Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth Sponsored by
APS Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-24-2007, 07:37 PM   #1
sux2bme
CF Senior Member
sux2bme's Avatar
Default Guessing RWHP results?????
2005 ls2 m6
Mods
222/224 581 112lsa cam
ported heads, intake/tb
B&B headers X-pipe Corsa Exh.
415rwhp
Now adding
D-1sc Procharger 6psi
60lb injectors
boost a pump
fuel pump
and everything else needed.
Where do you think my rwhp is going to end up?
I hopping for 550ish
THANKS
Modding is so much fun.
sux2bme is offline   Reply With Quote
Old 10-24-2007, 07:50 PM   #2
huckleberrydude
CF Senior Member
cool man!
you might be on track for a bit more than that. Now your main problem will be trying to keep it straight with the weather cooling down.
huckleberrydude is offline   Reply With Quote
Old 10-24-2007, 07:54 PM   #3
sux2bme
CF Senior Member
sux2bme's Avatar
I forgot to say that I have 4.10 gears too OOPS
Old 10-24-2007, 09:53 PM   #4
saplumr
CF Senior Member
Support Corvetteforum!
saplumr's Avatar
You'll be way past 550.
saplumr is offline   Reply With Quote
Old 10-25-2007, 12:15 AM   #5
rstarr c6
CF Member
rstarr c6's Avatar
Im thinking close to 575-600rwhp! Throw a meth kit on it and hang on!
rstarr c6 is offline   Reply With Quote
Old 10-25-2007, 02:21 AM   #6
BrooklynC6
aka allbottle¬hrottle
St. Jude Donor '08
BrooklynC6's Avatar
Location: Brooklyn New York The DVL and the chicken sleep with the fishes....
Quote:
- With a meth kit you should be well over 600
BrooklynC6 is offline   Reply With Quote
Old 10-25-2007, 04:55 AM   #7
07MontRedcp
CF Senior Member
07MontRedcp's Avatar
Quote:
Plus 9 - 10 psi.
BJK
__________________
APS TT 630 rwhp/654 rwtq @ 9 psi
'07 Z51, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, GT2 Coilovers, Autometer Cobalt Fuel & Boost Guages, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system.
07MontRedcp is online now   Reply With Quote
Old 10-25-2007, 07:22 AM   #8
CHARGED UP
CF Senior Member
CHARGED UP's Avatar
Send a message via AIM to CHARGED UP
I think the 4:10's will take some hp away. I have a Novi 1500 /headers/4:10's & meth & running about 9psi & put down 507 RWHP & 481 TQ. I had it tuned at ECS & remember them saying hp was effected a little by gears. Good luck. Stay on conservative side with 4:10's as when you add supercharger car becomes a beast to handle.
CHARGED UP is offline   Reply With Quote
Old 10-25-2007, 11:20 AM   #9
0AIS
Former Vendor
Location: www.alcoholinjectionsystems.com info@alcoholinjectionsystems.com Phone: 1. 801. 447. 2559
Keep in mind his elevation is 3500 ft. He's going to see roughly 7-10% less horsepower then compared to someone with his exact same combination located at sea level.
AIS is offline   Reply With Quote
Old 10-25-2007, 11:37 AM   #10
vertC6
CF Senior Member
vertC6's Avatar
Just my .02 cents I would change out that cam cause your going to be bleeding off a lot of boost with it reducing potential hp. Maybe a 220/230 114 or 115.
vertC6 is offline   Reply With Quote
Old 10-25-2007, 11:54 AM   #11
sux2bme
CF Senior Member
sux2bme's Avatar
Quote:
What do you mean? I know its not the best cam but I didn't think it would steal power?
Old 10-25-2007, 03:28 PM   #12
07MontRedcp
CF Senior Member
Quote:
When doing force induction you don't want much if any overlap. With NA engines overlap is used to help empty on the exhaust cycle and use that vacuum to draw in on the intake cycle. With FI that provides a charge leak. Check the specs on my cam shown in my Signature.
BJK
EDIT: Depending on the back pressure in exhaust system, some overlap can be used to force the exhaust gases thru the system. Headers would change the equation.
Check this link. Post # 12. There are differences between TTs and Pro charger types but in general I think it might help in understanding what he's saying. http://forums.corvetteforum.com/show....php?t=1832999
__________________
Old 10-26-2007, 12:28 AM   #13
backchannel
CF Senior Member
backchannel's Avatar
Quote:
typical day here is 14% reduction
backchannel is offline   Reply With Quote
Old 11-18-2007, 06:54 PM   #14
sux2bme
CF Senior Member
sux2bme's Avatar
Dropped the car off yesterday they are going to start on it on monday.
I added a meth kit for safety and maybe a little more hp.
Will post results.
Old 11-20-2007, 09:56 PM   #15
lynnb
CF Senior Member
lynnb's Avatar
Will post results.
my car made 509rwhp stock with procharger and borla exhaust only you should be 580-600 range.keep us posted cam and headers are my next two mods.love to see your results.
lynnb is offline   Reply With Quote
Old 11-20-2007, 11:31 PM   #16
pennys58
SC CF Senior Member
St. Jude Donor '06-'07-'08
pennys58's Avatar
Send a message via AIM to pennys58
Will post results.
You're gonna love it! Good decision on the Meth kit. With those mods, here in Houston, you'd be in the 600+rwhp. If you have a 14% reduction, I am guessing between 530-580rwhp depending on how your tune is.
What size pulley are you using? I am not sure if 6lbs. is where you'll be at. 99% of the out of box D1's are pushing 9-11psi on a stock motor here. I was up at the shop today and a stock C6 put down 11lbs on a 4" pulley.
Good luck and keep us posted
John
pennys58 is offline   Reply With Quote
Old 11-26-2007, 03:40 PM   #17
sux2bme
CF Senior Member
sux2bme's Avatar
Its will be the stock pulley on the d1sc.
Old 11-26-2007, 07:11 PM   #18
dgcarver
CF Senior Member
dgcarver's Avatar
I have 4.75" pully on my D1 making 8-9 psi boost and 521 rwhp on stock engine w/ LG headers
__________________
2005 VR, Z-51, Six Speed, Procharger D1 @ 8 psi, piller mount vacuum/boost/wide band gages, LPE hood, Z06 Rear fenders, 160 deg T/S, LG Motorsport headers w/cats & X-Pipe, Magnaflow axle back exhaust, Chrome Z06 Wheels, Z06 Brake Upgrade w/SS lines, Full VR GM Spoiler, KP BAP w/Racetronix wiring harness, DPE Procharger 2 minute oil drain kit, Michelin Runflat Pilot Sport 345/30/19 Rear, 275/35/18 front, Halltech CAI, Tuned and Dyno'd with HPT at 535 rwhp 489 rwt by LG Motorsports
dgcarver is offline   Reply With Quote
Old 11-26-2007, 09:22 PM   #19
c6800hp
CF Senior Member
c6800hp's Avatar
Default Rwhp
I have a 4.63 pully on a PISC at 5.5 lbs of boost making 535 RWHP on 2005 MN LS2 with headers and B&B exhaust and 42 lbs injectors.
c6800hp is offline   Reply With Quote
Reload this Page Guessing RWHP results?????
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
My New Z51 is a DOG!! USMCVET C6 Tech/Performance 76 06-12-2005 01:58 AM
70+ rwhp/9mph trap speed gain from cam & UD pulley only + tuning on A4 C5 rwj383 C5 Tech 16 05-24-2005 04:17 AM
Cam change 1/8 mile results cscollis Performance Results 18 06-27-2004 02:55 AM
HEADS/CAM DYNO RESULTS INSIDE! Server Flooding pics! NJ99FRC C5 Tech 38 04-02-2004 01:29 AM
Finally...Over 700 rwhp! (Naturally Aspirated) 632C2 C1 & C2 Corvettes 17 02-28-2003 10:12 PM
Katech Stage II(+) head/cam results....yeah baby! COBrien C5 Tech 39 06-15-2002 07:02 PM
Dyno Results After Long Tube Header Install on LT1 Dave-T C4 Tech/Performance 22 02-19-2002 08:52 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
