Reload this Page Msd Vs Kb Bap
Tags
adjustments, bap, bell, boost, c5, c6, corvette, kb, kenne, kennebelle, magnavolt, msd, problems, pump, supercharger
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
