Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-30-2007, 09:59 PM   #1
Spearfisher
CF Senior Member
Spearfisher's Avatar
Default a S/C
I starting to do research on super chargers.
thanks
Spearfisher is offline   Reply With Quote
Old 10-30-2007, 10:55 PM   #2
Busa196
CF Senior Member
Busa196's Avatar
Send a message via Yahoo to Busa196
That's a broad spectrum of questions, but here's some answers.
1) D1SC ProCharger and headers
2) 600rwhp/520rwtq
3)10.5 psi
4) As reliable as stock if tuned correctly and not abused
-Busa196-
Busa196 is offline   Reply With Quote
Old 10-30-2007, 11:10 PM   #3
BrooklynC6
aka allbottle¬hrottle
St. Jude Donor '08
BrooklynC6's Avatar
Location: Brooklyn New York The DVL and the chicken sleep with the fishes....
Procharger here too ..
1- P1-sc , nothing else ( meth kit planned )
2- About 550 at the wheels , didnt see my last dyno sheet yet
3- 8-9 lbs
4- 6k miles so far , so far , so good
BrooklynC6 is offline   Reply With Quote
Old 10-30-2007, 11:47 PM   #4
saplumr
CF Senior Member
Support Corvetteforum!
saplumr's Avatar
Count me in as the ProCharger choice.
saplumr is online now   Reply With Quote
Old 10-31-2007, 01:23 AM   #5
1bdasvt
CF Senior Member
St. Jude Donor '06-'09
1bdasvt's Avatar
I love My Maggie!!
I've had it for over 1.5 years with ZREO problems!!!
1bdasvt is offline   Reply With Quote
Old 10-31-2007, 08:32 AM   #6
schilitj
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
schilitj's Avatar
1. Procharger D1Sc
2. 586/506 rwhp/tq
3. 5-7
4. 10K and numerous trips down the 1/4 mile strip
schilitj is offline   Reply With Quote
Old 10-31-2007, 11:40 AM   #7
R50THC5
CF Senior Member
R50THC5's Avatar
P-1 6 PSI. Strongly recommend you have somesort of drain plug added to make changing the oil easier. There are some kits and ideas out there . Sucking thru the top..SUX. Access to drain plug pretty tight and for me impossible to reach. If you plan on more HP go with the D1. You have more flexibilty and there is NO hood mods required non with the P-1 also
R50THC5 is offline   Reply With Quote
Old 10-31-2007, 12:50 PM   #8
Spearfisher
CF Senior Member
sound unanimous, looks like good results with the procharger
I was leaning that way anyway, due to the technology
thanks
Old 10-31-2007, 01:06 PM   #9
TLewis4095
CF Senior Member
Send a message via AIM to TLewis4095
thanks
Where are you located? Give us a call if you want a quote a the system installed & tuned.
TLewis4095 is offline   Reply With Quote
Old 10-31-2007, 08:12 PM   #10
GWHITE75
CF Senior Member
GWHITE75's Avatar
I like the design of the Procharger system
what do you guys recommend?
1. what do you have
2. how much HP do you get out of it
3. How much boost are you running
4. reliability
thanks
Do a search, there was a thread about a month ago asking which way to go.
I just had an ECS kit installed on my 06-A6, with a very conservative tune by Jason at Gulf Coast Performance. It made 462 RWHP on a Winpep7 Dynojet in 96 degree temps. I decided on the ECS kit because some felt they make better bracketing, use the Paxton Novi 1500 head unit and there were no real heating issues with it.
The thing you also should consider is you have the automatic, like I do, although yours has some modifications for 08 that should make it a little stronger and longer lasting with high HP. We won't see the RWHP numbers manual transmissions see, plus I was told to keep my RWHP around 500 and stay away from real sticky tires.
Others on here can tell you more, as I'm a newbie to this type of F/I. Oh, the current HP I have is real fun......... for now.
GWHITE75 is offline   Reply With Quote
Old 11-02-2007, 01:02 PM   #11
Dgatto
CF Senior Member
Quote:
Dgatto is offline   Reply With Quote
Old 11-02-2007, 02:31 PM   #12
06.Z51.MontRed.Vert
CF Senior Member
St. Jude Donor '08-'09
06.Z51.MontRed.Vert's Avatar
Location: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
I agree completely. Procharger makes a nice unit, but 2 things steered me to the Paxton, 1. The procharger is very loud mechanically because of the type of internal gearing it uses (straight vs helical on the paxton), and 2.The oil changing issue. The Paxton uses the engine oil, so a regular oil change is all you have to do. I like the fact that I'm running constantly filtered oil to the unit as opposed to a few ounces of oil that is self contained in the procharger.
Either way you cant go wrong.
Good luck with your choice.
06.Z51.MontRed.Vert is offline   Reply With Quote
Old 11-04-2007, 10:31 AM   #13
0EPP
CF Senior Member
1. what do you have
4. reliability
thanks
Take a look at some of the builds in my project car section.
Here is a bone stock 300 mile C6 that we installed an ATI ProCharger on. It made 323 rwhp stock, once the ProCharger was installed it made 470! http://www.exoticperformanceplus.com...Car.php?car=30
What would happen if you added headers and exhaust? Check out the 532 rwhp this '05 GTO is making, which uses the same LS2 engine.
http://www.exoticperformanceplus.com...Car.php?car=46 Bob
EPP is offline   Reply With Quote
Old 11-04-2007, 11:07 AM   #14
salvitale
CF Member
salvitale's Avatar
ecs novi 1500
meth inj
headers
stock bottom end
13-14 pounds
9k miles strong with a beautiful tune by doug
salvitale is offline   Reply With Quote
Old 11-06-2007, 11:19 AM   #15
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5&C6 609-752-0321
Quote:
Originally Posted by salvitale View Post
ecs novi 1500
meth inj
headers
stock bottom end
13-14 pounds
Thats not just a stock bottom end, thats a 100% stock engine!
This is no garage queen either, it's seen 10's on street tires and has whooped 700+ rwhp cars on the street. (closed course naturally)
There are many reasons why one kit surpasses others and it does not all come down to the head unit. It is reason like this why both the fastest C5 ATI and Paxton come from our shop with our kits. BTW, thats 9.33 with the Paxton, and 9.62 with an F1, same set up, that has to say something.
Thanks for the kind words Sal.
DOUG @ ECS is offline   Reply With Quote
Old 11-06-2007, 12:14 PM   #16
RWTD
CF Senior Member
A&A Corvette, IMO, has the absolute best centrifugal setup on the market.
https://www.aandacorvette.com/cart/s...p?MainCatID=39 <---click!
Note that the pictures are older, so read the text. Andy also includes a integrated radiator/oil cooler in his kits.
RWTD is offline   Reply With Quote
Reload this Page Need Help with a S/C
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
(Event) CF N/A & S/C Corvette Challenge Series vetterdstr Southern California 59 08-06-2004 09:33 PM
I need help with .bin file for my twin turbo LT1 corvette project Grzenio C4 Forced Induction/Nitrous 18 06-21-2004 03:57 AM
Need help with a question, should I go Vortech or H/C? 99 torch red vette C5 Tech 18 11-15-2003 12:40 PM
Need help with FX3 "service ride controll" light and codes. 95wht6spd C4 Tech/Performance 43 04-15-2003 07:57 AM
Ok got new puppy need help with the name! vettewrench Great Lakes 39 08-22-2002 11:58 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
