On the C6 kit you can get Novi 1500 with self contained option. It also uses a slinger but different then Procharger.
On Novi it centrifuges oil up into upper cavity then oil drains back onto gears to lubricate them. On Procharger it has a thin gear that centrifuges oil onto smaller or output shaft gear. The Novi is much quieter do helical gearing and slinger design.
I've often thought than the the oil cooler supply and return ports for the Z51 cars could be used for this purpose. My car is non-Z51. and I used a Lingenfelter adapter to supply and return to the oil cooler I installed. Seems this could be used to supply oil, and return it, for sc that need this. Sure would beat having to drill the pan for a return.
In addition the ECS kit uses an adapter plate at the oil filter, no tapping the oil pan, at least that was the way they did it the last time I checked.
Location: Providing the most proven supercharger kits for your C5&C6 609-752-0321
Actually we feed the head unit from a fitting on the side of the block, simply remove a Allen head plug and install the fitting and line. Or you could go self contained as said before, that option is up to you.
Location: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
Quote:
Any other questions feel free to ask.
This is the way to go for sure, simple oil changes!!
Quote:
I agree, we now have the option for self contained, but my car would be installed oil fed, do it once and it's done forever, no maintenance other than rear tires and normal scheduled work.
We normally modify the oil pan to return the oil to the pan.
Quote:
__________________
Jason Haines, Project Director
Lingenfelter Performance Engineering www.lingenfelter.com
