That is a great looking curve, but I was under the impression that a Maggie 112 on a stock LS2 would put out 125-130 in Tq and Hp over stock numbers (520-530). Also, do you do installations of Maggie's and how much? Also, without affecting dependability as much as possible, what would you suggest for head work, cam, ECM, trans, and torque converter when considering a Maggie? Last question, for a stock LS2 would you recommend a 122?
THANKS
A stock LS2 dynos (around) 350 rear wheel hp......a stock LS2 with a maggie (stock pulley at 5.5-6lbs of boost) dynos (around) 480 rear wheel hp. There's your 130 hp.
Quote:
To C_Williams@rpm. Looking for a tuner in Cali. Do you do installs and how much?
I know Charlie and his shop are both very busy and he may not have time to read all the posts here. I would give his shop a call or call his cell.
shop 1-888-755-5391 cell 1-661-607-7822
