Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-29-2007, 10:46 PM   #1
jjas
CF Senior Member
Default 8 rib surpentime belt
Has anyone with a sc/procharger changed to an 8 rib belt? Is it recommended or can there be any damage done to the engine in doing so?
jjas is offline   Reply With Quote
Old 10-30-2007, 08:32 AM   #2
EuroRod
CF Senior Member
EuroRod's Avatar
Two reasons to go with an 8-rib set-up.
1. It's cool!
2. You're experiencing belt slip.
EuroRod is offline   Reply With Quote
Old 10-30-2007, 04:22 PM   #3
wanaZ
Junior Member
Quote:
From what I have heard it is a MUST.
wanaZ is offline   Reply With Quote
Old 10-30-2007, 09:59 PM   #4
WeaponsGradeTorque
CF Senior Member
get the 8-rib and don't waste any $$$ like I did on a 6-rib setup.
WeaponsGradeTorque is offline   Reply With Quote
Old 11-01-2007, 01:19 AM   #5
NemesisC5
Over The Edge
Support Corvetteforum!
NemesisC5's Avatar
Send a message via AIM to NemesisC5 Send a message via MSN to NemesisC5 Send a message via Yahoo to NemesisC5
Quote:
NemesisC5 is offline   Reply With Quote
Old 11-01-2007, 11:34 PM   #6
BAADC6
CF Senior Member
BAADC6's Avatar
I'm installing a procharger. I was told I probably don't need the 8 rib. What problems did you experience with the 6 rib
How much more was the 8 rib?? Thanks in advance for your help guys!!
BAADC6 is offline   Reply With Quote
Old 11-03-2007, 09:24 AM   #7
WeaponsGradeTorque
CF Senior Member
In my particular case their is some very minor belt slip in the higher RPMs (after 6500 rpm...C6 Z06). That is alot of Revs on that system plus this is with over 600 rwhp. Not too mention with a manual, it is a bit hard between shifts and more belt grip is always a good thing. It will cost you more $$$$ to do it later so just do it now. Your power delivery will be more predictable.
Old 11-03-2007, 12:52 PM   #8
backchannel
CF Senior Member
backchannel's Avatar
I ran procharged 434 small block in a riverboat. 767hp @ 6200 - took a 12 rib system to stop slip. Also used thicker brackets to stop flex and subsequent misalignment. Some of this was because jetboat was 1620 lbs and engine rev was violent. There were no issues with front crank bearing.
backchannel is offline   Reply With Quote
Old 11-03-2007, 01:20 PM   #9
BAADC6
CF Senior Member
BAADC6's Avatar
What was the cost to upgrade...send PM if you prefer...Thanks
Old 11-03-2007, 04:31 PM   #10
WeaponsGradeTorque
CF Senior Member
Did not do it yet, but probably $1200 parts + $800 labor. I really regret that i did not go with an 8-rib setup.
Reload this Page 8 rib surpentime belt
Tags
belt, c6, procharged, rib
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
