Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-19-2008, 01:45 PM   #1
vvette_c6
CF Senior Member
vvette_c6's Avatar
Send a message via MSN to vvette_c6
Default running 3.1 pully ( magnacharger ) professional help
hey guys ,,, i am running 3.1 pully ,,, instead for 3.4 ( 5 psi )
but my car is posting 5 psi only !!!
any ideas because of what ?
__________________
C6 Z51 Package M6
Procharger F1C | Custom camshaft l | AFR 72CC heads | 403 Stroker
FAST 92 MM intake | Wet Nitrous Direct Port ( fogers ) | Headers kooks 1 7/8
X pipe + cutback C6 Zo6 | F1-C 11PSI | Ram Twin Disk | Custom fuel System | 75 Shot if Dry Nitrous on F1-C cooler | ARP STUD | Moizer water Pump | Flip Drive | FAST 92 has killed me by leaking air and losing Boost !
RWHP 720 | RWTQ 725 On Dyno Jet ( with Drifiting on dyno)
vvette_c6 is offline   Reply With Quote
Old 01-19-2008, 04:27 PM   #2
vvette_c6
CF Senior Member
vvette_c6's Avatar
tttttttttttttttttttttttttttttttttttttttt t
__________________
C6 Z51 Package M6
Old 02-16-2008, 10:27 AM   #3
vvette_c6
CF Senior Member
vvette_c6's Avatar
any body knows what should i expect Psi when i run 3.1 on C6 Z51 364 engine ?
__________________
C6 Z51 Package M6
Old 02-16-2008, 11:02 AM   #4
Bushong572
CF Senior Member
Bushong572's Avatar
Need more info.........are you running headers? changed cam? What 3.1" pulley are you running?
Headers and a blower cam will lower your boost........the stock 3.4" is good for 5-5.5 lbs with stock exhaust manifolds. I've also seen some low grade pulleys that are not the actual diameter that's stamped on them. Also, have you tried another boost gauge (to make sure yours is accurate). Even with headers and a change in cam.....I think you should be making 6-6.5 lbs with a 3.1"
Bushong572 is offline   Reply With Quote
Old 02-16-2008, 12:45 PM   #5
blownchevy
CF Senior Member
Yes, more info please
blownchevy is offline   Reply With Quote
Old 02-16-2008, 04:01 PM   #6
vvette_c6
CF Senior Member
vvette_c6's Avatar
i am running headers 1 7/8 kooks long tube
my camshaft now is blower camshaft duration intake 222 exhust 228
Lift intake 566 exhust 571 lope 114
camshaft ls1 speed for blower
SC2 224 232 .581 .595 114 SC2
i tried the boost gage in another car and it was posting fine
now i will change my adjustable tensioner pulley
but thats good
i had the answer for my question which is i should expect 6 to 6.5 on 3.1 pulley
please guys i will start a new thread and i really need help and please guid me for a professional person who can help me
many thanks
__________________
C6 Z51 Package M6
Old 02-16-2008, 10:09 PM   #7
blownchevy
CF Senior Member
There are plenty of professionals here to help, no need to start a new thread. I would suspect that your cam selection along with the headers and free flowing exhaust might have some impact on your boost levels.
A few questions that I need answered:
1) Did you use the pinning kit for the balancer?
2) Where are you getting your boost readings?
3) Are you using a factory balancer or an after market "under drive" pulley?
4) Are you sure you are using the proper pulley? As stated above, some "after market" pulleys are not to exact specifications.
A 3.1 pulley on a stock 364 CI motor will yield approx 5-6 psi with the MP112, more than likely your cam/header selection is causing the boost to read lower. What you need to remember is you are still moving the same amount of air, just more efficiently. Boost is a measurement of restriction.
Old 02-17-2008, 04:12 AM   #8
96Magnuson
CF Senior Member
Support Corvetteforum!
96Magnuson's Avatar
I make 7lbs with my 3.1...
96Magnuson is offline   Reply With Quote
Reload this Page running 3.1 pully ( magnacharger )
Tags
c6, magnacharger, mp112, psi
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
