Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-02-2007, 03:35 PM   #1
BrooklynC6
aka allbottle¬hrottle
St. Jude Donor '08
BrooklynC6's Avatar
Location: Brooklyn New York The DVL and the chicken sleep with the fishes....
Default Voltage Question ......
Hey folks - Im running the Procharger P1-SC , and Im noticing the my voltometer is getting lower as I drive ...
What I mean is , when I start the car in the AM (cold) Voltage is bettween 14.1-13.9 , once the car is fully warmed up it drops slightly to about 13.9-13.5 , however if Ive been driving her hard for about an hour the voltage starts to fluctuate and settles as low as 11.9 on the guage ...
This of course is at idle with the headlights or DRL's on with nothing else (heat , A/C , radio , ect...) , as soon as Im moving again voltage shoots right back up into the 13's
No warning on the DIC and she starts fine and all , but Im curious what could be causing this .
Any thoughs ???
BrooklynC6 is offline   Reply With Quote
Old 11-02-2007, 05:56 PM   #2
07MontRedcp
CF Senior Member
Support Corvetteforum!
07MontRedcp's Avatar
Any thoughs ???
Sounds like the regulator is doing it's job. Higher initial voltage is to recharge for the start up. Then it tapers off. The change between idle speed and normal driving speed is due to the alternator changing speed with the engine. IMHO
BJK
__________________
APS TT 630 rwhp/654 rwtq @ 9 psi
'07 Z51, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, GT2 Coilovers, Autometer Cobalt Fuel & Boost Guages, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system.
07MontRedcp is offline   Reply With Quote
Reload this Page Voltage Question ......
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
