Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-15-2008, 03:56 AM   #1
ayousef
CF Senior Member
Send a message via MSN to ayousef
Default Oilcooler blocking intercooler - AFR question
how bad is that really? I got my Stock oil cooler sitting in front of the intercooler.
So if Colder air = denser air = more power, then am I loosing power by having the oil cooler sit infront? Should I waste my time looking for another place to throw the oil cooler at, will I see a "gain"
also, im posting my dyno chart, please dont comment about the RWHP number, in simple words a STOCK Z06 dynos 366 RWHP on this dyno.
So the question is, do you recommend a re-tune and in turn leaning the AFR? The highest point on this graph which is about 11.5:1 at the pipes, read out 10.8:1 at the collector, do the maths
Any power left on the table?
ayousef is offline   Reply With Quote
Old 01-15-2008, 08:46 AM   #2
EuroRod
CF Senior Member
EuroRod's Avatar
My tuner told me that the optima AFR for FI at WOT is 11.7. From the sheet, looks like you're running pretty rich. Good luck.
EuroRod is offline   Reply With Quote
Old 01-15-2008, 12:35 PM   #3
eboggs_jkvl
CF Senior Member
eboggs_jkvl's Avatar
A 10 A/F is mighty rich for a stock car. Hells fire, I run a 12.2 on a twin turbo 550RWHP LS6 Camaro. Your not losing power because of the air supply or colder air, that A/F would kill anything. I'd lean that puppy out a tad.
Elmer
eboggs_jkvl is online now   Reply With Quote
Old 01-15-2008, 03:35 PM   #4
ayousef
CF Senior Member
Quote:
Elmer
not stock supercharged, this thing is still pig rich I know, however cant you not compensate for the power loss of running a rich mixture by bumping up timing?
Old 01-15-2008, 04:17 PM   #5
eboggs_jkvl
CF Senior Member
Quote:
To be totally truthful, that A/F simply looks bogus. NOTHING hits a flat line like that. It looks like it goes to 10 OR MORE and simply drops dead at 10 but I'm thinking it is dropping further. Any WOT A/F that I've ever seen, has variance in the number. The variance might not be +/- .1 or .2 but it doesn't flat line like that.
Elmer
Old 01-16-2008, 03:52 AM   #6
ayousef
CF Senior Member
Elmer
look at the blue line not the red one, the red one is the BEFORE tune etc... The line is so flat because this is the smallest number the wideband attached to the car could read
still there is as I could see a 0.3-0.4 variance between tail pipe measured AFR and as measured at the collector.
Old 01-16-2008, 11:43 AM   #7
eboggs_jkvl
CF Senior Member
HEY! Look at the color of my car! I only see red! The blue is exactly what I referred to as realistic.
Ok, I'll be quiet now
Old 01-17-2008, 07:18 AM   #8
0EPP
CF Senior Member
We shoot for an air/fuel ratio with forced induction in the 11.5/1 range at wide open throttle, with wot timing at approx 18 degrees. We always weld a bung into the exhaust at the headers, tailpipe readings can be bogus especially on an exhaust system that is not 100% welded, as outside air can get sucked in around the seams under wide open throttle.
We normally use NGK TR6 4177 spark plugs, gapped at .035.
I'd start here and see what you have. Bob
EPP is offline   Reply With Quote
Old 01-17-2008, 11:08 PM   #9
snitz
CF Senior Member
Support Corvetteforum!
snitz's Avatar
To address the original post, placing an oil cooler directly in front of the intercooler sounds like a bad idea to me. If the intercooler doesn't get plenty of fresh air it will heat soak and you sc will be useless.
I installed my oil cooler adjacent to the dual side mounted inter-coolers and also utilized a tiger shark front end to generate more airflow to the engine bay and appropriate components (radiator, intercoolers and oil cooler).
The result was a huge drop in coolant/oil temps and a massive increase in avail power on the track. This set up has been RR weekly all last year.
snitz is offline   Reply With Quote
Reload this Page Oilcooler blocking intercooler - AFR question
Tags
cooler, forum, front, intercooler, oil
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
