Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-04-2007, 12:47 PM   #1
extremecorvette
CF Senior Member
Default What Plugs with Turbos??
Is there any one plug that works better with boost and what gap?
Has any one tried Pulstar Plugs?
http://www.pulstarplug.com/howtheywork.html
extremecorvette is offline   Reply With Quote
Old 11-04-2007, 12:50 PM   #2
eboggs_jkvl
CF Senior Member
eboggs_jkvl's Avatar
I use NGK TR6 gapped at .036 on my twins. Flawless performance.
Elmer
eboggs_jkvl is offline   Reply With Quote
Old 11-04-2007, 07:39 PM   #3
Brabus2
CF Senior Member
Brabus2's Avatar
Good results here with TR6.
__________________
2001 Brabus EV8 Kompressor
2002 S500 Sport
2007 Chyrsler T&C Limited
2006 Brabus ML500 B11
2005 C6 LAPD/APS Twin Turbo 402 cid -sold
Meth-dual nozzle, Blitz i-Color, WCCH LQ9, 230/230 115LSA, FAST 90, Wilwood BBK, LPE hood, Hotchkis bars, PFADT Coilover, LS7 Clutch, Cobalt gauges & shift light, Callaway shifter, Bullets, Z06 Time Attacks & rear fenders, 2bar SD tune.
2009 SL65 AMG (Brabus Tuned)
Brabus2 is offline   Reply With Quote
Old 11-04-2007, 09:37 PM   #4
1bdasvt
CF Senior Member
St. Jude Donor '06-'09
Support Corvetteforum!
1bdasvt's Avatar
Quote:
1bdasvt is offline   Reply With Quote
Old 11-06-2007, 01:37 PM   #5
extremecorvette
CF Senior Member
I just got off the phone with NGK and they told me to run a TR7IX 3690, its a colder plug and will take the 18-26 lbs of boost and high heat.
Old 11-06-2007, 02:51 PM   #6
eboggs_jkvl
CF Senior Member
Quote:
Next time mention the boost that's being planned. That is big boost. I'm only running 12.5 PSI.
Old 11-06-2007, 05:42 PM   #7
extremecorvette
CF Senior Member
Sorry, I just bought plugs today at Napa and had them order the full line of Royal Purple products for the car. I about died when I found out the cost of all the oil $247.00
12qt of XPR 10w40
5qt of Synchromax
3qt of Max Gear 75w140
2qt of Max EZ
1qt of Purple Ice
8 TR7IX 3690 plugs $48.00
Old 11-06-2007, 07:59 PM   #8
wewing
CF Senior Member
wewing's Avatar
NGK TR6IX gapped at .035 here.
wewing is offline   Reply With Quote
Old 11-06-2007, 11:26 PM   #9
TLewis4095
CF Senior Member
Send a message via AIM to TLewis4095
12qt of XPR 10w40
5qt of Synchromax
2qt of Max EZ
1qt of Purple Ice
Hi Nate,
I should have thought to mention the RP when we were on the phone....all products are great, except the motor oil. In our race engines we have seen several bearing failures w/RP. Their gear oil & other products seem fine, but we will not warranty our Xtreme builds if RP is used. Of all the oils, we still come back to M1 15w50 for our high RPM built motors.
We have seen a small HP increase w/RP due to how quickly it sheets off the cylinders, etc. But the only way to use it in our race motors is to change it after every run....and that is not practical.
We race year round all over the Eastern US and push our race motors day in & day out, and will not trust RP.
TLewis4095 is offline   Reply With Quote
Old 11-07-2007, 01:10 AM   #10
oldmansan
CF Senior Member
St. Jude Donor '09
oldmansan's Avatar
One of you is running 18-26 lbs of boost and another is "only" running 12.5 lbs of boost. Details please, as in compression ratio, octane, water/meth/whatever injection. Inquiring minds want to know.
San
oldmansan is offline   Reply With Quote
Old 11-07-2007, 11:23 AM   #11
extremecorvette
CF Senior Member
Quote:
San
I will post the WarHawk build once I get started on it 3 weeks.
Old 11-07-2007, 11:31 AM   #12
TLewis4095
CF Senior Member
He is doing all the right things w/all the right parts.
Old 11-07-2007, 10:19 PM   #13
oldmansan
CF Senior Member
St. Jude Donor '09
oldmansan's Avatar
Thanks.
San
Old 11-08-2007, 02:24 PM   #14
Pro Stock John
CF Senior Member
Pro Stock John's Avatar
Send a message via AIM to Pro Stock John
NGK TR8's, 20-26psi.
Pro Stock John is offline   Reply With Quote
Old 11-08-2007, 03:04 PM   #15
TLewis4095
CF Senior Member
The more boost, the cooler plug.
Reload this Page What Plugs with Turbos??
Tags
napa, tr7ix
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Completed Ptk Project Pics babala65 C5 Forced Induction/Nitrous 124 08-25-2005 10:52 PM
So is it LT5 history or an LT5 Landmark???? MrCrowley C4 ZR-1 Discussion 203 04-06-2005 07:05 PM
The advance of engine technology SWCDuke C6 Tech/Performance 156 03-10-2004 08:51 PM
What plugs/plug gaps/temp ranges are you guys running with your FI apps Earl H C5 Forced Induction/Nitrous 9 06-26-2003 09:38 PM
Blown 377 - Crankcase pressure and oil problem steveelsbury C4 Tech/Performance 22 05-25-2003 01:29 PM
Supercharger vs Turbocharger and why.... ImAgE C5 Forced Induction/Nitrous 138 09-07-2002 12:59 AM
What happened at the Atanta Dragstrip Friday night? av8or3 C5 Z06 Discussion 78 04-03-2002 06:04 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
