Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-21-2008, 09:18 PM   #1
ayousef
CF Senior Member
Send a message via MSN to ayousef
Default HKS SSQV BOV help - urgent
Got it, and I was told by a few that it should work fine with Vortech supercharger applications, can anyone confirm that as my tuner told me it might not work properly given its a Turbo BOV. Ideas?
Ill have to install it in a few hours so comments would be appreciated.
ayousef is offline   Reply With Quote
Old 01-21-2008, 10:00 PM   #2
07MontRedcp
CF Senior Member
Support Corvetteforum!
07MontRedcp's Avatar
I have no definitive answer for you but I do have two question that may help.
1. How would the BOV know that the boost it is seeing is produced by
Turbos?
2. How did you resolve the injector size problem? As I remember your
tuner said you needed to junk the 60# for 42#.
BJK
__________________
APS TT 630 rwhp/654 rwtq @ 9 psi
'07 Z51, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, GT2 Coilovers, Autometer Cobalt Fuel & Boost Guages, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system.
07MontRedcp is online now   Reply With Quote
Old 01-21-2008, 10:06 PM   #3
jersey jay
Moderator
National Events Coordinator
N. Jersey Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
jersey jay's Avatar
You'll be fine using it in either or.
jersey jay is offline   Reply With Quote
Old 01-21-2008, 10:18 PM   #4
ayousef
CF Senior Member
Turbos?
BJK
1- The difference I am concerned about is not under WOT, but in idle and cruise, a turbocharger would need LOAD to get the turbo spooling, in a few cars, you can drive at 4000RPM with VERY VERY little boost, and at 4000RPM with full boost depending on the throttle. With a supercharger I guess there isnt anything you can do about it, 4000RPM is 4000RPM whether full throttle or partial given the SC is directly connected to the engine, and will produce power by RPM, which means at partial throttle high-rpm the BOV has to dump excess air outside, again MAYBE. But in general thats the main reason for asking.
2- I did work out the tune, the car is better now, not SOO much better but noticeably, I travelled and we had very bad weather before that so I did not have the chance to fine tune it, which Ill do in the meanwhile, thankx for your concern, still I don't think the car would run as perfect as one with smaller injectors, in this case 48 to 50.
Old 01-21-2008, 10:20 PM   #5
Brabus2
CF Senior Member
Brabus2's Avatar
Professor Perry (C6Dude) previously used the same HKS unit on his ProCharger setup (currently a Turbosmart BOV), give him a holler...his knowledge & experience I trust!!!
http://forums.corvetteforum.com/show...hlight=hks+ssq
__________________
2001 Brabus EV8 Kompressor
2002 S500 Sport
2007 Chyrsler T&C Limited
2006 Brabus ML500 B11
2005 C6 LAPD/APS Twin Turbo 402 cid -sold
Meth-dual nozzle, Blitz i-Color, WCCH LQ9, 230/230 115LSA, FAST 90, Wilwood BBK, LPE hood, Hotchkis bars, PFADT Coilover, LS7 Clutch, Cobalt gauges & shift light, Callaway shifter, Bullets, Z06 Time Attacks & rear fenders, 2bar SD tune.
2009 SL65 AMG (Brabus Tuned)
Brabus2 is offline   Reply With Quote
Old 01-21-2008, 10:27 PM   #6
ayousef
CF Senior Member
I was told by him that its fine, and thats the only reason why I bought it, but I wanted to make sure
Old 01-21-2008, 11:18 PM   #7
Brabus2
CF Senior Member
Brabus2's Avatar
Quote:
Good stuff. I recall talking to Brian at ICS, he uses the HKS SSQV on his ProCharger C5Z and very happy with it. On my previous ProCharger setup I used the Vortech Race Valve, during light-moderate throttle I had fluttering issues, it required some adjustment on the stop nut (top of the valve) to eliminate this. The HKS unit was my second choice.
__________________
2002 S500 Sport
Old 01-22-2008, 12:16 AM   #8
dgcarver
CF Senior Member
dgcarver's Avatar
Default I'm Confused (Not the first time)
The BY_PASS valve that comes with the Procharger kit is normally open until the vacuum reachs about 2psi. This is to reduce the amount of air the engine sees at lower RPMs and loads.
A BOV is normally closed until the set pressure is acheived and then it opens to bleed excess air to limit the maximum pressure.
Boost on a supercharger is a function of the pulley and supercharger gear ratio. Boost on a turbo is a fuction of turbo capacity, engine RPM, and exhaust gas flow and that is why you need a BOV to limit the boost on a unit that has higher capacity than you want.
So what type of BOV is everyone using on supercharger applications and does it function to open on boost or close on boost?
__________________
2005 VR, Z-51, Six Speed, Procharger D1 @ 8 psi, piller mount vacuum/boost/wide band gages, LPE hood, Z06 Rear fenders, 160 deg T/S, LG Motorsport headers w/cats & X-Pipe, Magnaflow axle back exhaust, Chrome Z06 Wheels, Z06 Brake Upgrade w/SS lines, Full VR GM Spoiler, KP BAP w/Racetronix wiring harness, DPE Procharger 2 minute oil drain kit, Michelin Runflat Pilot Sport 345/30/19 Rear, 275/35/18 front, Halltech CAI, Tuned and Dyno'd with HPT at 535 rwhp 489 rwt by LG Motorsports
dgcarver is offline   Reply With Quote
Old 01-22-2008, 12:22 AM   #9
ayousef
CF Senior Member
thats a WASTEGATE, all BOV's open to bleed boost when you lift, to prevent that air that gets trapped as the throttle body closes from flowing back to the turbo & causing turbo surge - which apparently is bad for the turbo headunit, and slows you down as well (it sounds cool though).
but again a BOV does not stay open until boost reaches 2PSI, it would be hard for people running low boost like me (4PSI) to build boost if that thing doesnt close, it might have a function of being partially open at cruise to release excess air though.
Old 01-22-2008, 06:00 PM   #10
Drag_Knight
CF Senior Member
Drag_Knight's Avatar
Yes the HKS will work fine on car. Its designed to remain completely closed under idle and will hold to 30+psi without leaking.
thats what im using on my TT car now. (Not a vette ). And i also have a friend running the HKS on his built/procharged LS1
__________________
FASTER & FASTER UNTIL THE THRILL OF SPEED OVERCOMES THE FEAR OF DEATH...
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."
Drag_Knight is offline   Reply With Quote
Old 01-23-2008, 12:08 AM   #11
Mr.Big
CF Senior Member
Mr.Big's Avatar
currently running one as well, works great at my current boost level...
__________________
Jeremy
Dallas/Valley Ranch Tx
1070+rwhp930+rwtq Boost ONLY
Dallas Performance custom F1R system, D.P. Forged 370, ALKY Control/D.P. Triple nozzle, D.P. E85 fuel system, Wilson Billet intake, D.P. Direct Drive + 10rib, WCCH 317's, D.P. Blower cam, HPTuner, D.P. '09 rearend, TR6060, Mcleod "sintered" twin, THANKS to www.dallasperformance.com
Mr.Big is offline   Reply With Quote
Old 01-23-2008, 01:41 AM   #12
MachineWorks
CF Senior Member
MachineWorks's Avatar
I used a 50mm Tial, you will have to weld the bung on to your up pipe.
MachineWorks is offline   Reply With Quote
Reload this Page HKS SSQV BOV help - urgent
Tags
bov, c6, corvette, forum, hks, problem, problems, procharger, ssqv, supercharger, superchrger, vortech, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
