Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-13-2008, 11:43 PM   #1
csun213
CF Senior Member
csun213's Avatar
Default Low Fuel pressure
I have a 2006 C6 A6 with a Vortech supercharger. My fuel pressure gauge have always showed about 70-72psi at idle.
My C6 have been parked for about 3 weeks since the weather have been bad here. I drove it today and I noticed that my fuel pressure guage is now showing 60psi at idle. Can someone tell me why my fuel pressure have dropped 10psi since I last drove it? Thanks in advance.
I am going to post in the Tech section to see if anyone have seen this problem.
csun213 is offline   Reply With Quote
Old 01-14-2008, 01:25 AM   #2
BrooklynC6
aka allbottle¬hrottle
St. Jude Donor '08
BrooklynC6's Avatar
Location: Brooklyn New York The DVL and the chicken sleep with the fishes....
I have never seen fuel pressure as high as 70+lbs , 60 lbs is about right what you should have if you have a Boost-a-pump or secondary fuel pump .
I would get the gauge checked for accuracy .
BrooklynC6 is offline   Reply With Quote
Old 01-14-2008, 02:34 AM   #3
Brabus2
CF Senior Member
Brabus2's Avatar
Keep an eye on it and see if it continues to drop. What does it register at WOT? Sending units can go bad and register low pressure, you can try using another sending unit and attach a mech. gauge at the fuel rail.
__________________
2001 Brabus EV8 Kompressor
2002 S500 Sport
2007 Chyrsler T&C Limited
2006 Brabus ML500 B11
2005 C6 LAPD/APS Twin Turbo 402 cid -sold
Meth-dual nozzle, Blitz i-Color, WCCH LQ9, 230/230 115LSA, FAST 90, Wilwood BBK, LPE hood, Hotchkis bars, PFADT Coilover, LS7 Clutch, Cobalt gauges & shift light, Callaway shifter, Bullets, Z06 Time Attacks & rear fenders, 2bar SD tune.
2009 SL65 AMG (Brabus Tuned)
Brabus2 is offline   Reply With Quote
Old 01-14-2008, 09:38 AM   #4
excessive81
CF Senior Member
excessive81's Avatar
Send a message via Yahoo to excessive81
a mec gauge is a easy cheap way to make sure the electric one is working properly...oh and they look cool...lol
excessive81 is offline   Reply With Quote
Old 01-14-2008, 11:24 AM   #5
csun213
CF Senior Member
csun213's Avatar
I don't have a boost a pump since Vortech said that I did not need it. I have always shown 70-72 psi at idle.
Old 01-14-2008, 11:25 AM   #6
csun213
CF Senior Member
csun213's Avatar
Quote:
I did not floor it since I was worried about breaking something however my fuel pressure was at 47psi at 0.7lb boost.
Old 01-14-2008, 03:46 PM   #7
Brabus2
CF Senior Member
Brabus2's Avatar
I understand, and please have it check with your installer that's a significant drop from idle to boost. I normally drop a pound or two from idle to WOT. I didn't realize you weren't using a BAP up until now, I recall reading sometime ago you were looking to get one....maybe now it's a good time to add it to your FI setup with the irregularities in the fuel system on these cars, cheap insurance.
__________________
2002 S500 Sport
Old 01-14-2008, 04:41 PM   #8
csun213
CF Senior Member
csun213's Avatar
I actually purchased one but was told that I did not need it by both Vortech and my tuner therefore I sold it at a loss. Never had any problem at all until today. Now the fuel pressure is 10 psi than before at idle.
I guess I will be purchasing a Boost a Pump again.
Old 01-14-2008, 05:49 PM   #9
C6dude
CF Senior Member
C6dude's Avatar
Your gauge doesn't seem correct.
The OEM fuel pressure regulator is set to bleed out excess fuel after 60psi.
70psi at idle on a stock fuel sending unit is not right unless your fuel pressure regulator is bad which is Very unlikely. That is why I suspect a faulty gauge reading .
Like Brabus2 said, get a BAP it's good insurance.
I'm really surprised installers put blowers on customer cars without one.
I WOULD NEVER install a SC without one.
Some tuners/installers will cut corners by increasing the injector pulse width at higher RPM's instead of a BAP to try and make up for the decreased fuel pressure and volume that can barely meet the engines fuel demands.
That is not the optimum way to do it and you are playing with fire if your car is tuned like that.
Another thing to keep in mind is the fuel volume from your OEM pump will go down as you accumulate miles on your car from restriction in your fuel filter . That will starve your car of fuel at High RPMs when you need it most.
Good luck
Perry
__________________
My Youtube Videos : " DPE C6 "
C6dude is offline   Reply With Quote
Old 01-14-2008, 07:00 PM   #10
csun213
CF Senior Member
csun213's Avatar
Good luck
Perry
Thanks for your answer. I will purchase a Boost a Pump.
Does anyone know how to test if my fuel pressure guage is correct?
Old 01-14-2008, 09:59 PM   #11
excessive81
CF Senior Member
a mechanical gauge on the rail......i got a gauge and adapter to put on stock rail i will sell you if you interested. i got billit rails and running a diffrent setup now
Old 01-15-2008, 07:25 AM   #12
JFijolek
CF Senior Member
JFijolek's Avatar
Send a message via AIM to JFijolek
60lbs on the Vortech A&A kit
JFijolek is offline   Reply With Quote
Old 01-15-2008, 04:02 PM   #13
csun213
CF Senior Member
csun213's Avatar
Was told by Vortech that the fuel pressure gauge would need to be grounded to the engine. They said that I can check on the sending unit by discounting a white wire at the sending unit and put an Ohm meter between the white wire and the sending unit. If the reading is between 35-240 ohm then the sending unit is fine.
Can someone tell me where is the sending unit located? Thanks
Old 01-16-2008, 01:11 AM   #14
Brabus2
CF Senior Member
Brabus2's Avatar
Likely your sending unit is attach on the driver side fuel rail end by a 4 AN to 1/8" NPT adaptor.
__________________
2002 S500 Sport
Old 01-16-2008, 12:43 PM   #15
csun213
CF Senior Member
csun213's Avatar
Thanks, I will get someone to look at it. I am not too good with cars.
Old 01-17-2008, 07:10 AM   #16
0EPP
CF Senior Member
That is what makes this forum so great! All of the replies were right on! Bob
EPP is offline   Reply With Quote
Reload this Page Low Fuel pressure
Tags
03, attaching, corvette, fuel, gauge, gm, idle, low, lq9, pressure
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Any Ideas of what could cause low fuel pressure at the fuel rails? ZR_Don C4 Tech/Performance 14 04-08-2005 08:51 AM
Low fuel pressure c4_4ya C4 Tech/Performance 14 01-29-2005 03:13 AM
Paging REDC4CORVETTE about BG low fuel pressure switch skateparkdave C4 Forced Induction/Nitrous 9 01-02-2005 06:11 AM
Adjustable Fuel pressure - how? - and is this the right one for L98 ? Stingraynut C4 Tech/Performance 10 05-22-2003 09:47 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
